    MM does not start - Cannot find module 'html-to-text'
    14 Posts 2 Posters 2.4k Views 3 Watching
    • K Offline
      Klinge
      currently my MM does not start. When I start with “DISPLAY=:0 npm start” I get the following error message.
      [04.10.2023 07:00.37.670] [LOG]   Starting MagicMirror: v2.25.0
      [04.10.2023 07:00.37.696] [LOG]   Loading config ...
      [04.10.2023 07:00.37.726] [DEBUG] config template file not exists, no envsubst
      [04.10.2023 07:00.37.737] [LOG]   Loading module helpers ...
      [04.10.2023 07:00.37.739] [LOG]   No helper found for module: alert.
      [04.10.2023 07:00.37.780] [LOG]   Initializing new module helper ...
      [04.10.2023 07:00.37.783] [LOG]   Module helper loaded: updatenotification
      [04.10.2023 07:00.37.786] [LOG]   No helper found for module: clock.
      [04.10.2023 07:00.37.900] [LOG]   Initializing new module helper ...
      [04.10.2023 07:00.37.902] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
      [04.10.2023 07:00.38.275] [LOG]   Initializing new module helper ...
      [04.10.2023 07:00.38.278] [LOG]   Module helper loaded: calendar
      [04.10.2023 07:00.41.502] [LOG]   Initializing new module helper ...
      [04.10.2023 07:00.41.504] [LOG]   Module helper loaded: MMM-OnThisDay
      [04.10.2023 07:00.42.231] [LOG]   Initializing new module helper ...
      [04.10.2023 07:00.42.232] [LOG]   Module helper loaded: MMM-DWD-Pollen
      [04.10.2023 07:00.42.442] [LOG]   Initializing new module helper ...
      [04.10.2023 07:00.42.445] [LOG]   Module helper loaded: MMM-NINA
      [04.10.2023 07:00.42.624] [LOG]   Initializing new module helper ...
      [04.10.2023 07:00.42.626] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
      [04.10.2023 07:00.42.683] [ERROR] (node:1016) UnhandledPromiseRejectionWarning: Error: Cannot find module 'html-to-text'
      Require stack:
      - /home/pi/MagicMirror/modules/default/newsfeed/newsfeedfetcher.js
      - /home/pi/MagicMirror/modules/default/newsfeed/node_helper.js
          at Module._resolveFilename (node:internal/modules/cjs/loader:963:15)
          at n._resolveFilename (node:electron/js2c/browser_init:2:109751)
          at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (node:internal/modules/cjs/loader:811:27)
          at f._load (node:electron/js2c/asar_bundle:2:13330)
          at Module.require (node:internal/modules/cjs/loader:1035:19)
          at require (node:internal/modules/cjs/helpers:102:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/newsfeed/newsfeedfetcher.js:11:24)
          at Module._compile (node:internal/modules/cjs/loader:1141:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1196:10)
          at Module.load (node:internal/modules/cjs/loader:1011:32)
          at Module._load (node:internal/modules/cjs/loader:846:12)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/newsfeed/node_helper.js:10:25)
      (Use `electron --trace-warnings ...` to show where the warning was created)
      [04.10.2023 07:00.42.685] [ERROR] (node:1016) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
      [1050:1004/070043.971548:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      [1062:1004/070044.211988:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
      ^C/home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      Unfortunately I could not find anything about this problem in this forum.
      It would be really nice if someone could help me.
      Thank you in advance.
      Kind regards
        sdetweil @Klinge
        @Klinge sounds like you didn’t do the npm install
        do this
        npm run install-mm
        • K Offline
          Klinge @sdetweil
          @sdetweil Thank you for your answer.
          Unfortunately it does not work.
          pi@raspberrypi:~/MagicMirror $ npm run install-mm
          > magicmirror@2.25.0 install-mm /home/pi/MagicMirror
          > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
          npm ERR! code ENOTSUP
          npm ERR! notsup Unsupported engine for magicmirror@2.25.0: wanted: {"node":">=18"} (current: {"node":"10.24.1","npm":"6.14.12"})
          npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.25.0
          npm ERR! notsup Required: {"node":">=18"}
          npm ERR! notsup Actual:   {"npm":"6.14.12","node":"10.24.1"}
          npm ERR!     /home/pi/.npm/_logs/2023-10-04T12_58_48_289Z-debug.log
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! magicmirror@2.25.0 install-mm: `npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.25.0 install-mm script.
          npm ERR!     /home/pi/.npm/_logs/2023-10-04T12_58_48_449Z-debug.log
          After that it crushed with the same error like in my first post.
          Could it be that npm is not compatible to the MM version?
          Thank you.
            sdetweil @Klinge
            @Klinge u need to be at node 18 at least…
            run my upgrade script
            note that update is a 2 part process…
            1. test, no changes,
            2. apply
            use force instead of apply , on the apply command
            K 1 Reply Last reply Reply Quote 1
            • K Offline
              Klinge @sdetweil
              @sdetweil Ok, I installed and executed your update script
              pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
              Paketlisten werden gelesen... Fertig
              Abhängigkeitsbaum wird aufgebaut.
              Statusinformationen werden eingelesen.... Fertig
              Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
                point-rpi
              Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
              Die folgenden Pakete werden ENTFERNT:
                nodejs*
              0 aktualisiert, 0 neu installiert, 1 zu entfernen und 439 nicht aktualisiert.
              Nach dieser Operation werden 177 MB Plattenplatz freigegeben.
              (Lese Datenbank ... 99530 Dateien und Verzeichnisse sind derzeit installiert.)
              Entfernen von nodejs (18.18.0-1nodesource1) ...
              dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules« nicht leer, wird daher nicht gelöscht
              Trigger für man-db (2.8.5-2) werden verarbeitet ...
              OK:1 http://archive.raspberrypi.org/debian buster InRelease
              OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
              ca-certificates ist schon die neueste Version (20200601~deb10u2).
              curl ist schon die neueste Version (7.64.0-4+deb10u6).
              gnupg ist schon die neueste Version (2.2.12-1+rpi1+deb10u1).
                point-rpi
              0 aktualisiert, 0 neu installiert, 0 zu entfernen und 439 nicht aktualisiert.
              deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
              Holen:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12,1 kB]
              Holen:4 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5.267 B]
              Es wurden 17,4 kB in 1 s geholt (12,6 kB/s).
                point-rpi
              Die folgenden NEUEN Pakete werden installiert:
                nodejs
              0 aktualisiert, 1 neu installiert, 0 zu entfernen und 439 nicht aktualisiert.
              Es müssen noch 0 B von 26,8 MB an Archiven heruntergeladen werden.
              Nach dieser Operation werden 177 MB Plattenplatz zusätzlich benutzt.
              Vormals nicht ausgewähltes Paket nodejs wird gewählt.
              (Lese Datenbank ... 93906 Dateien und Verzeichnisse sind derzeit installiert.)
              Vorbereitung zum Entpacken von .../nodejs_18.18.0-1nodesource1_armhf.deb ...
              Entpacken von nodejs (18.18.0-1nodesource1) ...
              nodejs (18.18.0-1nodesource1) wird eingerichtet ...
              doing test run = false
              Minimum Node version: v18.18.0
              Installed Node version: v18.18.0
              No Node.js upgrade necessary.
              Minimum npm version: V9.8.1
              Installed npm version: V9.8.1
              No npm upgrade necessary.
              upgrading from version 2.25.0 to 2.25.0
              fetching latest revisions
              > magicmirror@2.25.0 postinstall
              > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
              > magicmirror@2.25.0 install-vendor
              > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
              added 1 package, and changed 3 packages in 25s
              > magicmirror@2.25.0 install-fonts
              > echo "Installing fonts ...
              > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
              changed 2 packages in 9s
              > magicmirror@2.25.0 prepare
              > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
              no husky installed.
              added 334 packages in 5m
              97 packages are looking for funding
                run `npm fund` for details
              npm notice
              npm notice New major version of npm available! 9.8.1 -> 10.2.0
              npm notice Changelog: <https://github.com/npm/cli/releases/tag/v10.2.0>
              npm notice Run `npm install -g npm@10.2.0` to update!
              npm notice
              processing for module MMM-OpenWeatherMapForecast please wait
              added 7 packages, and audited 8 packages in 14s
              found 0 vulnerabilities
              processing complete for module MMM-OpenWeatherMapForecast
              processing for module MMM-OnThisDay please wait
              npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
              npm WARN deprecated har-validator@5.1.3: this library is no longer supported
              npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
              added 99 packages, and audited 100 packages in 25s
              2 packages are looking for funding
              8 vulnerabilities (7 moderate, 1 high)
              To address all issues, run:
                npm audit fix
              Run `npm audit` for details.
              processing complete for module MMM-OnThisDay
              processing for module MMM-DWD-Pollen please wait
              added 47 packages, and audited 48 packages in 8s
              2 moderate severity vulnerabilities
              Some issues need review, and may require choosing
              a different dependency.
              processing complete for module MMM-DWD-Pollen
              processing for module MMM-NINA please wait
              added 4 packages, and audited 5 packages in 4s
              processing complete for module MMM-NINA
              processing for module MMM-DWD-WarnWeather please wait
              added 47 packages, and audited 48 packages in 7s
              processing complete for module MMM-DWD-WarnWeather
              but unfortunately it does not start again
              When the MM start the following error message occur
              pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
              > magicmirror@2.25.0 start
              [04.10.2023 17:08.09.512] [LOG]   Starting MagicMirror: v2.25.0
              [04.10.2023 17:08.09.521] [LOG]   Loading config ...
              [04.10.2023 17:08.09.531] [DEBUG] config template file not exists, no envsubst
              [04.10.2023 17:08.09.547] [LOG]   Loading module helpers ...
              [04.10.2023 17:08.09.550] [LOG]   No helper found for module: alert.
              [04.10.2023 17:08.09.612] [LOG]   Initializing new module helper ...
              [04.10.2023 17:08.09.613] [LOG]   Module helper loaded: updatenotification
              [04.10.2023 17:08.09.615] [LOG]   No helper found for module: clock.
              [04.10.2023 17:08.09.714] [LOG]   Initializing new module helper ...
              [04.10.2023 17:08.09.716] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
              [04.10.2023 17:08.10.146] [LOG]   Initializing new module helper ...
              [04.10.2023 17:08.10.147] [LOG]   Module helper loaded: calendar
              [04.10.2023 17:08.13.995] [LOG]   Initializing new module helper ...
              [04.10.2023 17:08.13.997] [LOG]   Module helper loaded: MMM-OnThisDay
              [04.10.2023 17:08.14.646] [LOG]   Initializing new module helper ...
              [04.10.2023 17:08.14.647] [LOG]   Module helper loaded: MMM-DWD-Pollen
              [04.10.2023 17:08.14.808] [LOG]   Initializing new module helper ...
              [04.10.2023 17:08.14.809] [LOG]   Module helper loaded: MMM-NINA
              [04.10.2023 17:08.14.831] [ERROR] (node:17281) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-fetch'
              Require stack:
              - /home/pi/MagicMirror/modules/MMM-DWD-WarnWeather/node_helper.js
                  at node:internal/modules/cjs/loader:1084:15
                  at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                  at node:internal/modules/cjs/loader:929:27
                  at Function._load (node:electron/js2c/asar_bundle:2:13327)
                  at Module.require (node:internal/modules/cjs/loader:1150:19)
                  at require (node:internal/modules/cjs/helpers:110:18)
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DWD-WarnWeather/node_helper.js:12:15)
                  at Module._compile (node:internal/modules/cjs/loader:1271:14)
                  at Object..js (node:internal/modules/cjs/loader:1326:10)
                  at Module.load (node:internal/modules/cjs/loader:1126:32)
                  at node:internal/modules/cjs/loader:967:12
                  at loadModule (/home/pi/MagicMirror/js/app.js:180:19)
              [04.10.2023 17:08.14.833] [ERROR] (node:17281) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
              [17281:1004/170815.752475:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
              [17316:1004/170817.472544:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                sdetweil @Klinge
                @Klinge said in MM does not start - Cannot find module 'html-to-text':
                there is a fix for this module
                go to its folder and do
                git pull
                npm install
                then restart MagicMirror
                K 2 Replies Last reply Reply Quote 0
                • K Offline
                  Klinge @sdetweil
                  @sdetweil Yes, that´s it. Now it runs again.
                  Thank you very much!
                  I wish you a nice day :-)
                  • K Offline
                    Klinge @sdetweil
                    @sdetweil Sorry, but now I have a new problem.
                    Now my MM restart every one to two minutes.
                    Maybe it is nice to know. Before I installed your update script I realized an autostart via pm2.
                    Sorry, but it would be nice if you could help me again.
                    Thank you.
                      sdetweil @Klinge
                      @Klinge pm2 logs --lines=50
                      show the output
                      • K Offline
                        Klinge @sdetweil
                        @sdetweil Ok, here it is
                        pi@raspberrypi:~ $ pm2 logs --lines=50
                        [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
                        /home/pi/.pm2/pm2.log last 50 lines:
                        PM2        |     at WriteStream.emit (node:events:517:28)
                        PM2        |     at WriteStream.emit (node:domain:552:15)
                        PM2        |     at node:internal/fs/streams:75:16
                        PM2        |     at FSReqCallback.oncomplete (node:fs:200:23)
                        PM2        | 2023-10-04T18:15:52: PM2 log: App [mm:0] online
                        PM2        | 2023-10-04T18:17:17: PM2 log: pm2 has been killed by signal, dumping process list before exit...
                        PM2        | 2023-10-04T18:17:17: PM2 log: Deleting process 0
                        PM2        | 2023-10-04T18:17:17: PM2 log: Stopping app:mm id:0
                        PM2        | 2023-10-04T18:17:17: PM2 log: App [mm:0] exited with code [0] via signal [SIGTERM]
                        PM2        | 2023-10-04T18:17:17: PM2 log: pid=8252 msg=process killed
                        PM2        | 2023-10-04T18:17:17: PM2 log: Exited peacefully
                        PM2        | 2023-10-04T18:17:22: PM2 error: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received type number (8523)
                        PM2        |     at Object.writeFileSync (node:fs:2314:5)
                        PM2        |     at Daemon.innerStart (/usr/lib/node_modules/pm2/lib/Daemon.js:89:8)
                        PM2        |     at Domain.<anonymous> (/usr/lib/node_modules/pm2/lib/Daemon.js:62:10)
                        PM2        |     at Domain.run (node:domain:389:15)
                        PM2        |     at Daemon.start (/usr/lib/node_modules/pm2/lib/Daemon.js:61:5)
                        PM2        |     at Object.<anonymous> (/usr/lib/node_modules/pm2/lib/Daemon.js:453:10)
                        PM2        |     at Module._compile (node:internal/modules/cjs/loader:1256:14)
                        PM2        |     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                        PM2        |     at Module.load (node:internal/modules/cjs/loader:1119:32)
                        PM2        |     at Module._load (node:internal/modules/cjs/loader:960:12)
                        PM2        | 2023-10-04T18:17:23: PM2 log: ===============================================================================
                        PM2        | 2023-10-04T18:17:23: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                        PM2        | 2023-10-04T18:17:23: PM2 log: Time                 : Wed Oct 04 2023 18:17:23 GMT+0200 (Mitteleuropäische Sommerzeit)
                        PM2        | 2023-10-04T18:17:23: PM2 log: PM2 version          : 4.1.2
                        PM2        | 2023-10-04T18:17:23: PM2 log: Node.js version      : 18.18.0
                        PM2        | 2023-10-04T18:17:23: PM2 log: Current arch         : arm
                        PM2        | 2023-10-04T18:17:23: PM2 log: PM2 home             : /home/pi/.pm2
                        PM2        | 2023-10-04T18:17:23: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                        PM2        | 2023-10-04T18:17:23: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                        PM2        | 2023-10-04T18:17:23: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                        PM2        | 2023-10-04T18:17:23: PM2 log: Application log path : /home/pi/.pm2/logs
                        PM2        | 2023-10-04T18:17:23: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                        PM2        | 2023-10-04T18:17:23: PM2 log: Concurrent actions   : 2
                        PM2        | 2023-10-04T18:17:23: PM2 log: SIGTERM timeout      : 1600
                        PM2        | 2023-10-04T18:17:23: PM2 log: App [mm:0] starting in -fork mode-
                        PM2        | 2023-10-04T18:17:23: PM2 error: TypeError [ERR_INVALID_ARG_TYPE]: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received type number (8534)
                        PM2        |     at /usr/lib/node_modules/pm2/lib/God/ForkMode.js:258:12
                        PM2        |     at wrapper (/usr/lib/node_modules/pm2/node_modules/async/internal/once.js:12:16)
                        PM2        |     at next (/usr/lib/node_modules/pm2/node_modules/async/waterfall.js:96:20)
                        PM2        |     at /usr/lib/node_modules/pm2/node_modules/async/internal/onlyOnce.js:12:16
                        PM2        |     at WriteStream.<anonymous> (/usr/lib/node_modules/pm2/lib/Utility.js:186:13)
                        PM2        | 2023-10-04T18:17:23: PM2 log: App [mm:0] online
                        /home/pi/.pm2/logs/mm-error.log last 50 lines:
                        0|mm       | [5855:1004/175718.120837:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        0|mm       | [5861:1004/175718.510133:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                        0|mm       | [04.10.2023 17:58.46.910] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        0|mm       | [6032:1004/175847.776473:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                        0|mm       | [6065:1004/175848.920978:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        0|mm       | [6071:1004/175849.241379:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                        0|mm       | [04.10.2023 18:00.17.672] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        0|mm       | [6267:1004/180018.583887:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                        0|mm       | [6300:1004/180019.572846:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        0|mm       | [6306:1004/180019.869359:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                        0|mm       | [04.10.2023 18:01.55.338] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        0|mm       | [6484:1004/180156.182863:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                        0|mm       | [6517:1004/180157.230654:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        0|mm       | [6523:1004/180157.517864:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                        0|mm       | [04.10.2023 18:03.41.690] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        0|mm       | [6748:1004/180342.596450:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                        0|mm       | [6782:1004/180343.590529:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        0|mm       | [6789:1004/180343.906253:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                        0|mm       | [04.10.2023 18:05.13.048] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        0|mm       | [6958:1004/180513.984383:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                        0|mm       | [6992:1004/180514.960583:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        0|mm       | [6998:1004/180515.244798:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                        0|mm       | [04.10.2023 18:07.56.767] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        0|mm       | [7179:1004/180757.724734:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                        0|mm       | [7235:1004/180758.509746:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        0|mm       | [7247:1004/180758.777018:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                        0|mm       | [04.10.2023 18:09.34.194] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        0|mm       | [7416:1004/180935.131361:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                        0|mm       | [7448:1004/180936.160496:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        0|mm       | [7455:1004/180936.436592:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                        0|mm       | [04.10.2023 18:11.05.471] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        0|mm       | [7625:1004/181106.474886:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                        0|mm       | [7656:1004/181107.269802:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        0|mm       | [7670:1004/181107.574314:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                        0|mm       | [04.10.2023 18:12.40.548] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        0|mm       | [7843:1004/181241.470196:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                        0|mm       | [7876:1004/181242.409833:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        0|mm       | [7883:1004/181242.738127:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                        0|mm       | [04.10.2023 18:14.11.405] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        0|mm       | [8059:1004/181412.295277:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                        0|mm       | [8092:1004/181413.340008:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        0|mm       | [8098:1004/181413.652866:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                        0|mm       | [04.10.2023 18:16.04.369] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        0|mm       | [8276:1004/181605.210320:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                        0|mm       | [8309:1004/181606.250563:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        0|mm       | [8315:1004/181606.535078:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                        0|mm       | [04.10.2023 18:17.36.219] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        0|mm       | [8561:1004/181737.160188:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                        0|mm       | [8596:1004/181738.109901:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        0|mm       | [8602:1004/181738.404887:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                        /home/pi/.pm2/logs/mm-out.log last 50 lines:
                        0|mm       | [04.10.2023 18:17.30.568] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
                        0|mm       | [04.10.2023 18:17.30.933] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 18:17.30.935] [LOG]   Module helper loaded: calendar
                        0|mm       | [04.10.2023 18:17.34.910] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 18:17.34.912] [LOG]   Module helper loaded: MMM-OnThisDay
                        0|mm       | [04.10.2023 18:17.35.609] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 18:17.35.610] [LOG]   Module helper loaded: MMM-DWD-Pollen
                        0|mm       | [04.10.2023 18:17.35.805] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 18:17.35.805] [LOG]   Module helper loaded: MMM-NINA
                        0|mm       | [04.10.2023 18:17.35.898] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 18:17.35.899] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
                        0|mm       | [04.10.2023 18:17.36.182] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 18:17.36.183] [LOG]   Module helper loaded: newsfeed
                        0|mm       | [04.10.2023 18:17.36.184] [LOG]   All module helpers loaded.
                        0|mm       | [04.10.2023 18:17.36.208] [LOG]   Starting server on port 8080 ...
                        0|mm       | [04.10.2023 18:17.36.247] [LOG]   Server started ...
                        0|mm       | [04.10.2023 18:17.36.251] [LOG]   Connecting socket for: updatenotification
                        0|mm       | [04.10.2023 18:17.36.254] [LOG]   Starting module helper: updatenotification
                        0|mm       | [04.10.2023 18:17.36.257] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
                        0|mm       | [04.10.2023 18:17.36.260] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast]
                        0|mm       | [04.10.2023 18:17.36.262] [LOG]   Connecting socket for: calendar
                        0|mm       | [04.10.2023 18:17.36.265] [LOG]   Starting node helper for: calendar
                        0|mm       | [04.10.2023 18:17.36.267] [LOG]   Connecting socket for: MMM-OnThisDay
                        0|mm       | [04.10.2023 18:17.36.269] [LOG]   Starting module helper: MMM-OnThisDay
                        0|mm       | [04.10.2023 18:17.36.271] [LOG]   Connecting socket for: MMM-DWD-Pollen
                        0|mm       | [04.10.2023 18:17.36.272] [LOG]   MMM-DWD-Pollen helper started ...
                        0|mm       | [04.10.2023 18:17.36.273] [LOG]   Connecting socket for: MMM-NINA
                        0|mm       | [04.10.2023 18:17.36.274] [LOG]   MMM-NINA helper method started...
                        0|mm       | [04.10.2023 18:17.36.275] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
                        0|mm       | [04.10.2023 18:17.36.276] [LOG]   MMM-DWD-WarnWeather helper started...
                        0|mm       | [04.10.2023 18:17.36.277] [LOG]   Connecting socket for: newsfeed
                        0|mm       | [04.10.2023 18:17.36.278] [LOG]   Starting node helper for: newsfeed
                        0|mm       | [04.10.2023 18:17.36.280] [LOG]   Sockets connected & modules started ...
                        0|mm       | [04.10.2023 18:17.36.828] [LOG]   Launching application.
                        0|mm       | [04.10.2023 18:17.42.028] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/lars.klingeberg%40gmail.com/private-8cbcc08f4b0fa124985428c70478a278/basic.ics - Interval: 3600000
                        0|mm       | [04.10.2023 18:17.42.369] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/daniela.silbernagel%40gmail.com/private-88e7d28377f0b505f184b5413a231bb7/basic.ics - Interval: 3600000
                        0|mm       | [04.10.2023 18:17.42.500] [LOG]   requesting:https://opendata.dwd.de/climate_environment/health/alerts/s31fg.json
                        0|mm       | [04.10.2023 18:17.42.557] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                        0|mm       | [04.10.2023 18:17.42.584] [LOG]   MMM-OnThisDay: Received socket notification LOAD_EVENTS.
                        0|mm       | [04.10.2023 18:17.42.587] [LOG]   MMM-OnThisDay: Load events ...
                        0|mm       | [04.10.2023 18:17.42.610] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
                        0|mm       | [04.10.2023 18:17.42.704] [INFO]  Checking git for module: MMM-OnThisDay
                        0|mm       | [04.10.2023 18:17.42.769] [INFO]  Checking git for module: MMM-DWD-Pollen
                        0|mm       | [04.10.2023 18:17.43.047] [INFO]  Checking git for module: MMM-NINA
                        0|mm       | [04.10.2023 18:17.43.124] [LOG]   MMM-DWD-Pollen: Success loading
                        0|mm       | [04.10.2023 18:17.43.205] [INFO]  Checking git for module: MMM-DWD-WarnWeather
                        0|mm       | [04.10.2023 18:17.43.275] [INFO]  Checking git for module: MagicMirror
                        0|mm       | [04.10.2023 18:17.43.568] [LOG]   MMM-OnThisDay: Parse HTML data ...
                        0|mm       | [04.10.2023 18:17.46.721] [INFO]  Newsfeed-Fetcher: reloadInterval set to ttl=5400000 for url http://www.tagesschau.de/xml/rss2
                        0|mm       | [04.10.2023 18:17.47.876] [INFO]  Newsfeed-Fetcher: Broadcasting 40 items.
