    MMM-ModuleMonkeyPatch
    3 Posts 3 Posters 975 Views 3 Watching
      MMRIZE
      MagicMirror module to make monkey-patching other modules
      https://github.com/MMRIZE/MMM-ModuleMonkeyPatch
      No screenshot, because it works in the background.
      Why?
      When you need some modification of existing modules but do not want to edit the original source code to prevent conflicts on upgrade/update.
      But… I think rare people will use this module. :D. This was my half-day weekend killing-time project.
      Usage example;
      • When you want to change the rendering of a specific module, but not sufficient with only CSS handling. So you have to modify getDom(), you can override that method with this module.
      • When you want to insert a logic into some module to handle your specific notification, you can override notificationReceived() with this module.
      Or many other things, without worrying of update/upgrading the original module on direct modification.
      Limitation
      • This module works after ALL_MODULES_STARTED notification, which means you cannot override start method.
      BKeyportB M 2 Replies Last reply Reply Quote 2
      • BKeyportB Offline
        BKeyport Module Developer @MMRIZE
        @MMRIZE Ok, so how do I defeat this for my module? 🤣
          Matuki Module Developer @MMRIZE
          @MMRIZE Excellent!
          No more need to do ugly patch. Thank you for this module.
