    Error trying to run: npm run install-mm
    18 Posts 2 Posters 9.5k Views 2 Watching
    • L
      lvolkjr
      I’m trying to install MagicMirror on my Pi 4 - Buster and when I put in npm run install-mm while I’m in the MagicMirror folder I get the following:
      evalmachine.:36
      } = primordials;
      ReferenceError: primordials is not defined
      at evalmachine.:36:5
      at Object. (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/fs.js:11:8)
      at Module._compile (internal/modules/cjs/loader.js:999:30)
      at Object.Module._extensions…js (internal/modules/cjs/loader.js:1027:10)
      at Module.load (internal/modules/cjs/loader.js:863:32)
      at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      at Module.require (internal/modules/cjs/loader.js:887:19)
      at require (internal/modules/cjs/helpers.js:74:18)
      at Object. (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:3:27)
      How do I resolve this issue? I’m new to this.
        sdetweil @lvolkjr
        @lvolkjr I expected something too
        I’d rebuild the SD card, boot, skip updates
        then use my script. this node install is such a mess, they changed the process…ugh
          sdetweil @lvolkjr
          @lvolkjr yeh, SO much fun…
          take off nodejs
          sudo apt-get remove nodejs npm -y
          then
          node -v
          should return commands not found ,or some old version number maybe 12…
          then run my install script…
          see https://github.com/sdetweil/MagicMirror_scripts
          it will install the correct version of nodejs and npm
          • L
            lvolkjr @sdetweil
            @sdetweil I ran node -v and got the following:
            bash: /usr/bin/node: No such file or directory
            Then I ran your install script and got this:
            install log being saved to /home/lowell/install.log
            Updating packages …
            Installing helper tools …
            installing correct version of node and npm, please wait
            sudo: n: command not found
            node failed to install, exiting
              sdetweil @lvolkjr
              @lvolkjr sorry
              can u do
              ls /usr/bin/node -laF
              if not present do
              hash -r
              then node -v again
              also show me output of
              uname -a
              lsb_release -a
              file /bin/bash
              • L
                lvolkjr @sdetweil
                @sdetweil My bad I said Buster earlier, It’s Bullseye. I went back a version because I needed VNC server to work.
                lowell@raspberrypi:~/MagicMirror $ ls /usr/bin/node -laF
                -rwxr-xr-x 1 root root 80547788 Oct 13 07:03 /usr/bin/node*
                lowell@raspberrypi:~/MagicMirror $ node -v
                v18.18.2
                lowell@raspberrypi:~/MagicMirror $ uname -a
                Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
                lowell@raspberrypi:~/MagicMirror $ lsb_release -a
                No LSB modules are available.
                Distributor ID: Raspbian
                Description: Raspbian GNU/Linux 11 (bullseye)
                Release: 11
                Codename: bullseye
                lowell@raspberrypi:~/MagicMirror $ file /bin/bash
                /bin/bash: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, BuildID[sha1]=f12e6d40fb262ad0037b6ec43162208b76d4da71, for GNU/Linux 3.2.0, stripped
                  sdetweil @lvolkjr
                  @lvolkjr ok, try this
                  which node
                  n ls
                  • L
                    lvolkjr @sdetweil
                    lowell@raspberrypi:~/MagicMirror $ which node
                    /usr/bin/node
                    lowell@raspberrypi:~/MagicMirror $ n ls
                    bash: n: command not found
                      sdetweil @lvolkjr
                      @lvolkjr ok, thx… but how did you get to node 18? it doesn’t come as default.
                      • L
                        lvolkjr @sdetweil
                        @sdetweil I was looking for a solution prior to coming to this forum and following someone else’s answer to there own issue that I thought would work for me, but got me no where. they said to change to node 18 from here: https://github.com/nodesource/distributions
                        Download and import the Nodesource GPG key
                        sudo apt-get update
                        sudo apt-get install -y ca-certificates curl gnupg
                        sudo mkdir -p /etc/apt/keyrings
                        curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
                        Create deb repository
                        NODE_MAJOR=20
                        echo “deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_$NODE_MAJOR.x nodistro main” | sudo tee /etc/apt/sources.list.d/nodesource.list
                        Optional: NODE_MAJOR can be changed depending on the version you need.
                        NODE_MAJOR=16
                        NODE_MAJOR=18
                        NODE_MAJOR=20
                        NODE_MAJOR=21
                        Run Update and Install
                        sudo apt-get update
                        sudo apt-get install nodejs -y
                        Did this screw me up?
                          sdetweil @lvolkjr
                          @lvolkjr said in Error trying to run: npm run install-mm:
                          maybe…
                          try this
                          sudo apt-get remove nodejs -y
                          then do
                          node -v
                          • L
                            lvolkjr @sdetweil
                            @sdetweil I didn’t see any errors after running sudo apt-get remove nodejs -y
                            When I run node -v I get this:
                              sdetweil @lvolkjr
                              @lvolkjr ok, do
                              ls /usr/bin/node
                              should return file not found
                              do
                              hash -r
                              node -v
                              just to make sure…
                              then run my install or upgrade script as appropriate…
                              • L
                                lvolkjr @sdetweil
                                @sdetweil This is what I got:
                                lowell@raspberrypi:~ $ ls /usr/bin/node
                                ls: cannot access ‘/usr/bin/node’: No such file or directory
                                lowell@raspberrypi:~ $ hash -r
                                lowell@raspberrypi:~ $ node -v
                                bash: node: command not found
                                Do you still want me to run your script? I feel like node -v should have given me a different output, like the version number.
                                  sdetweil @lvolkjr
                                  • L
                                    lvolkjr @sdetweil
                                    @sdetweil Yea, I figured. Thanks for all your help. Hopefully I could repay you in the future. I’ll keep you updated to what happens.
                                    • L
                                      lvolkjr @lvolkjr
                                      @sdetweil Thanks!!! That worked! I’m running MagicMirror and getting ready to customize it. I should have started over a long time ago.
                                        sdetweil @lvolkjr
                                        @lvolkjr cool… yeh, its hard to tell when you’ve hit a real roadblock
                                        glad you are working now… make sure to backup!!..
                                        see https://github.com/sdetweil/MagicMirror-backup-restore
                                        • L
                                          lvolkjr @sdetweil
                                          @sdetweil I will, thanks again.
