MMM-NewsAPI after MM2.25.0 update
6 Posts 3 Posters 753 Views 3 Watching
  • K Offline
    kicifans
    Hello everyone!
    Anyone else having problems with this module after updating?
    I get this error when starting up MagicMirror:
    [ERROR] (node:2571) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘node-fetch’
    Require stack:
    • /home/pi/MagicMirror/modules/MMM-NewsAPI/node_helper.js
    • at node:internal/modules/cjs/loader:1084:15
      at Function. (node:electron/js2c/browser_init:2:117419)
      at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
      at node:internal/modules/cjs/loader:929:27
      at Function._load (node:electron/js2c/asar_bundle:2:13327)
      at Module.require (node:internal/modules/cjs/loader:1150:19)
      at require (node:internal/modules/cjs/helpers:110:18)
      at Object. (/home/pi/MagicMirror/modules/MMM-NewsAPI/node_helper.js:4:13)
      at Module._compile (node:internal/modules/cjs/loader:1271:14)
      at Object…js (node:internal/modules/cjs/loader:1326:10)
      at Module.load (node:internal/modules/cjs/loader:1126:32)
      at node:internal/modules/cjs/loader:967:12
      at loadModule (/home/pi/MagicMirror/js/app.js:180:19)
    Maybe module is working fine for others after update?
    Any ideas or help would be appreciated!
    Thanks in advance.
    S 1 Reply Last reply Oct 10, 2023, 7:18 PM Reply Quote 0
    • S Away
      sdetweil @kicifans
      @kicifans said in MMM-NewsAPI after MM2.25.0 update:
      yes, we removed node-fetch in this release, and here is another module that didn’t document using it…
      see general purpose recovery steps here
      K M 2 Replies Last reply Oct 10, 2023, 7:24 PM Reply Quote 1
      • K Offline
        kicifans @sdetweil
        @sdetweil Thank you! This solved the issue!
        S 1 Reply Last reply Oct 10, 2023, 7:26 PM Reply Quote 1
        • S Away
          sdetweil @kicifans
          @kicifans awesome… thanks for the feedback…
            @sdetweil Thanks for the assist with this one Sam but my module does list the dependencies on Github. Check it out.
            https://github.com/mumblebaj/MMM-NewsAPI
            S 1 Reply Last reply Oct 11, 2023, 3:40 PM Reply Quote 1
            • S Away
              sdetweil @mumblebaj
              @mumblebaj all I can say is the ‘manual fix’ worked…
              don’t know why
