    Errors after Update
    16 Posts 2 Posters 5.2k Views 2 Watching
      JoeFranz
      Re: Upgrade errors?
      Nothing has worked for me since the update.
      I updated the mirror with the update script from sdetweil.
      Can someone help?
      Joe
      pi@raspberrypi:~/MagicMirror $ pm2 logs MagicMirror
      [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
      0|MagicMir | [02.10.2023 17:12.44.449] [ERROR] TypeError: Cannot read properties of undefined (reading ‘on’)
      0|MagicMir | at Object. (/home/pi/MagicMirror/js/electron.js:139:5)
      0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1241:14)
      0|MagicMir | at Module._extensions…js (node:internal/modules/cjs/loader:1295:10)
      0|MagicMir | at Module.load (node:internal/modules/cjs/loader:1091:32)
      0|MagicMir | at Module._load (node:internal/modules/cjs/loader:938:12)
      0|MagicMir | at Object. (/usr/lib/node_modules/pm2/lib/ProcessContainerFork.js:33:23)
      0|MagicMir | at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:83:12)
      0|MagicMir | at node:internal/main/run_main_module:23:47
      0|MagicMir | [02.10.2023 17:12.44.452] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [02.10.2023 17:12.44.454] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        sdetweil @JoeFranz
        @JoeFranz note that the script tries to install node 20… which seems to have changed the process…
        see the script at the top of the scripts page and see if that helps…
        we know that rpi buster has a problem… not yet solved … I am working on it…
        lsb_release -a
        will tell you what OS release u are on
          JoeFranz @sdetweil
          @sdetweil said in Errors after Update:
          lsb_release -a
          Distributor ID: Raspbian
          Description: Raspbian GNU/Linux 11 (bullseye)
          Release: 11
          Codename: bullseye
          I ran the script, the error remains.
            sdetweil @JoeFranz
            @JoeFranz can you do
            pm2 logs --lines=50
            the logs is short above the error
              JoeFranz @sdetweil
              /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
              0|MagicMir | [02.10.2023 17:27.58.805] [ERROR] Whoops! There was an uncaught exception…
              0|MagicMir | [02.10.2023 17:27.58.807] [ERROR] TypeError: Cannot read properties of undefined (reading ‘on’)
              0|MagicMir | [02.10.2023 17:27.58.810] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              0|MagicMir | [02.10.2023 17:27.58.812] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              0|MagicMir | [02.10.2023 17:28.02.795] [ERROR] TypeError: Cannot read properties of undefined (reading ‘on’)
              0|MagicMir | [02.10.2023 17:28.02.811] [ERROR] Whoops! There was an uncaught exception…
              0|MagicMir | [02.10.2023 17:28.02.814] [ERROR] TypeError: Cannot read properties of undefined (reading ‘on’)
              0|MagicMir | [02.10.2023 17:28.02.819] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              0|MagicMir | [02.10.2023 17:28.02.822] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                sdetweil @JoeFranz
                @JoeFranz ok, do this
                pm2 stop all
                npm start
                does it still fail?
                  JoeFranz @sdetweil
                  pm2 stop all
                  npm start
                  magicmirror@2.25.0 start
                  [02.10.2023 17:48.18.730] [LOG] Starting MagicMirror: v2.25.0
                  [02.10.2023 17:48.18.752] [LOG] Loading config …
                  [02.10.2023 17:48.18.762] [DEBUG] config template file not exists, no envsubst
                  [02.10.2023 17:48.21.067] [ERROR] (node:8240) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘html-to-text’
                  Require stack:
                  • /home/pi/MagicMirror/modules/default/newsfeed/newsfeedfetcher.js
                  • /home/pi/MagicMirror/modules/default/newsfeed/node_helper.js
                  • at Module._resolveFilename (node:internal/modules/cjs/loader:963:15)
                    at n._resolveFilename (node:electron/js2c/browser_init:2:109751)
                    at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                    at Module._load (node:internal/modules/cjs/loader:811:27)
                    at f._load (node:electron/js2c/asar_bundle:2:13330)
                    at Module.require (node:internal/modules/cjs/loader:1035:19)
                    at require (node:internal/modules/cjs/helpers:102:18)
                    at Object. (/home/pi/MagicMirror/modules/default/newsfeed/newsfeedfetcher.js:11:24)
                    at Module._compile (node:internal/modules/cjs/loader:1141:14)
                    at Module._extensions…js (node:internal/modules/cjs/loader:1196:10)
                    at Module.load (node:internal/modules/cjs/loader:1011:32)
                    at Module._load (node:internal/modules/cjs/loader:846:12)
                    at Object. (/home/pi/MagicMirror/modules/default/newsfeed/node_helper.js:10:25)
                    (Use electron --trace-warnings ... to show where the warning was created)
                    [02.10.2023 17:48.21.071] [ERROR] (node:8240) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                    [8292:1002/174823.865854:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                    [8319:1002/174824.432604:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                    sdetweil @JoeFranz
                    @JoeFranz said in Errors after Update:
                    ok… in the mm folder do
                    npm install html-to-text
                    then try again
                    but it sounds like the npm install of the upgrade failed…
                    which would have happened if the node 20 install failed
                    so you have to fix the node 20 install (with the other script)
                    and THEN
                    rm -rf node_modules
                    npm run install-mm
                      JoeFranz @sdetweil
                      pi@raspberrypi:~ $ pm2 stop all
                      npm start
                      [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                      [PM2] [MagicMirror](0) ✓
                      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                      │ 0  │ MagicMirror        │ fork     │ 277  │ stopped   │ 0%       │ 0b       │
                      [02.10.2023 18:05.06.957] [LOG]   Starting MagicMirror: v2.25.0
                      [02.10.2023 18:05.06.967] [LOG]   Loading config ...
                      [02.10.2023 18:05.06.972] [DEBUG] config template file not exists, no envsubst
                      [02.10.2023 18:05.07.048] [ERROR] (node:11262) UnhandledPromiseRejectionWarning: Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                      was compiled against a different Node.js version using
                      NODE_MODULE_VERSION 110. This version of Node.js requires
                      NODE_MODULE_VERSION 116. Please try re-compiling or re-installing
                      the module (for instance, using `npm rebuild` or `npm install`).
                          at process.func [as dlopen] (node:electron/js2c/asar_bundle:2:2131)
                          at Object.<anonymous> (node:internal/modules/cjs/loader:1356:18)
                          at Object.func [as .node] (node:electron/js2c/asar_bundle:2:2131)
                          at Module.load (node:internal/modules/cjs/loader:1126:32)
                          at node:internal/modules/cjs/loader:967:12
                          at Function._load (node:electron/js2c/asar_bundle:2:13327)
                          at Module.require (node:internal/modules/cjs/loader:1150:19)
                          at require (node:internal/modules/cjs/helpers:110:18)
                          at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:112:48)
                          at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:7:31
                          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:15:3)
                          at Module._compile (node:internal/modules/cjs/loader:1271:14)
                          at Object..js (node:internal/modules/cjs/loader:1326:10)
                      (Use `electron --trace-warnings ...` to show where the warning was created)
                      [02.10.2023 18:05.07.050] [ERROR] (node:11262) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                      [11301:1002/180508.559663:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                      [11262:1002/180508.753264:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                      [11329:1002/180509.789629:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                      [11354:1002/180512.079821:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        sdetweil @JoeFranz
                        @JoeFranz yeh, thats all the stuff my upgrade script takes care of…
                        but node 20 is a mess
                        node 18 on buster doesn’t install
                        apt get update
                        sets up to install node 20.5.1…
                          sdetweil @JoeFranz
                          @JoeFranz try the upgrade script again, with force instead of apply
                          it will remove and and add the right version of node the right way, including on buster
                          please advise your results…
                            JoeFranz @sdetweil
                            @sdetweil how do I do the update by force?
                              sdetweil @JoeFranz
                              @JoeFranz you copy/paste the upgrade apply command string
                              and change apply to force
                              all the commands are copy paste so you don’t need to download anything
                                JoeFranz @sdetweil
                                @sdetweil ```
                                [02.10.2023 21:29.49.912] [LOG] Starting MagicMirror: v2.25.0
                                [02.10.2023 21:29.49.922] [LOG] Loading config …
                                [02.10.2023 21:29.49.928] [DEBUG] config template file not exists, no envsubst
                                [02.10.2023 21:29.51.691] [ERROR] (node:7976) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘node-fetch’
                                Require stack:
                                • /home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js
                                • at node:internal/modules/cjs/loader:1084:15
                                  at Function. (node:electron/js2c/browser_init:2:117419)
                                  at node:internal/modules/cjs/loader:929:27
                                  at Object. (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:10:15)
                                  at Object…js (node:internal/modules/cjs/loader:1326:10)
                                  at loadModule (/home/pi/MagicMirror/js/app.js:180:19)
                                  [02.10.2023 21:29.51.693] [ERROR] (node:7976) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                                  [7976:1002/212952.276668:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                                  [8016:1002/212953.559582:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                                  sdetweil @JoeFranz
                                  see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
                                    JoeFranz @sdetweil
                                    @sdetweil The mirror lives again!! Thank you! :-)
                                    There are still errors in two modules, soccer-live-score and newsfeed
                                    I’ll take a look at that tomorrow
                                    Good job thanks
