    RPI4 Dual Monitor blanking
    7 Posts 2 Posters 1.7k Views 2 Watching
    • G Offline
      grantc66
      Started a new project with a dual monitor setup using a pi4. Connected via DVI as there is no HDMI (only display port, thanks HP).
      Monitors are in portrait mode & MM is setup in single instance configuration using this post as a template (linky)
      The latest version of Bullseye seems to have stopped “vcgencmd display_power 0” from working , it no longer blanks the display and just responds with display_power=1. This appears to be due to a change to the KMS driver.
      Googling give me this as an alternative
      xrandr --output HDMI-1 --off
      It does work & switches the screens off (separate commands for HDMI-1 & HDMI-2) however, using
      xrandr --output HDMI-2 --off
      to switch off and
      xrandr --output HDMI-1 --rotate right --auto
      xrandr --output HDMI-2 --rotate left --right-of HDMI-1 --auto
      Puts them back in the right place . Sometimes.
      About 1 in every 10 off/on cycles the righthand display ends up on HDMI-1 & HDMI-2 shows the desktop. CTRL W puts it back in the right place, but that’s really annoying & I don’t want to reset the MM every time as it looks ugly whilst repopulating.
      Has anyone found a more reliable method to blank the displays & return MM back to the correct displays?
      wishmaster270W G 2 Replies Last reply Reply Quote 0
      • wishmaster270W Offline
        wishmaster270 Module Developer @grantc66
        @grantc66 Hi,
        it may be a timing issue.
        Maybe a sleep 1 between the two xrand commands helps.
        • G Offline
          grantc66 @wishmaster270
          @wishmaster270 Thanks for the suggestion. Unfortunately not a timing issue.
          Adding a delay didn’t change the behaviour. ☹️
          • G Offline
            grantc66 @grantc66
            After nearly a week of trying different things, short of removing the KMS driver or reverting to Buster, the only method I could come up with was to use the xset screensaver.
            Set the timeout to 3 minutes
            xset -display :0 s 180
            and do
            xset -display :0 s reset
            to wake it up on motion.
            It’s not elegant but without any cec control of the monitor it appears to be my only solution, unless anyone has a method to get xrandr to keep electron on the correct monitor.
              @grantc66
              There are ways to move windows to a specific screen on the bash. But it is complicated.
              Maybe one of the solutions in this thread solves your problem.
              • G Offline
                grantc66 @grantc66
                @grantc66
                For anyone having the same issue:
                Another solution is to edit /boot/config.txt & change to the fake kms driver
                dtoverlay=vc4-kms-v3d
                to
                dtoverlay=vc4-fkms-v3d
                reboot & then
                vcgencmd display_power 1
                work as they used to do.
                I’ve not noticed any negative effect from using the fake one but I’m not using any 3D effects (your results may vary).
                • G Offline
                  grantc66
                  For anyone having this issue:
                  Change the kms driver to the fake one by editing /boot/config.txt
                  change
                  to
                  Reboot & display will now switch on/off using
                  I’ve not noticed any problems using the fake driver but I’m not using anything 3D (your results may be different)
