    MMM-Remote-Control API and remote fails after V2.25.0 update
    21 Posts 3 Posters 5.7k Views 3 Watching
      sdetweil @rhbauman
      @rhbauman I don’t use this module, but if Karsten posts, then you listen. the
      node_fetch library was removed in this release.
      R 1 Reply Last reply
        rhbauman @sdetweil
        And if I post, please read it and think about what you are about to post before adding noise to the discussion. I am not seeing any error messages about missing modules and I am not getting a black screen.
        Perhaps you could load Remote-Control and let me know if you can duplicate my problem?
          sdetweil @rhbauman
          and came up on my phone
          my module config
              module: 'MMM-Remote-Control',
              // position: 'bottom_left',
                  customCommand: {},  // Optional, See "Using Custom Commands" below
                  showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                  secureEndpoints: true, // Optional, See API/README.md
                  // uncomment any of the lines below if you're gonna use it
                  // customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                  apiKey: "12345", // Optional, See API/README.md for details
                  // classes: {} // Optional, See "Custom Classes" below
          my top line mm config
          let config = {
          	address: "0.0.0.0",	// Address to listen on, can be:
          	port: 8090,
          	basePath: "/",			// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
          	ipWhitelist: [],	// Set [] to allow all IP addresses
            rhbauman
            Thanks! I’ll try using an apikey. That’s a difference between your configuration and mine.
              sdetweil @rhbauman
              @rhbauman it was the same before apiKey was uncommented…
              I was just trying to use a function that required a key… as well as the others.
                rhbauman
                Yeah, secureEndpoints made no difference for me. What’s your MM host, a Raspberry Pi? If so, are you running bullseye? And you’re running MM V2.25, right?
                  sdetweil @rhbauman
                  @rhbauman i installed on a pi3, pi4 and my linux desktop, all on node 18 or 20 all with the same module config (cut and paste)
                  buster and bullseye, all MM 2.25
                  and all worked.
                    rhbauman
                    Excellent. Then I’ve got some problem in my Pi environment. Thanks for the info and taking the time to try to duplicate the issue.
                      sdetweil @rhbauman
                      @rhbauman let us know how it works out…
                        rhbauman @sdetweil
                        OK. This masked the root problem: pm2 logs mm --lines 100 doesn’t show the same information as npm run start. From pm2 logs:
                        0|mm       | [04.10.2023 10:23.56.064] [LOG]   Loading config ...
                        0|mm       | [04.10.2023 10:23.56.071] [DEBUG] config template file not exists, no envsubst
                        0|mm       | [04.10.2023 10:23.56.081] [LOG]   Loading module helpers ...
                        0|mm       | [04.10.2023 10:23.56.084] [LOG]   No helper found for module: alert.
                        0|mm       | [04.10.2023 10:23.56.143] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 10:23.56.145] [LOG]   Module helper loaded: updatenotification
                        0|mm       | [04.10.2023 10:23.56.147] [LOG]   No helper found for module: clock.
                        0|mm       | [04.10.2023 10:23.56.511] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 10:23.56.513] [LOG]   Module helper loaded: calendar
                        0|mm       | [04.10.2023 10:23.56.516] [LOG]   No helper found for module: MMM-WeatherGraph.
                        0|mm       | [04.10.2023 10:23.56.765] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 10:23.56.766] [LOG]   Module helper loaded: MMM-Remote-Control
                        0|mm       | [04.10.2023 10:23.56.771] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 10:23.56.772] [LOG]   Module helper loaded: WallberryTheme
                        0|mm       | [04.10.2023 10:23.56.874] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 10:23.56.875] [LOG]   Module helper loaded: MMM-HomeAssistantDisplay
                        0|mm       | [04.10.2023 10:23.56.875] [LOG]   All module helpers loaded.
                        0|mm       | [04.10.2023 10:23.56.895] [LOG]   Starting server on port 8080 ...
                        0|mm       | [04.10.2023 10:23.56.934] [LOG]   Server started ...
                        0|mm       | [04.10.2023 10:23.56.937] [LOG]   Connecting socket for: updatenotification
                        0|mm       | [04.10.2023 10:23.56.938] [LOG]   Starting module helper: updatenotification
                        0|mm       | [04.10.2023 10:23.56.940] [LOG]   Connecting socket for: calendar
                        0|mm       | [04.10.2023 10:23.56.941] [LOG]   Starting node helper for: calendar
                        0|mm       | [04.10.2023 10:23.56.943] [LOG]   Connecting socket for: MMM-Remote-Control
                        0|mm       | [04.10.2023 10:23.56.944] [LOG]   Starting node helper for: MMM-Remote-Control
                        0|mm       | [04.10.2023 10:23.56.962] [LOG]   Connecting socket for: WallberryTheme
                        0|mm       | [04.10.2023 10:23.56.963] [LOG]   Starting module helper: WallberryTheme
                        0|mm       | [04.10.2023 10:23.56.964] [LOG]   Connecting socket for: MMM-HomeAssistantDisplay
                        0|mm       | [04.10.2023 10:23.56.966] [LOG]   Sockets connected & modules started ...
                        0|mm       | [04.10.2023 10:23.57.425] [LOG]   Launching application.
                        0|mm       | [04.10.2023 10:24.02.086] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 3600000
                        0|mm       | [04.10.2023 10:24.02.389] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/subergnc60%40gmail.com/private-aea673a8cf3f206ff493088e6bbdbda9/basic.ics - Interval: 3600000
                        0|mm       | [04.10.2023 10:24.02.512] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/ronbauman36%40gmail.com/private-4a25d5bf1c4accb1dce4e685fdcf2fcd/basic.ics - Interval: 3600000
                        0|mm       | [04.10.2023 10:24.03.547] [INFO]  [MMM-HomeAssistantDisplay] [ 'HomeAssistant connected for module_11_MMM-HomeAssistantDisplay' ]
                        0|mm       | [04.10.2023 10:24.03.597] [INFO]  Checking git for module: MMM-WeatherGraph
                        0|mm       | [04.10.2023 10:24.03.654] [LOG]   Electron's cache successfully cleared.
                        0|mm       | [04.10.2023 10:24.03.816] [INFO]  Checking git for module: MMM-Remote-Control
                        0|mm       | [04.10.2023 10:24.03.924] [INFO]  Checking git for module: WallberryTheme
                        0|mm       | [04.10.2023 10:24.04.045] [INFO]  Checking git for module: MMM-HomeAssistantDisplay
                        0|mm       | [04.10.2023 10:24.04.149] [INFO]  Checking git for module: MagicMirror
                        0|mm       | [04.10.2023 10:24.04.566] [INFO]  Calendar-Fetcher: Broadcasting 1 events from http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics.
                        0|mm       | [04.10.2023 10:24.04.794] [INFO]  [MMM-HomeAssistantDisplay] [
                        0|mm       |   'Conected to Home Assistant for module_11_MMM-HomeAssistantDisplay after 0 retries'
                        0|mm       | ]
                        0|mm       | [04.10.2023 10:24.09.117] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/ronbauman36%40gmail.com/private-4a25d5bf1c4accb1dce4e685fdcf2fcd/basic.ics.
                        0|mm       | [04.10.2023 10:24.11.480] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/subergnc60%40gmail.com/private-aea673a8cf3f206ff493088e6bbdbda9/basic.ics.
                        0|mm       | [04.10.2023 11:24.05.182] [INFO]  Calendar-Fetcher: Broadcasting 1 events from http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics.
                        0|mm       | [04.10.2023 11:24.11.829] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/ronbauman36%40gmail.com/private-4a25d5bf1c4accb1dce4e685fdcf2fcd/basic.ics.
                        0|mm       | [04.10.2023 11:24.13.950] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/subergnc60%40gmail.com/private-aea673a8cf3f206ff493088e6bbdbda9/basic.ics.
                        0|mm       |
                        0|mm       | > magicmirror@2.25.0 start
                        0|mm       | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                        0|mm       |
                        0|mm       | [04.10.2023 12:16.42.478] [LOG]   Starting MagicMirror: v2.25.0
                        0|mm       | [04.10.2023 12:16.42.491] [LOG]   Loading config ...
                        0|mm       | [04.10.2023 12:16.42.498] [DEBUG] config template file not exists, no envsubst
                        0|mm       | [04.10.2023 12:16.42.508] [LOG]   Loading module helpers ...
                        0|mm       | [04.10.2023 12:16.42.512] [LOG]   No helper found for module: alert.
                        0|mm       | [04.10.2023 12:16.42.570] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 12:16.42.572] [LOG]   Module helper loaded: updatenotification
                        0|mm       | [04.10.2023 12:16.42.574] [LOG]   No helper found for module: clock.
                        0|mm       | [04.10.2023 12:16.42.942] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 12:16.42.944] [LOG]   Module helper loaded: calendar
                        0|mm       | [04.10.2023 12:16.42.947] [LOG]   No helper found for module: MMM-WeatherGraph.
                        0|mm       | [04.10.2023 12:16.43.212] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 12:16.43.215] [LOG]   Module helper loaded: MMM-Remote-Control
                        0|mm       | [04.10.2023 12:16.43.220] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 12:16.43.221] [LOG]   Module helper loaded: WallberryTheme
                        0|mm       | [04.10.2023 12:16.43.349] [LOG]   Initializing new module helper ...
                        0|mm       | [04.10.2023 12:16.43.349] [LOG]   Module helper loaded: MMM-HomeAssistantDisplay
                        0|mm       | [04.10.2023 12:16.43.350] [LOG]   All module helpers loaded.
                        0|mm       | [04.10.2023 12:16.43.370] [LOG]   Starting server on port 8080 ...
                        0|mm       | [04.10.2023 12:16.43.412] [LOG]   Server started ...
                        0|mm       | [04.10.2023 12:16.43.414] [LOG]   Connecting socket for: updatenotification
                        0|mm       | [04.10.2023 12:16.43.416] [LOG]   Starting module helper: updatenotification
                        0|mm       | [04.10.2023 12:16.43.417] [LOG]   Connecting socket for: calendar
                        0|mm       | [04.10.2023 12:16.43.419] [LOG]   Starting node helper for: calendar
                        0|mm       | [04.10.2023 12:16.43.420] [LOG]   Connecting socket for: MMM-Remote-Control
                        0|mm       | [04.10.2023 12:16.43.422] [LOG]   Starting node helper for: MMM-Remote-Control
                        0|mm       | [04.10.2023 12:16.43.440] [LOG]   Connecting socket for: WallberryTheme
                        0|mm       | [04.10.2023 12:16.43.441] [LOG]   Starting module helper: WallberryTheme
                        0|mm       | [04.10.2023 12:16.43.442] [LOG]   Connecting socket for: MMM-HomeAssistantDisplay
                        0|mm       | [04.10.2023 12:16.43.444] [LOG]   Sockets connected & modules started ...
                        0|mm       | [04.10.2023 12:16.43.932] [LOG]   Launching application.
                        0|mm       | [04.10.2023 12:16.48.648] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 3600000
                        0|mm       | [04.10.2023 12:16.48.956] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/subergnc60%40gmail.com/private-aea673a8cf3f206ff493088e6bbdbda9/basic.ics - Interval: 3600000
                        0|mm       | [04.10.2023 12:16.50.033] [INFO]  [MMM-HomeAssistantDisplay] [ 'HomeAssistant connected for module_11_MMM-HomeAssistantDisplay' ]
                        0|mm       | [04.10.2023 12:16.50.062] [LOG]   Electron's cache successfully cleared.
                        0|mm       | [04.10.2023 12:16.50.122] [INFO]  Checking git for module: MMM-WeatherGraph
                        0|mm       | [04.10.2023 12:16.50.220] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/ronbauman36%40gmail.com/private-4a25d5bf1c4accb1dce4e685fdcf2fcd/basic.ics - Interval: 3600000
                        0|mm       | [04.10.2023 12:16.50.283] [INFO]  Checking git for module: MMM-Remote-Control
                        0|mm       | [04.10.2023 12:16.50.412] [INFO]  Checking git for module: WallberryTheme
                        0|mm       | [04.10.2023 12:16.50.560] [INFO]  Checking git for module: MMM-HomeAssistantDisplay
                        0|mm       | [04.10.2023 12:16.50.682] [INFO]  Checking git for module: MagicMirror
                        0|mm       | [04.10.2023 12:16.51.047] [INFO]  Calendar-Fetcher: Broadcasting 1 events from http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics.
                        0|mm       | [04.10.2023 12:16.51.265] [INFO]  [MMM-HomeAssistantDisplay] [
                        0|mm       | ]
                        0|mm       | [04.10.2023 12:16.56.265] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://calendar.google.com/calendar/ical/ronbauman36%40gmail.com/private-4a25d5bf1c4accb1dce4e685fdcf2fcd/basic.ics.
                        0|mm       | [04.10.2023 12:16.58.824] [INFO]  Calendar-Fetcher: Broadcasting 6 events from https://calendar.google.com/calendar/ical/subergnc60%40gmail.com/private-aea673a8cf3f206ff493088e6bbdbda9/basic.ics.
                        From npm run start:
                        [04.10.2023 12:28.01.300] [LOG]   Starting MagicMirror: v2.25.0
                        [04.10.2023 12:28.01.312] [LOG]   Loading config ...
                        [04.10.2023 12:28.01.322] [DEBUG] config template file not exists, no envsubst
                        [04.10.2023 12:28.01.334] [LOG]   Loading module helpers ...
                        [04.10.2023 12:28.01.339] [LOG]   No helper found for module: alert.
                        [04.10.2023 12:28.01.403] [LOG]   Initializing new module helper ...
                        [04.10.2023 12:28.01.405] [LOG]   Module helper loaded: updatenotification
                        [04.10.2023 12:28.01.411] [LOG]   No helper found for module: clock.
                        [04.10.2023 12:28.01.967] [LOG]   Initializing new module helper ...
                        [04.10.2023 12:28.01.969] [LOG]   Module helper loaded: calendar
                        [04.10.2023 12:28.01.972] [LOG]   No helper found for module: MMM-WeatherGraph.
                        [04.10.2023 12:28.02.332] [LOG]   Initializing new module helper ...
                        [04.10.2023 12:28.02.333] [LOG]   Module helper loaded: MMM-Remote-Control
                        [04.10.2023 12:28.02.353] [LOG]   Initializing new module helper ...
                        [04.10.2023 12:28.02.354] [LOG]   Module helper loaded: WallberryTheme
                        [04.10.2023 12:28.02.561] [LOG]   Initializing new module helper ...
                        [04.10.2023 12:28.02.561] [LOG]   Module helper loaded: MMM-HomeAssistantDisplay
                        [04.10.2023 12:28.02.562] [LOG]   All module helpers loaded.
                        [04.10.2023 12:28.02.581] [LOG]   Starting server on port 8080 ...
                        [04.10.2023 12:28.02.590] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        [04.10.2023 12:28.02.618] [LOG]   Server started ...
                        [04.10.2023 12:28.02.621] [LOG]   Connecting socket for: updatenotification
                        [04.10.2023 12:28.02.622] [LOG]   Starting module helper: updatenotification
                        [04.10.2023 12:28.02.624] [LOG]   Connecting socket for: calendar
                        [04.10.2023 12:28.02.625] [LOG]   Starting node helper for: calendar
                        [04.10.2023 12:28.02.626] [LOG]   Connecting socket for: MMM-Remote-Control
                        [04.10.2023 12:28.02.627] [LOG]   Starting node helper for: MMM-Remote-Control
                        [04.10.2023 12:28.02.640] [ERROR] Error when starting node_helper for module MMM-Remote-Control:
                        [04.10.2023 12:28.02.645] [ERROR] Error: Cannot find module 'node-fetch'
                        Require stack:
                        - /home/pi/MagicMirror/modules/MMM-Remote-Control/scripts/download_modules.js
                        - /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js
                            at node:internal/modules/cjs/loader:1084:15
                            at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                            at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                            at node:internal/modules/cjs/loader:929:27
                            at Function._load (node:electron/js2c/asar_bundle:2:13327)
                            at Module.require (node:internal/modules/cjs/loader:1150:19)
                            at require (node:internal/modules/cjs/helpers:110:18)
                            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Remote-Control/scripts/download_modules.js:15:15)
                            at Module._compile (node:internal/modules/cjs/loader:1271:14)
                            at Object..js (node:internal/modules/cjs/loader:1326:10)
                            at Module.load (node:internal/modules/cjs/loader:1126:32)
                            at node:internal/modules/cjs/loader:967:12
                            at Class.updateModuleList (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:191:35) {
                          code: 'MODULE_NOT_FOUND',
                          requireStack: [
                            '/home/pi/MagicMirror/modules/MMM-Remote-Control/scripts/download_modules.js',
                            '/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js',
                            '/home/pi/MagicMirror/js/app.js',
                            '/home/pi/MagicMirror/js/electron.js',
                            '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                            undefined
                        [04.10.2023 12:28.02.647] [LOG]   Connecting socket for: WallberryTheme
                        [04.10.2023 12:28.02.648] [LOG]   Starting module helper: WallberryTheme
                        [04.10.2023 12:28.02.649] [LOG]   Connecting socket for: MMM-HomeAssistantDisplay
                        [04.10.2023 12:28.02.651] [LOG]   Sockets connected & modules started ...
                        [04.10.2023 12:28.03.227] [LOG]   Launching application.
                        Once I discovered that node-fetch wasn’t found it was easy enough to follow your instructions to do an npm install node-fetch, although if I ran it in the MMM-Remote-Control directory I got
                        pi@magicmirror:~/MagicMirror/modules/MMM-Remote-Control $ npm install node-fetch
                        up to date, audited 88 packages in 4s
                        But from the MM directory:
                        pi@magicmirror:~/MagicMirror $ npm install node-fetch
                        added 6 packages in 17s
                        And which 6 packages got installed? Who knows. At any rate, Remote-Control API’s are now working again for me. Looking at the MM changelog again I see in the Updates section “Replace node-fetch with internal fetch (#2649) and remove digest-fetch.” To me that seems to be a transparent change that should break anything.
                        And a question for you, Sam. When you installed MMM-Remote-Control in V2.25, did you have to run npm install node-fetch? If not, why not?
                          sdetweil @rhbauman
                          @rhbauman on the PM2 output masking the problem there are two output areas The error output and the output output You’re just showing the output output.
                          I did not have to install node fetch in the remote control module. on any platform. I do not know why, but these were new installs not upgrades
                          karsten13K 1 Reply Last reply
                          • karsten13K
                            karsten13 @sdetweil
                            the missing node-fetch in package.json of MMM-RemoteControl was fixed 19h before so I think you installed the fixed version and rhbauman not …
                              sdetweil @karsten13
                              @karsten13 that will do it. he is upgrading already installed and I installed new with the fix
                              | thanks you made my lunch a whole lot better!!
