    Current Weather Not Dimmed
    4 Posts 2 Posters 988 Views 2 Watching
    • E Offline
      Elkanah
      Hey, I’ve been playing with the CSS (total newbie) and have tweaked a bunch of things. But I ran into an issue with the current weather. Aside from the current temperature and weather icon, everything is dimmed text. I’d like it all to be bright white but I can’t figure out how to do that. Can anyone help?
      Thanks!
      ankonaskiff17A 1 Reply Last reply Reply Quote 0
      • ankonaskiff17A Offline
        ankonaskiff17 @Elkanah
        @Elkanah
        You want this?
        Change --color-text-dimmed: #fff;
        I wanted everything to be white across the board so did that by copying the whole root font configuration into custom.css and made change in custom.css NOT in main.css
        • E Offline
          Elkanah
          Yes, that’s what I am aiming for and your tip was perfect! It’s looking great now!
            @Elkanah Glad I could help.
            You can stack modules one after the other because in some respects something like top_left has no bottom. You can have modules below the bottom of the physical monitor.
            If you want modules in a particular order, arrange them that way in config.js
            If you are looking for a particular color or say colors that compliment each other you can do a search on “hex color codes” and you will get the hex nomenclature for every color imaginable. Some colors you can just say “black” or “white” and that will work but I’ve personally stuck with using the hex codes for the most part.
