    MMM-ImagesPhotos issue
    14 Posts 2 Posters 6.8k Views 2 Watching
    • N Offline
      Nneuland
      After install Magic Mirror will not auto boot after change to config file.
      Receiving this when attempting to run npm run start in he Magic Mirror folder.
      magicmirror@2.23.0 start
      [13.06.2023 12:54.22.117] [LOG] Starting MagicMirror: v2.23.0
      [13.06.2023 12:54.22.123] [LOG] Loading config …
      [13.06.2023 12:54.22.126] [DEBUG] config template file not exists, no envsubst
      [13.06.2023 12:54.22.132] [LOG] Loading module helpers …
      [13.06.2023 12:54.22.145] [LOG] Initializing new module helper …
      [13.06.2023 12:54.22.146] [LOG] Module helper loaded: MMM-PiTemp
      [13.06.2023 12:54.22.146] [LOG] No helper found for module: MMM-connection-status.
      [13.06.2023 12:54.22.401] [LOG] Initializing new module helper …
      [13.06.2023 12:54.22.402] [LOG] Module helper loaded: MMM-nyc-transit
      [13.06.2023 12:54.22.408] [ERROR] (node:6269) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
      Require stack:
      • /home/pi/MagicMirror/modules/MMM-ImagesPhotos/node_helper.js
      • at Module._resolveFilename (node:internal/modules/cjs/loader:963:15)
        at n._resolveFilename (node:electron/js2c/browser_init:2:109751)
        at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Module._load (node:internal/modules/cjs/loader:811:27)
        at f._load (node:electron/js2c/asar_bundle:2:13330)
        at Module.require (node:internal/modules/cjs/loader:1035:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at Object. (/home/pi/MagicMirror/modules/MMM-ImagesPhotos/node_helper.js:10:15)
        at Module._compile (node:internal/modules/cjs/loader:1141:14)
        at Module._extensions…js (node:internal/modules/cjs/loader:1196:10)
        at Module.load (node:internal/modules/cjs/loader:1011:32)
        at Module._load (node:internal/modules/cjs/loader:846:12)
        at loadModule (/home/pi/MagicMirror/js/app.js:184:19)
        (Use electron --trace-warnings ... to show where the warning was created)
        [13.06.2023 12:54.22.410] [ERROR] (node:6269) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
        [13.06.2023 12:54.22.704] [LOG] Launching application.
        MESA-LOADER: failed to retrieve device information
        MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
        failed to load driver: kms_swrast
        MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
        failed to load swrast driver
      Any suggestions?
        sdetweil @Nneuland
        @Nneuland see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
        • N Offline
          Nneuland @sdetweil
          This might be over my head…
          pi@raspberrypi:~/MagicMirror/modules/MMM-ImagesPhotos $ npm install
          npm ERR! code ERESOLVE
          npm ERR! ERESOLVE could not resolve
          npm ERR!
          npm ERR! While resolving: magicmirror-images-photos@0.1.1
          npm ERR! Found: stylelint@14.16.1
          npm ERR! node_modules/stylelint
          npm ERR! peer stylelint@“14.x” from grunt-stylelint@0.18.0
          npm ERR! node_modules/grunt-stylelint
          npm ERR! dev grunt-stylelint@“latest” from the root project
          npm ERR!
          npm ERR! Could not resolve dependency:
          npm ERR! dev stylelint-config-standard@“latest” from the root project
          npm ERR!
          npm ERR! Conflicting peer dependency: stylelint@15.7.0
          npm ERR! peer stylelint@“^15.5.0” from stylelint-config-standard@33.0.0
          npm ERR! node_modules/stylelint-config-standard
          npm ERR!
          npm ERR! Fix the upstream dependency conflict, or retry
          npm ERR! this command with --force, or --legacy-peer-deps
          npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
          npm ERR!
          npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.
          npm ERR! /home/pi/.npm/_logs/2023-06-13T18_03_53_057Z-debug-0.log
            sdetweil @Nneuland
            @Nneuland ok, fun stuff…
            the module is so old that the development dependencies no longer exist…
            so
            edit the package.json
            and change this
              "devDependencies": {
            to this.
              "devDependencies1": {
            the rerun npm install
            another stupid thing, npm gives you the option to NOT install the dev stuff. --omit=dev, BUT it still checks them and fails if they don’t work…
            so, we have to force them to not exist…
            • N Offline
              Nneuland @sdetweil
              thanks Sam. after adjusting the devDependencies in package.json then running npm install seemed to correct the install.
              I have auto start mirror enabled when making adjustments to config file. However after adding the config info for this module, the mirror wont start. maybe too old of a module…any suggestions on a better image viewer module?
                sdetweil @Nneuland
                @Nneuland did u fix the missing library problem??? which is why MM doesn’t start???
                • N Offline
                  Nneuland @sdetweil
                  i have not yet. I’ll need to research how to do that properly…
                    sdetweil @Nneuland
                    @Nneuland see the link I posted on what to do. no research needed
                    https://forum.magicmirror.builders/topic/17845/mmm-imagesphotos-issue/2?_=1686706297079
                    • N Offline
                      Nneuland @sdetweil
                      Thank you Sam!!
                        sdetweil @Nneuland
                        @Nneuland are you back up and running?
                        N 2 Replies Last reply Reply Quote 0
                        • N Offline
                          Nneuland @sdetweil
                          I’m gonna give it a go later tonight
                          • N Offline
                            Nneuland @sdetweil
                            After following your basic instructions I’m still having the issue.
                            To clarify, after adding the modules config information, the mirror wont start up… removing the config information and saving auto starts the mirror.
                              sdetweil @Nneuland
                              @Nneuland correct, did you add the missing library request??
                              the link says,
                              read the messages output by MM at startup (which you showed above)
                              find the not found message, which has the library name in it
                              use the library name in an
                              npm install  library_name_here
                              command while the current folder is the module folder
                              I am trying to teach you how to resolve this on your own next time… vs just giving u the answer, and having to do that over and over
                              • N Offline
                                Nneuland @sdetweil
                                Got it! Solved!
                                Sam, I can’t thank you enough for your time and patience. I appreciate all of your help. Over the years even!
                                I dont mean to be an annoyance. I find these issues daunting and beyond understanding at times.
