    After update MMM-Buttons breaks, made things worse trying to fix it
    23 Posts 5 Posters 5.7k Views 5 Watching
    • G Offline
      gonzonia @sdetweil
      @sdetweil Apologies. You did say that already and it didn’t penetrate. Replaced with your fork and it looks like I’m mostly back up. CalendarExt2 doesn’t seem to be loading though. I’ll have to dig into that later.
      • LusbuebL Offline
        Lusbueb @gonzonia
        @gonzonia had same problems and tried several methods. i’m not a linux crack and can only make what other say to try. :see-no-evil_monkey: :grinning_squinting_face:
        this Post help me: https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more/2?page=1
        1. delete any existing ../modules/MMM-Buttons folder.
        2. clone the repository in your modules folder:
          cd ~/MagicMirror/modules
          git clone https://github.com/MarcLandis/MMM-Buttons.git
          cd MMM-Buttons
        3. install magicmirror-rebuild library with this command:
          npm i magicmirror-rebuild
        pi@MM:~/MagicMirror/modules/MMM-Buttons $ npm i magicmirror-rebuild
        added 191 packages, and audited 192 packages in 43s
        37 packages are looking for funding
          run `npm fund` for details
        found 0 vulnerabilities
        1. try to execute MagicMirror-rebuild script for rebuild with this command:
          ./node_modules/.bin/MagicMirror-rebuild
        pi@MM:~/MagicMirror/modules/MMM-Buttons $ ./node_modules/.bin/MagicMirror-rebuild
        ⠹ MagicMirror Building module: epoll, Completed: 0gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
        ⠸ MagicMirror Building module: epoll, Completed: 0gyp http GET https://www.electronjs.org/headers/v25.2.0/node-v25.2.0-headers.tar.gz
        ⠏ MagicMirror Building module: epoll, Completed: 0gyp http 200 https://artifacts.electronjs.org/headers/v25.2.0/node-v25.2.0-headers.tar.gz?force_headers_dist=1
        ⠼ MagicMirror Building module: epoll, Completed: 0gyp http GET https://www.electronjs.org/headers/v25.2.0/SHASUMS256.txt
        ⠋ MagicMirror Building module: epoll, Completed: 0gyp http 200 https://artifacts.electronjs.org/headers/v25.2.0/SHASUMS256.txt?force_headers_dist=1
        ⠙ MagicMirror Building module: epoll, Completed: 0gyp info spawn /usr/bin/python3
        gyp info spawn args [
        gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/node-gyp/gyp/gyp_main.py',
        gyp info spawn args   'binding.gyp',
        gyp info spawn args   '-f',
        gyp info spawn args   'make',
        gyp info spawn args   '-I',
        gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/config.gypi',
        gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/node-gyp/addon.gypi',
        gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/25.2.0/include/node/common.gypi',
        gyp info spawn args   '-Dlibrary=shared_library',
        gyp info spawn args   '-Dvisibility=default',
        gyp info spawn args   '-Dnode_root_dir=/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/25.2.0',
        gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/node-gyp',
        gyp info spawn args   '-Dnode_lib_file=/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/25.2.0/<(target_arch)/node.lib',
        gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll',
        gyp info spawn args   '-Dnode_engine=v8',
        gyp info spawn args   '--depth=.',
        gyp info spawn args   '--no-parallel',
        gyp info spawn args   '--generator-output',
        gyp info spawn args   'build',
        gyp info spawn args   '-Goutput_dir=.'
        gyp info spawn args ]
        ⠹ MagicMirror Building module: epoll, Completed: 0gyp info spawn make
        gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
        make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build“ wird betreten
          CXX(target) Release/obj.target/epoll/src/epoll.o
        ⠹ MagicMirror Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
        ⠧ MagicMirror Building module: epoll, Completed: 0  COPY Release/epoll.node
        make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build“ wird verlassen
        ✔ MagicMirror Rebuild Complete
        That you see MagicMirror Rebuild Complete !
        Your module is now installed correctly
        This way will also be good for the Originl MMM-Buttons from the Year 2017 and many other modules!
        if you work with this module https://github.com/Jopyth/MMM-Buttons you must change 2 lines and add 1 line in the file package.json after git clone:
        a.) change Line 23 from
        "postinstall": "node_modules/.bin/electron-rebuild -e ../../node_modules/electron" to
        "postinstall": "node_modules/.bin/magicmirror-rebuild -e ../../node_modules/electron"
        b.) change Line 29 from
        "electron-rebuild": "^1.2.1" to
        "magicmirror-rebuild": "^1.0.0"
        c.) add a line after line26 from
        "onoff": "latest" to
        "onoff": "latest",
        "magicmirror-rebuild": "latest"
        after that you can continue with step 3, good luck :)
          sdetweil @Lusbueb
          @Lusbueb or, you can get my fork of MMM-Buttons which fixes the install problem
          https://github.com/sdetweil/MMM-Buttons
          LusbuebL 2 Replies Last reply Reply Quote 1
          • LusbuebL Offline
            Lusbueb @sdetweil
            @sdetweil Of course I had also tried your git repo but it didn’t work for me, so I kept looking and with the alternative migicmirror-rebuild every module worked.
            I’ve also seen that some modules have been adapted to magicmirror-rebuild, but it’s of no use if you don’t know exactly how to use it.
            my description above was the solution that worked for me, so I published it here.
            thank you again for your support. :hugging_face:
              sdetweil @Lusbueb
              @Lusbueb I’d like to know what didn’t work, as I test it quite often. I don’t like providing fixes that don’t work…
              LusbuebL 1 Reply Last reply Reply Quote 0
              • LusbuebL Offline
                Lusbueb @sdetweil
                @sdetweil if i run your git repo it looks liike this:
                pi@MM:~ $ cd ~/MagicMirror/modules
                pi@MM:~/MagicMirror/modules $ git clone https://github.com/Jopyth/MMM-Buttons.git
                Klone nach 'MMM-Buttons' ...
                remote: Enumerating objects: 54, done.
                remote: Total 54 (delta 0), reused 0 (delta 0), pack-reused 54
                Empfange Objekte: 100% (54/54), 11.34 KiB | 893.00 KiB/s, fertig.
                Löse Unterschiede auf: 100% (25/25), fertig.
                pi@MM:~/MagicMirror/modules $ cd MMM-Buttons
                pi@MM:~/MagicMirror/modules/MMM-Buttons $ npm install
                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                npm WARN deprecated electron-rebuild@1.11.0: Please use @electron/rebuild moving forward.  There is no API change, just a package name change
                npm ERR! code 7
                npm ERR! path /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll
                npm ERR! command failed
                npm ERR! command sh -c node-gyp rebuild
                npm ERR! gyp info it worked if it ends with ok
                npm ERR! gyp info using node-gyp@6.1.0
                npm ERR! gyp info using node@20.4.0 | linux | arm
                npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
                npm ERR! gyp ERR! UNCAUGHT EXCEPTION
                npm ERR! gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
                npm ERR! gyp ERR! stack     at createConfigFile (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/node-gyp/lib/configure.js:118:21)
                npm ERR! gyp ERR! stack     at /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/node-gyp/lib/configure.js:85:9
                npm ERR! gyp ERR! stack     at /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/mkdirp/index.js:30:20
                npm ERR! gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:189:23)
                npm ERR! gyp ERR! System Linux 5.10.103-v7+
                npm ERR! gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/.bin/node-gyp" "rebuild"
                npm ERR! gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll
                npm ERR! gyp ERR! node -v v20.4.0
                npm ERR! gyp ERR! node-gyp -v v6.1.0
                npm ERR! gyp ERR! This is a bug in `node-gyp`.
                npm ERR! gyp ERR! Try to update node-gyp and file an Issue if it does not help:
                npm ERR! gyp ERR!     <https://github.com/nodejs/node-gyp/issues>
                npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-07-09T13_31_31_133Z-debug-0.log
                then i changed in our package.json
                  "dependencies": {
                    "onoff": "latest",
                  "devDependencies": {
                and do npm install it looks like this:
                > Magic-Mirror-Module-Buttons@1.0.0 postinstall
                sh: 1: node_modules/.bin/magicmirror-rebuild: not found
                npm ERR! code 127
                npm ERR! command sh -c node_modules/.bin/magicmirror-rebuild -e ../../node_modules/electron
                npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-07-09T13_37_41_609Z-debug-0.log
                so, the package.json is allready changed, i delete the new created file package-lock.json and folder node_modules and run npm i magicmirror-rebuild it look like this:
                npm WARN idealTree Removing dependencies.magicmirror-rebuild in favor of devDependencies.magicmirror-rebuild
                added 191 packages, and audited 192 packages in 39s
                and then in run ./node_modules/.bin/MagicMirror-rebuild, it looks like this an everything ist ok an running with no errors:
                ⠋ MagicMirror Building module: epoll, Completed: 0gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
                ⠙ MagicMirror Building module: epoll, Completed: 0gyp http GET https://www.electronjs.org/headers/v25.2.0/node-v25.2.0-headers.tar.gz
                ⠦ MagicMirror Building module: epoll, Completed: 0gyp http 200 https://artifacts.electronjs.org/headers/v25.2.0/node-v25.2.0-headers.tar.gz?force_headers_dist=1
                ⠙ MagicMirror Building module: epoll, Completed: 0gyp http GET https://www.electronjs.org/headers/v25.2.0/SHASUMS256.txt
                ⠹ MagicMirror Building module: epoll, Completed: 0gyp http 200 https://artifacts.electronjs.org/headers/v25.2.0/SHASUMS256.txt?force_headers_dist=1
                ⠸ MagicMirror Building module: epoll, Completed: 0gyp info spawn make
                ⠇ MagicMirror Building module: epoll, Completed: 0  COPY Release/epoll.node
                hope it helps you :-)
                Regards, Peter from Switzerland
                  sdetweil @Lusbueb
                  @Lusbueb said in After update MMM-Buttons breaks, made things worse trying to fix it:
                  that is not mine… that is the broken one
                  substitute my repo URL for the documented git clone url
                  • LusbuebL Offline
                    Lusbueb @sdetweil
                    @sdetweil said in After update MMM-Buttons breaks, made things worse trying to fix it:
                    oh yes, thats true! 🙈 Please change your Installation -Instruktion in your GIT, thank you😅
                      sdetweil @Lusbueb
                      no… mine is a fork of the master… you should know to substitute my URL for the one in the doc (if any)
                      if I were to change the link AND submit it to the author, AND they took it, then their doc would point to MY repo incorrectly…
                      this is how the fork process works…
                      SO, if you git clone my url and do the npm install, does it fail?
                      LusbuebL 1 Reply Last reply Reply Quote 1
                      • LusbuebL Offline
                        Lusbueb @sdetweil
                        yes you did it :-)
                        your fork works, you are my hero! :-)
                        but why can’t you adapt the readme file in a FORK?
                        pi@MM:~/MagicMirror/modules $ git clone https://github.com/sdetweil/MMM-Buttons
                        remote: Enumerating objects: 56, done.
                        remote: Counting objects: 100% (4/4), done.
                        remote: Compressing objects: 100% (4/4), done.
                        remote: Total 56 (delta 0), reused 2 (delta 0), pack-reused 52
                        Empfange Objekte: 100% (56/56), 11.86 KiB | 146.00 KiB/s, fertig.
                        > ./postinstall
                        ✔ Rebuild Complete
                        added 6 packages, and audited 7 packages in 32s
                          sdetweil @Lusbueb
                          @Lusbueb cause it’s temporary… maybe.
                          things you just learn to deal w
                          • LusbuebL Offline
                            Lusbueb @sdetweil
                            hello sam
                            Can you please adjust the command in your repo (https://github.com/sdetweil/MMM-Buttons) under Installation:
                            from (false): git clone https://github.com/Jopyth/MMM-Buttons.git
                            to (right): git clone https://github.com/sdetweil/MMM-Buttons
                            I’m so glad that I copied the link to this forum back then, but it took a long time before I realized that I was always installing the faulty git (Jopyth) instead of your git, just because I followed your installation instructions.
                            Happy New Year and thank you for your work :-)
                            Kind regards
                            Peter
                              sdetweil @Lusbueb
                              @Lusbueb done… I never copy/paste that instruction… I push the green button to copy the code in this current repo (regardless of the name)
                              KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
                              • KristjanESPERANTOK Offline
                                @Lusbueb Just a side note: On the module list is the fork from MarcLandis (https://github.com/MarcLandis/MMM-Buttons), he is actively maintaining the module.
                                • LusbuebL Offline
                                  Lusbueb @KristjanESPERANTO
                                  @KristjanESPERANTO Thank you for the tip, but the notification does not work for the MMM-Carousel module and with the fork from sdetweil everything works as it should for me.
