    Unable to run MM install script with raspbian bookworm
    13 Posts 2 Posters 4.5k Views 2 Watching
    • I Offline
      ijahmc2u @sdetweil
      this was a new sd card and new install …
      for some reason it is telling me the log file needs to end in png… jpeg not in .log
      anyway to get ti working I had to do the following
      sudo apt-get update && sudo apt-get install -y ca-certificates curl gnupg
      curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
      NODE_MAJOR=20
      echo “deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_$NODE_MAJOR.x nodistro main” | sudo tee /etc/apt/sources.list.d/nodesource.list
      sudo apt-get update && sudo apt-get install nodejs -y
      • I Offline
        ijahmc2u @sdetweil
        sorry just lost power for a bit there…
        so to answer your questions this was a fresh install of MM on a new SD card
        no I installed the opencv and dlib first as I have had issues with them in the past so I built them from source…
        while doing some reading I installed nodejs from the steps on their site and then ran your script and now it installed everything and ran pm2 as well … vnc is not working but thats ok for now.
        also note I was trying to upload my install.log but it won’t let me upload a .log file
        • I Offline
          ijahmc2u
          admin@rasmm:~ $ node -v
          v20.8.1
            sdetweil @ijahmc2u
            @ijahmc2u hm… but why? should be 20.8.0
            do
            n ls
              sdetweil @ijahmc2u
              @ijahmc2u please don’t do the node20 stuff it messes it all up
              flash the SD card
              boot , configure wifi…
              reboot run my install script
              then add the; ther stuff
              do NOT DO ANY NODE INSTALL . my script will handle all that.
              I 2 Replies Last reply Reply Quote 0
              • I Offline
                ijahmc2u @sdetweil
                ok will try that
                • I Offline
                  ijahmc2u @sdetweil
                  ok that worked please close this one … looks like I am having another problem with the module mmm-face-reco-dnn all other modules seem to be installing ok
                    sdetweil @ijahmc2u
                    @ijahmc2u said in Unable to run MM install script with raspbian bookworm:
                    whats the problem there? note that it is using old python, and opencv so there may be impacts… the module hasn’t been updated in quite a while
                    and the install/usage doc is missing a few important words for new users
                    • I Offline
                      ijahmc2u @sdetweil
                      sorry for the late response
                      After installing pipenv I still can’t get the dependencies to be installed seems to look up at the Pipfile.lock and then after some time it spits out a bunch of failure messages
                        sdetweil @ijahmc2u
                        @ijahmc2u I don’t know. I see the author has been working on some changes…
