    Exiting GPU process due to errors during initialization
    3 Posts 3 Posters 1.8k Views 3 Watching
      Sebi76 0
      I installed a freh installation from MagicMirror on a RPI3 with 2023-02-21-raspios-bullseye-armhf Image.
      I updated Pi, Electron; NodeJs
      Bu follwed the Erros i become…
      1784:0319/124629.513027:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      [1824:0319/124630.051065:ERROR:gpu_memory_buffer_support_x11.cc(49)] dri3 extension not supported.
      [1798:0319/124630.130077:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
        Merowinger @Sebi76 0
        @Sebi76-0 I updated to 2.24.0 and got this problem right now. Strange that nobody can help
          sdetweil @Merowinger
          @Merowinger this is a pi config issue with the display driver
          in the short term you can turn off use of the gou.by electron by adding
          export ELECTRON_DISABLE_GPU=1
          before
          npm start
          if u are using my install script and pm2, then the little startup script is
          ~/MagicMirror/installers/mm.sh
