    How to use Yr as a weather provider
    12 Posts 3 Posters 2.6k Views 4 Watching
    • karsten13K Offline
      karsten13 @MajorC
      @MajorC
      see https://github.com/MichMich/MagicMirror-Documentation/pull/134/files
      will hopefully soon merged into official documentation (there are merge conflicts …)
      karsten13K 1 Reply Last reply Reply Quote 1
        karsten13 @karsten13
        as follow up: That was merged today so you find it now in the offical documentation https://docs.magicmirror.builders/modules/weather.html#yr-options
          MajorC Project Sponsor @karsten13
          @karsten13
          My config looks like this:
          			module: "weather",
          				showHeader: true,
          				weatherProvider: "yr",
          				type: "current",
          				lat: "52.5544",
          				lon: "13.4635",
          				roundTemp: true,
          But the mirror only says “loading…” all the time.
          Any ideas how to deal with that? I use MM v2.24.0
            sdetweil @MajorC
            @MajorC said in How to use Yr as a weather provider:
              		type: "current",
              		lat: "52.5544",
              		lon: "13.4635",
            numbers and true/false do not use quotes…
            open the developers window, ctrl-shift-i on the MM page,
            select the console tab and put,
            wea
            in the filter field to see only messages from the weather module
              MajorC Project Sponsor @sdetweil
              @sdetweil you are absolute right. But still:
              yr.js:311 Could not load weather data. SyntaxError: Unexpected non-whitespace character after JSON at position 4 (line 1 column 5)
                  at JSON.parse (<anonymous>)
                  at performWebRequest (utils.js:27:29)
              (anonymous) @ yr.js:311
              Promise.catch (async)
              getStellarDataFromYr @ yr.js:310
              getStellarDataFromYrOrCache @ yr.js:268
              (anonymous) @ yr.js:231
              getStellarData @ yr.js:213
              getCurrentWeather @ yr.js:47
              fetchCurrentWeather @ yr.js:35
              (anonymous) @ weather.js:190
              setTimeout (async)
              scheduleUpdate @ weather.js:187
              start @ weather.js:99
              startModules @ loader.js:25
              loadNextModule @ loader.js:218
              await in loadNextModule (async)
              loadNextModule @ loader.js:211
              loadModules @ loader.js:221
              init @ main.js:471
              await in init (async)
              (anonymous) @ main.js:593
              yr.js:285 Error: SyntaxError: Unexpected non-whitespace character after JSON at position 4 (line 1 column 5)
                  at yr.js:312:11
              (anonymous) @ yr.js:285
              getStellarDataFromYrOrCache @ yr.js:284
              setTimeout (async)
              init @ main.js:471
              yr.js:41 Unable to get stellar data from Yr.
              (anonymous) @ yr.js:41
              fetchCurrentWeather @ yr.js:40
              setTimeout (async)
              init @ main.js:471
              yr.js:42 Uncaught (in promise) Error: Unable to get stellar data from Yr.
                  at yr.js:42:11
              with config:
              			module: "weather",
              				showHeader: true,
              				type: "current",
              				lat: 52.5544,
              				lon: 13.4635,
              				//roundTemp: true
              ![alt text](c76fa3d6-3ee0-4a86-af34-ab263cea8040-image.png image url)
                sdetweil @MajorC
                @MajorC the api returned data the module did not expect and did not handle the error…
                the exact cause of the error is unknown as the code did not report it…
                i have seen quite a lot of sloppy api programming lately…
                the rules are pretty clear
                rc=200 means all good
                other errors 300/400/500 families provide specific info
                but a lot of apis return 200 even for error cases and THEN the code has to decode the TEXT of the ‘good’ data message…
                sloppy, lazy…
                because the error calls out an ‘unexpected non-whitepace’ (a colon maybe) , I suspect this api is one of these
                  @sdetweil so I have to use an other weather provider? I really like Yr. They are very precise for Europe.
                    sdetweil @MajorC
                    @MajorC not what I said… its broken as you are using it, but I don’t know why. I am not the provider author… you can post an issue to the MM github page…
                      karsten13 @sdetweil
                      see https://github.com/MichMich/MagicMirror/issues/3189
                      yr has changed api, the fix comes with next release on Oct.
                        sdetweil @karsten13
                        @karsten13 thanks, gotta start checking the changelog .
