    Buttons only work if I access via python first
    8 Posts 3 Posters 1.8k Views 3 Watching
    • G
      gonzonia
      I’ve had this problem for a while and I’m not sure how to fix it.
      I’m using MMM-Buttons to switch between scenes from MMM-Scenes and it’s working. However, it only works if I first use a little python test program I have to test the buttons. Why? I don’t even have to actually press a button, just run the python and then exit. After that, the buttons work.
      I thought I posted this before but can’t find it. I apologize if this is a duplicate.
      Python:
      import RPi.GPIO as GPIO
      import time
      GPIO.setmode(GPIO.BCM)
      GPIO.setup(25, GPIO.IN, pull_up_down=GPIO.PUD_UP)
      GPIO.setup(24, GPIO.IN, pull_up_down=GPIO.PUD_UP)
      while True:
          input_state25 = GPIO.input(25)
          input_state24 = GPIO.input(24)
          if input_state25 == False:
              print('Button Pressed 25')
              time.sleep(0.2)
          if input_state24 == False:
              print('Button Pressed 24')
              time.sleep(0.2)
      M 1 Reply Last reply
        MMRIZE @gonzonia
        @gonzonia
        A few modules have similar names; which one are you using exactly?
        G 1 Reply Last reply
        • G
          gonzonia @MMRIZE
          @MMRIZE Sorry for the delay I missed your response.
          I’m using https://github.com/Jopyth/MMM-Buttons but happy to switch if there’s something better.
          I’m using it to switch scenes in MMM-Scenes by sending “SCENES_NEXT” or “SCENES_PREV”
          M G 2 Replies Last reply
            MMRIZE @gonzonia
            @gonzonia
            Is your issue solved?
            • G
              gonzonia @gonzonia
              Oh, I’m realized I’m not actually using https://github.com/sdetweil/MMM-Buttons to fix the install issues
              • G
                gonzonia @MMRIZE
                @MMRIZE No. I still need to run my little test script to get the buttons to work. It’s not a huge deal, I just wonder why that’s the case.
                M S 2 Replies Last reply
                  MMRIZE @gonzonia
                  @gonzonia
                  Sorry, I read the module but found nothing suspicious in that. The module and its dependencies look normal. ATM, I cannot guess the issue.
                    sdetweil @gonzonia
                    @gonzonia see this maybe
                    https://roboticsbackend.com/raspberry-pi-gpios-default-state/
