    Config template file not exists, no ensubst
    8 Posts 2 Posters 2.6k Views 2 Watching
      sdetweil @DDE12
      @DDE12 this is a new feature, allowing runtime substitution of variables in the config
      see
      https://docs.magicmirror.builders/configuration/introduction.html#environment-variables
      the message just says we didn’t find the env file to use, not an error
      this goes along with some additional messaging in the case where we couldn’t find the module you specified in config.js … instead of being silent…
        DDE12 @sdetweil
        @sdetweil Thank you for taking a look at this. I forgot to put in the first post that the MM screen doesn’t start. If that message does not indicate an error, then I have another problem. Please let me know what else to try or what further info I can provide. Thanks!
          sdetweil @DDE12
          @DDE12 can you show the rest of the messages
            sdetweil @DDE12
            @DDE12 but I think you need to do the npm install in the MagicMirror folder
              DDE12 @sdetweil
              User@Win10 MINGW64 /c/MagicMirror
              $ npm run start
              magicmirror@2.23.0 start
              .\node_modules.bin\electron js\electron.js
              [27.05.2023 14:49.18.622] [LOG] Starting MagicMirror: v2.23.0
              [27.05.2023 14:49.18.638] [LOG] Loading config …
              [27.05.2023 14:49.18.638] [DEBUG] config template file not exists, no envsubst
              [27.05.2023 14:49.18.654] [LOG] Loading module helpers …
              [27.05.2023 14:49.18.654] [LOG] No helper found for module: alert.
              [27.05.2023 14:49.18.669] [LOG] Initializing new module helper …
              [27.05.2023 14:49.18.676] [LOG] Module helper loaded: updatenotification
              [27.05.2023 14:49.18.676] [LOG] No helper found for module: clock.
              [27.05.2023 14:49.19.008] [LOG] Initializing new module helper …
              [27.05.2023 14:49.19.008] [LOG] Module helper loaded: calendar
              [27.05.2023 14:49.19.008] [LOG] No helper found for module: compliments.
              [27.05.2023 14:49.19.008] [LOG] No helper found for module: weather.
              [27.05.2023 14:49.19.039] [LOG] Initializing new module helper …
              [27.05.2023 14:49.19.039] [LOG] Module helper loaded: newsfeed
              [27.05.2023 14:49.19.039] [LOG] All module helpers loaded.
              [27.05.2023 14:49.19.070] [LOG] Starting server on port 8080 …
              [27.05.2023 14:49.19.209] [LOG] Launching application.
              [27.05.2023 14:49.19.391] [LOG] Server started …
              [27.05.2023 14:49.19.391] [LOG] Connecting socket for: updatenotification
              [27.05.2023 14:49.19.391] [LOG] Starting module helper: updatenotification
              [27.05.2023 14:49.19.391] [LOG] Connecting socket for: calendar
              [27.05.2023 14:49.19.400] [LOG] Starting node helper for: calendar
              [27.05.2023 14:49.19.400] [LOG] Connecting socket for: newsfeed
              [27.05.2023 14:49.19.400] [LOG] Starting node helper for: newsfeed
              [27.05.2023 14:49.19.400] [LOG] Sockets connected & modules started …
                sdetweil @DDE12
                @DDE12 doah, windows… bug, temp fix or pull the develop branch
                temp fix, remove the red, add the green
                https://github.com/MichMich/MagicMirror/commit/979f4ec6647728215ff1cccca941548b703ad356
                or get the develop branch
                https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                  DDE12 @sdetweil
                  @sdetweil The temp fix worked. Thank you!
                  • D DDE12 referenced this topic on
