    The correct way to update a module
    8 Posts 4 Posters 9.6k Views 4 Watching
      JMac
      I’ve had the notification on the top bar saying there’s an update to my MMM-calendarExt3 module, that the current installation is 2 commits behind the main branch.
      What is the correct way of dealing with this?
      It may seem a daft question however…
      The last time I had an update the issues off the back of it - when the update ran into issues and failed part way - and the entire MM stopped working and some kind people on here rescued me from the point of binning the whole setup.
      Cheers.
      sdetweil edit: change topic name
      BKeyportB M 2 Replies Last reply Reply Quote 0
      • BKeyportB Online
        BKeyport Module Developer @JMac
        @JMac in this case, if you’re that close, it’s a simple git pull in your module directory, then restart.
        as a force of habit, I run git pull then npm install on every update, just to make sure everything loads, then restart.
        Likely, the reason it didn’t work before was a slight change to the code introduced in 1.2.0 - MMRize took duplicate code out of all his CX3 modules, and made a single file for them all - you had to install that code via the documentation here: https://github.com/MMRIZE/MMM-CalendarExt3Agenda#update-to-120
        I missed it too…
          MMRIZE @JMac
          @JMac
          cd <YOUR_MM_DIRECTORY>/modules/MMM-CalendarExt3
          git pull
          npm install
          When you meet some error message about CX3_Shared, try this also there.
          git submodule update --init --recursive
          S J 2 Replies Last reply Reply Quote 0
            sdetweil @MMRIZE
            @MMRIZE you should add a postinstall npm task and check that and do the git commands
              MMRIZE @sdetweil
              I did already, so most cases it will work unless missing ‘npm install’
                sdetweil @MMRIZE
                @MMRIZE ah…
                  JMac @MMRIZE
                  @MMRIZE When I cd MagicMirror I get into that directory
                  but the /modules/MMM-CalendarExt3 says it isn’t recognised.
                    sdetweil @JMac
                    @JMac not /modules
                    / at the front means root
                    you want ~/MagicMirror/modules/MMM-CalendarExt3
                    ~ at the front means current users home folder
                    if you are in the MagicMirror folder, then
                    cd modules
                    will move the current folder the the ~/MagicMirror/modules folder
