[MMM-OpenWeatherMapForecast] ** ERROR ** null
3 Posts 2 Posters 620 Views 2 Watching
    Chazzer
    [15.10.2023 13:51.43.569] [INFO] Checking git for module: MMM-OpenWeatherMapForecast
    [15.10.2023 13:51.43.609] [LOG] [MMM-OpenWeatherMapForecast] 15-Oct-23 13:51 ** ERROR ** null
    Can someone tell me why I get the error null?
    I use a Pi 3b and latest MM2 version. ( MagicMirror: v2.25.0)
    The default weather app function
    Open weather Map "loaded cc5859ce-fbda-4dbd-8396-3c5884cc5466-Bild 15.10.23 um 13.57.jpg
    I install it from here:
    https://github.com/MarcLandis/MMM-OpenWeatherMapForecast
    config
    module: “MMM-OpenWeatherMapForecast”,
    header: “Open Weather Map”,
    position: “top_right”,
    classes: “default everyone”,
    disabled: false,
    apikey: “4xxxxSecret”,
    latitude: “51.003610”,
    longitude: “6.889070”,
    iconset: “4c”,
    concise: false,
    forecastLayout: “table”
      JeanMichelC
      I have the same issue and I spent some time debugging it. It turns out that the API call reference the onecall API which is not free. It requires a subscription https://openweathermap.org/api/one-call-3#error401
      The call is using 2.5 but the documentation online only reference 3.0
      https://api.openweathermap.org/data/3.0/onecall?lat={lat}&lon={lon}&exclude={part}&appid={API key}
      I tried changing the API call to use hte free one but the layout is probably diffrent and therefore fails.
      I think this module won’t work unless you have the OneCall subscription.
      C 1 Reply Last reply Oct 21, 2023, 12:58 AM Reply Quote 0
        Chazzer @JeanMichelC
        As you described, the solution was to upgrade the subscription to the One Call API 3.0. Subsequently, I created a new API key and configured it in the config.js file for the module. Thank you for the suggestion.
        Now, I just need to align everything to the right.
