    BirdNET-PI-chart on MM2
    Scheduled Pinned Locked Moved Education
    35 Posts 5 Posters 21.7k Views 5 Watching
      bhepler Module Developer @thgmirror
      @thgmirror I’m not sure I understand. Their GitHub repository is an analysis application. I’m just planning on a display interface. Only slightly more involved than displaying Dad Jokes.
      If you mean submitting the module to be included in their Showroom section of their GitHub, then certainly.
      Did you mean integrating with the BirdNET-Pi app? That may be possible. But I’m not sure why your mirror would be listening to birds. But there are a lot of odd configurations out there.
      thgmirrorT 1 Reply Last reply Reply Quote 0
      • thgmirrorT Offline
        thgmirror @bhepler
        Hi @bhepler,
        during installation for BirdNet-Pi at paragraph 25 you are asked to request a BirdweatherID to partizipate in a worldwide citizen sience. That was my idea…
          It’s coming along. Still much work to do.
            cyberdie @bhepler
            @bhepler Looks good!
            What a bout showing the last X birds identified with their corresponding pictures gathered from Flicker?
            thgmirrorT B 2 Replies Last reply Reply Quote 0
              thgmirror @cyberdie
              @cyberdie @bhepler
              BirdNET-Pi itself offers pictures of the birds:-)
                cyberdie @thgmirror
                @thgmirror Yes, i know. But showing them in an MM module is an interesting feature IMHO
                  thgmirror @cyberdie
                  @cyberdie May be @bhepler can catch the pictures from BirdNET directly…
                    bhepler Module Developer @cyberdie
                    @cyberdie - I have an idea. Once I have it implemented I’ll post it and let you guys try it out.
                      cyberdie @bhepler
                      @bhepler Awesome!
                        thgmirror @cyberdie
                        • L Offline
                          lmhmm
                          I’m interested this and have just set it up on another pi. I am very interested in getting on my mm!
                          Shall I wait for the module or how did you get it via Smart Web Display?
                          I’m a beginner.
                          B thgmirrorT 2 Replies Last reply Reply Quote 0
                            bhepler Module Developer @lmhmm
                            @lmhmm - The key difference will be, IMHO, which data you want to display. If you want to display the chart from the first post from your own BirdNET-Pi installation, then go with the smart web display. My module will display everyone’s BirdNET hits around you, not just your own.
                            @thgmirror can probably walk you through setting up the smart web display.
                              Okay, version 0.1.0 is ready. I think. Give it a go and let me know if you encounter any problems.
                              MMM-BirdNET on GitHub
                                thgmirror @bhepler
                                @bhepler 404 when I try the link
                                  thgmirror @lmhmm
                                  @lmhmm
                                  Currently, I’m using an RPI4 with BirdNET-Pi outside in the garden and an RPI3b as MM2. Both are in the same WIFI-net. Best is to use the standard-installation of BirdNET-Pi and to use the recommended names.
                                  1. install MMM-EasyPix at MM2
                                  2. add MMM-EasyPix to your config.js with birdnet.png as the name of the picture
                                  3. add the following code to a file called
                                    makedownloadbirdnet.py at the root-folder of MM2
                                    sudo nano makedownloadbirdnet.py
                                  #!/usr/bin/python
                                  # coding:utf-8
                                  import os
                                  import urllib.request
                                  import datetime
                                  current_date = datetime.date.today()
                                  url = "http://birdnetpi.local/Charts/Combo-"  + str(current_date) + ".png"
                                  nix = "/home/pi/MagicMirror/modules/keinbild.png"
                                  out = "/home/pi/MagicMirror/modules/MMM-EasyPix/pix/birdnet.png"
                                  # Prüfen, ob es bereits eine Datei out im Verzeichnis gibt
                                  if os.path.exists(out):
                                  #   alte Datei löschen
                                      os.remove(out)
                                  # Herunterladen der Datei
                                  try:
                                      urllib.request.urlretrieve(url, out)
                                  except:
                                      os.system(f'cp "{nix}" "{out}"')
                                  1. Create a small picture with a hint, that a chart is not available, name it keinbild.png and store it in the modules-folder at MM2.
                                  2. Create a cronjob at MM2:
                                  * * * * sudo python3 makedownloadbirdnet.py
                                  • L Offline
                                    lmhmm @thgmirror
                                    @thgmirror Blimey that’s a comprehensive answer!
                                    I’ll have to go my homework. I appreciate your comprehensive reply.
                                    Many thanks,
                                    Lorraine
                                      @thgmirror - Sorry about that. Somehow, the repository was marked private. I’ve fixed it and it should work for you now.
                                      • L Offline
                                        lmhmm @bhepler
                                        @bhepler hello, I’ve successfully installed your module MMM-BirdNET and set the map to terrain and my Co ordinates etc.
                                        So while I get up a nice map, there don’t seem to be any stations or dots showing at all. Just a map.
                                        Also there’s no activity, just a map shows and nothing else.
                                        Can you advise?
                                        Lorraine
                                          @lmhmm - Absolutely. Let’s get you fixed up. Could you please post the relevant portion of your config.js? I want to try it on my test system and see if I can duplicate your problem.
                                          L 3 Replies Last reply Reply Quote 0
                                          • L Offline
                                            lmhmm @bhepler
                                            @bhepler Hello Brian,
                                            Please see the map and config. I have updated the module also and my mirror is up to date 2.24
                                            Lorraine
                                            Err not sure how to add the pictures?
