    2.24.0 - Calendar Error. Could not fetch calendar
    6 Posts 3 Posters 1.6k Views 3 Watching
    • AssassinsA Offline
      Assassins
      Is work before update to 2.24.0
      [02.07.2023 21:19.56.057] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/modules/calendars/190C3BC4-1E8B-43Fkkk4-9EBE438.ics FetchError: request to http://localhost:8080/modules/calendars/190C3BC4-1E8B-43F4E-89BE438.ics failed, reason: connect ECONNREFUSED ::1:8080
      at ClientRequest. (/home/pi/MagicMirror/node_modules/node-fetch/lib/index.js:1505:11)
      at ClientRequest.emit (node:events:513:28)
      at Socket.socketErrorListener (node:_http_client:502:9)
      at Socket.emit (node:events:513:28)
      at emitErrorNT (node:internal/streams/destroy:151:8)
      at emitErrorCloseNT (node:internal/streams/destroy:116:3)
      at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {
      type: ‘system’,
      errno: ‘ECONNREFUSED’,
      code: ‘ECONNREFUSED’
        sdetweil @Assassins
        @Assassins if you didn’t make a special folder called calendars
        that might be an issue
        if you open a browser and go to that url what happens?
        AssassinsA 1 Reply Last reply Reply Quote 0
          Assassins @sdetweil
          @sdetweil The folder is there, and all the files
          • karsten13K Offline
            karsten13 @Assassins
            see https://github.com/MichMich/MagicMirror/issues/3147
              Assassins @karsten13
              @karsten13 yes, is me there 😉
                Assassins
                The error is fix with : https://github.com/MichMich/MagicMirror/issues/3147
