    Alexa Control i save th config ab get black screen (config fail)
    5 Posts 2 Posters 969 Views 2 Watching
      Chazzer
      The problem I have, after I installed the module and extended the config with the module, my MagicMirror shuts down. and I see Linux Desktop. with PM2 restart MagiMirror I have no success. Is there something wrong with the module in the config?
      Please have a look .
          module: 'MMM-AlexaControl',
          position: 'middle_center',
              image: true,
              pm2ProcessName: "MagicMirror",
              monitorToggle: true,
              vcgencmd: "vcgencmd"
        sdetweil @Chazzer
        @Chazzer So you didn’t do the npm install that’s required for this module
          sdetweil @Chazzer
          @Chazzer do
           pm2 stop all
          npm start
          what error do you see?
            Chazzer @sdetweil
            @sdetweil ```
            dorieen@raspberrypi:~/MagicMirror $ npm start
            magicmirror@2.25.0 start
            [23.10.2023 06:01.02.810] [LOG] Starting MagicMirror: v2.25.0
            [23.10.2023 06:01.02.819] [LOG] Loading config …
            [23.10.2023 06:01.02.824] [DEBUG] config template file not exists, no envsubst
            [23.10.2023 06:01.02.832] [LOG] Loading module helpers …
            [23.10.2023 06:01.02.835] [LOG] No helper found for module: alert.
            [23.10.2023 06:01.02.882] [LOG] Initializing new module helper …
            [23.10.2023 06:01.02.884] [LOG] Module helper loaded: updatenotification
            [23.10.2023 06:01.04.063] [LOG] Initializing new module helper …
            [23.10.2023 06:01.04.065] [LOG] Module helper loaded: MMM-Jast
            [23.10.2023 06:01.04.067] [LOG] No helper found for module: clock.
            [23.10.2023 06:01.04.438] [LOG] Initializing new module helper …
            [23.10.2023 06:01.04.440] [LOG] Module helper loaded: calendar
            [23.10.2023 06:01.04.479] [LOG] Initializing new module helper …
            [23.10.2023 06:01.04.480] [LOG] Module helper loaded: MMM-birthdays
            [23.10.2023 06:01.04.562] [LOG] Initializing new module helper …
            [23.10.2023 06:01.04.563] [LOG] Module helper loaded: MMM-OpenWeatherMapForecast
            [23.10.2023 06:01.04.571] [ERROR] (node:6150) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘node-fauxmo’
            Require stack:
            • /home/dorieen/MagicMirror/modules/MMM-AlexaControl/node_helper.js
            • /home/dorieen/MagicMirror/js/app.js
            • /home/dorieen/MagicMirror/js/electron.js
            • /home/dorieen/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
            • at node:internal/modules/cjs/loader:1084:15
              at Function. (node:electron/js2c/browser_init:2:117500)
              at Module._resolveFilename (/home/dorieen/MagicMirror/node_modules/module-alias/index.js:49:29)
              at node:internal/modules/cjs/loader:929:27
              at Function._load (node:electron/js2c/asar_bundle:2:13327)
              at Module.require (node:internal/modules/cjs/loader:1150:19)
              at require (node:internal/modules/cjs/helpers:110:18)
              at Object. (/home/dorieen/MagicMirror/modules/MMM-AlexaControl/node_helper.js:10:14)
              at Module._compile (node:internal/modules/cjs/loader:1271:14)
              at Object…js (node:internal/modules/cjs/loader:1326:10)
              at Module.load (node:internal/modules/cjs/loader:1126:32)
              at node:internal/modules/cjs/loader:967:12
              at loadModule (/home/dorieen/MagicMirror/js/app.js:180:19)
              (Use electron --trace-warnings ... to show where the warning was created)
              [23.10.2023 06:01.04.572] [ERROR] (node:6150) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
              [6150:1023/060105.030239:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
              MESA-LOADER: failed to retrieve device information
            S C 2 Replies Last reply Reply Quote 0
              sdetweil @Chazzer
                Chazzer @Chazzer
                @Chazzer
                what ,… hmm I forgot…hmm I make it. Thank you very much!
