    MagicMirror seemingly ignoring custom.css
    8 Posts 2 Posters 1.9k Views 2 Watching
      mbalmer
      Hi there,
      I seem to be having an issue with my installation of MM. I’ve tried adding a custom.css file to change the fonts and colors on some of the modules I’m using, and despite my efforts, it constantly acts as though the custom.css file either isn’t there or is being overridden by something.
      I’ve tried opening the inspector while MM is running and it does show the custom.css file in the list underneath the <head> tag, but it’s like it never opened it or read it.
      I’ve attached my config.js file if that will help.
      let config = {
      	address: "localhost", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/",
      	useHttps: false,
      	httpsPrivateKey: "",
      	httpsCertificate: "",
      	language: "en",
      	locale: "en-US",
      	timeFormat: 24,
      	units: "imperial",
      	zoom: 1.75,
      			module: "alert",
      			module: "updatenotification",
      			position: "bottom_bar"
      			module: "clock",
      			position: "top_left"
      			header: "Band Calendar of Events",
      						symbol: "calendar-check",
      						url: "[[REMOVED]]"
      			module: "weather",
      				type: "current",
      // (OLD OpenWeather info)
      //				location: "[[REMOVED]]",
      //				locationID: "[[REMOVED]]",
      				apiKey: "[[REMOVED]]",
      // Weather.gov info
      //				apiBase: "https://api.weather.gov/points/",
      				lat: [[REMOVED]],
      				lon: [[REMOVED]],
      			module: "weather",
      			header: "Weather Forecast for",
      				weatherProvider: "weathergov",
      				colored: "true",
      				type: "forecast",
      // OLD OpenWeather info
      //				apiKey: "[[REMOVED]]",
      // Weather.gov info
      				apiBase: "https://api.weather.gov/points",
      				lat: [[REMOVED]],
      				lon: [[REMOVED]],
        sdetweil @mbalmer
        @mbalmer try this
        pm2 stop all
        cd ~
        rm -rf .config/Electron
        cd MagicMirror
        npm start
        seems electron doesn’t like changing the zoom setting once set.
        this will erase all the saved electron settings
        you can try the browser keys to zoom as well. these are saved
        ctrl-+ (plus) zoom in
        ctrl-- (minus)zoom out
        some keyboards require those next to backspace some on keypad
          sdetweil @mbalmer
          @mbalmer open the developers window, ctrl-shift-i on the MM keyboard
          go to the console tab, and enter css
          you should see something like this
            mbalmer @sdetweil
            Yep; I see what you’re talking about. I do have a “refused to apply style” error, but it’s for “animate.css” and not “custom.css”.
            I looked, and the reason it’s showing that is because “animate.css” doesn’t exist, so it’s throwing a 404 there, but I don’t understand why that would stop it from loading custom.css – as far as I know, the two aren’t linked.
            Interestingly, the error shows twice – once at the very top of the console, and then again as the last line. I don’t know if that means it’s trying to find it twice or if that’s the inspector shoving errors to the bottom of the list so they’re easily viewed.
            Do I have a missing package that should’ve been installed?
            Here’s a screenshot:
              sdetweil @mbalmer
              @mbalmer I don’t know why the animate.css is listed twice
              but it shows that custom.css was loaded successfully no error produced.
              So now we need to understand what’s in custom CSS and is it used properly.
              if you go to the elements tab you can use the little pointer to the left of the top left corner and you can use the mouse pointer over the content in the browser side to pick the element you want to look at when you click it will appear on the right hand side and you can see the style sheets CSS tree down the right hand side
              see this post for using the elements tab
              https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1696523432686
                mbalmer @sdetweil
                I tried repeatedly tweaking values in custom.css and nothing ever seemed to change, so I tried a complete, fresh reinstallation.
                Now the config.css file loads and parses properly, but a new thing has popped up: In the config.js file, it’s ignoring the zoom property completely. Everything else works, but even though I have it set to zoom: 1.75, it’s still displaying at a zoom of 1. I suppose I could just change the base font sizes in the custom.css file, but it was nice to have the global zoom set in the config.js file.
                  sdetweil @mbalmer
                  @mbalmer try this
                  pm2 stop all
                  cd ~
                  cd MagicMirror
                  npm start
                    mbalmer @sdetweil
                    The rm -rf did the job. Makes me wonder if adding modules will be as obstinate as this was. Is it grabbing a cached copy somewhere, or is it just that setting that it doesn’t like changing?
                      sdetweil @mbalmer
                      @mbalmer this is an electron thing not a magic mirror thing.
                      they don’t disclose what they save and what conditions allow it to be changed.
                      it originally worked just like you proposed change it in config and then it worked right but then they changed something in electron without telling anybody
                      MagicMirror does not cache anything
