    MMM-UKTide - error on load
    2 Posts 2 Posters 478 Views 2 Watching
    • O Offline
      olitills
      New to Magic Mirrors, so feeling things out at this stage.
      After installing https://github.com/Captsi/MMM-UKTide on a fresh RPi 4 Magic Mirror setup I encounter the following error, which prevents the mirror from loading (whereas if I remove this module from the config.js the mirror loads just fine.
      Any suggestions?
      pi@minecraft:~/MagicMirror $ npm start
      > > magicmirror@2.24.0 start
      > > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      > [27.08.2023 16:24.34.781] [LOG]   Starting MagicMirror: v2.24.0
      > [27.08.2023 16:24.34.789] [LOG]   Loading config ...
      > [27.08.2023 16:24.34.792] [DEBUG] config template file not exists, no envsubst
      > [27.08.2023 16:24.34.798] [LOG]   Loading module helpers ...
      > [27.08.2023 16:24.34.800] [LOG]   No helper found for module: alert.
      > [27.08.2023 16:24.34.824] [LOG]   Initializing new module helper ...
      > [27.08.2023 16:24.34.825] [LOG]   Module helper loaded: updatenotification
      > [27.08.2023 16:24.35.142] [LOG]   Initializing new module helper ...
      > [27.08.2023 16:24.35.143] [LOG]   Module helper loaded: calendar
      > [27.08.2023 16:24.35.145] [LOG]   No helper found for module: clock.
      > [27.08.2023 16:24.35.151] [ERROR] (node:6501) UnhandledPromiseRejectionWarning: Error: Cannot find module 'request'
      > Require stack:
      > - /home/pi/MagicMirror/modules/MMM-UKTide/node_helper.js
      > - /home/pi/MagicMirror/js/app.js
      > - /home/pi/MagicMirror/js/electron.js
      > - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      >     at Module._resolveFilename (node:internal/modules/cjs/loader:1082:15)
      >     at n._resolveFilename (node:electron/js2c/browser_init:2:117457)
      >     at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
      >     at Module._load (node:internal/modules/cjs/loader:927:27)
      >     at f._load (node:electron/js2c/asar_bundle:2:13330)
      >     at Module.require (node:internal/modules/cjs/loader:1148:19)
      >     at require (node:internal/modules/cjs/helpers:110:18)
      >     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-UKTide/node_helper.js:12:15)
      >     at Module._compile (node:internal/modules/cjs/loader:1269:14)
      >     at Module._extensions..js (node:internal/modules/cjs/loader:1324:10)
      >     at Module.load (node:internal/modules/cjs/loader:1124:32)
      >     at Module._load (node:internal/modules/cjs/loader:965:12)
      >     at loadModule (/home/pi/MagicMirror/js/app.js:180:19)
      > (Use `electron --trace-warnings ...` to show where the warning was created)
      > [27.08.2023 16:24.35.151] [ERROR] (node:6501) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
        sdetweil @olitills
        @olitills said in MMM-UKTide - error on load:
        ) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
        see
