    Different URLS to different configs
    coreurlconfig
    4 Posts 2 Posters 1.6k Views 2 Watching
    • W
      Whitling2k
      Just wondering if it is possible to have a different URL on the local host to load a different config?
      i.e. http://192.168.1.101:8080/ points to my default, config, and is loaded on MM dedicated portrait screen.
      But, http://192.168.1.101:8080/browser.html points to a different layout optimised for a landscaped screen.
      And http://192.168.1.101:8080/ios.html points to a different layout optimised for a phone screen.
      I would want them all loading the same modules (ish), but display them differently
        sdetweil @Whitling2k
        @Whitling2k currently no.
        but you could run multiple instance w different configs from the same files. using the
        environment variable
        MM_CONFIG_FILE=/user/pi/MagicMirror/config/config.js
        you can also use environment variable for port
        MM_PORT=8080
        note that css can detect size, orientation and vendor
        if width is less than height, then in portrait mode
        so you could have a customized custom.css that would do all that
        W 1 Reply Last reply
        • W
          Whitling2k @sdetweil
          Thanks @sdetweil
          What sort of system resources would two instances consume? I’m running on a Pi 4b, that’s also being used as a local web server and weather station. So critical functions - would two instances of MM cause high cpu/memory usage?
          I think the time it would take me to learn enough CSS to build responsive pages for my 4/5 devices would exceed my current free time :-D
          Cheers again!
            @Whitling2k depends on the modules. most of the time is spent waiting for data.
            responsive
            if you were building separate urls, its the same work.
            use variables and calc at the beginning…see main.css
