    BirdNET-PI-chart on MM2
    Scheduled Pinned Locked Moved Education
    35 Posts 5 Posters 22.1k Views 5 Watching
    • thgmirrorT Offline
      thgmirror @bhepler
      Hi @bhepler,
      during installation for BirdNet-Pi at paragraph 25 you are asked to request a BirdweatherID to partizipate in a worldwide citizen sience. That was my idea…
        bhepler Module Developer
        It’s coming along. Still much work to do.
          cyberdie @bhepler
          @bhepler Looks good!
          What a bout showing the last X birds identified with their corresponding pictures gathered from Flicker?
          thgmirrorT B 2 Replies Last reply Reply Quote 0
            thgmirror @cyberdie
            @cyberdie @bhepler
            BirdNET-Pi itself offers pictures of the birds:-)
              cyberdie @thgmirror
              @thgmirror Yes, i know. But showing them in an MM module is an interesting feature IMHO
              thgmirrorT 1 Reply Last reply Reply Quote 0
                thgmirror @cyberdie
                @cyberdie May be @bhepler can catch the pictures from BirdNET directly…
                  bhepler Module Developer @cyberdie
                  @cyberdie - I have an idea. Once I have it implemented I’ll post it and let you guys try it out.
                    cyberdie @bhepler
                    @bhepler Awesome!
                      thgmirror @cyberdie
                      • L Offline
                        lmhmm
                        I’m interested this and have just set it up on another pi. I am very interested in getting on my mm!
                        Shall I wait for the module or how did you get it via Smart Web Display?
                        I’m a beginner.
                        B thgmirrorT 2 Replies Last reply Reply Quote 0
                          bhepler Module Developer @lmhmm
                          @lmhmm - The key difference will be, IMHO, which data you want to display. If you want to display the chart from the first post from your own BirdNET-Pi installation, then go with the smart web display. My module will display everyone’s BirdNET hits around you, not just your own.
                          @thgmirror can probably walk you through setting up the smart web display.
                            Okay, version 0.1.0 is ready. I think. Give it a go and let me know if you encounter any problems.
                            MMM-BirdNET on GitHub
                              thgmirror @bhepler
                              @bhepler 404 when I try the link
                                thgmirror @lmhmm
                                @lmhmm
                                Currently, I’m using an RPI4 with BirdNET-Pi outside in the garden and an RPI3b as MM2. Both are in the same WIFI-net. Best is to use the standard-installation of BirdNET-Pi and to use the recommended names.
                                1. install MMM-EasyPix at MM2
                                2. add MMM-EasyPix to your config.js with birdnet.png as the name of the picture
                                3. add the following code to a file called
                                  makedownloadbirdnet.py at the root-folder of MM2
                                  sudo nano makedownloadbirdnet.py
                                #!/usr/bin/python
                                # coding:utf-8
                                import os
                                import urllib.request
                                import datetime
                                current_date = datetime.date.today()
                                url = "http://birdnetpi.local/Charts/Combo-"  + str(current_date) + ".png"
                                nix = "/home/pi/MagicMirror/modules/keinbild.png"
                                out = "/home/pi/MagicMirror/modules/MMM-EasyPix/pix/birdnet.png"
                                # Prüfen, ob es bereits eine Datei out im Verzeichnis gibt
                                if os.path.exists(out):
                                #   alte Datei löschen
                                    os.remove(out)
                                # Herunterladen der Datei
                                try:
                                    urllib.request.urlretrieve(url, out)
                                except:
                                    os.system(f'cp "{nix}" "{out}"')
                                1. Create a small picture with a hint, that a chart is not available, name it keinbild.png and store it in the modules-folder at MM2.
                                2. Create a cronjob at MM2:
                                * * * * sudo python3 makedownloadbirdnet.py
                                • L Offline
                                  lmhmm @thgmirror
                                  @thgmirror Blimey that’s a comprehensive answer!
                                  I’ll have to go my homework. I appreciate your comprehensive reply.
                                  Many thanks,
                                  Lorraine
                                    bhepler Module Developer @thgmirror
                                    @thgmirror - Sorry about that. Somehow, the repository was marked private. I’ve fixed it and it should work for you now.
                                    • L Offline
                                      lmhmm @bhepler
                                      @bhepler hello, I’ve successfully installed your module MMM-BirdNET and set the map to terrain and my Co ordinates etc.
                                      So while I get up a nice map, there don’t seem to be any stations or dots showing at all. Just a map.
                                      Also there’s no activity, just a map shows and nothing else.
                                      Can you advise?
                                      Lorraine
                                        @lmhmm - Absolutely. Let’s get you fixed up. Could you please post the relevant portion of your config.js? I want to try it on my test system and see if I can duplicate your problem.
                                        L 3 Replies Last reply Reply Quote 0
                                        • L Offline
                                          lmhmm @bhepler
                                          @bhepler Hello Brian,
                                          Please see the map and config. I have updated the module also and my mirror is up to date 2.24
                                          Lorraine
                                          Err not sure how to add the pictures?
                                          • L Offline
                                            lmhmm @bhepler
                                            @bheplerOkay here we go:
                                            Config:
                                            module: "MMM-BirdNET position:
                                            "top_center
                                            lat: 54.6633, lon: -3.3680, updateInterval: 3600000, popInterval:
                                            30000,
                                            dataUrl: “https://birdnet. cornell.edu/map/requeststats/” mapMode:
                                            “terrain”
                                            markercolor: “Light Blue” markerDistance: 300, //width:
                                            “100px”
                                            //height:
                                            “100px”
                                            zoomLevel: 7, //mapurl:
                                            null,
