    Mmm calendar ext3
    11 Posts 3 Posters 6.1k Views 3 Watching
      Michelle.H2020 @MMRIZE
      @MMRIZE
      https://share.icloud.com/photos/03aqlgKBfgMhJNo1eFLv7-Jng
        @Michelle-H2020 please use the code block around config info
          Michelle.H2020 @sdetweil
            module: "MMM-CalendarExt3",
            position: "bottom_bar",
          mode: "week",
              instanceId: "basicCalendar",
              locale: 'en',
              maxEventLines: 4,
          url: "https://calendar.google.com/calendar/ical/dandmfloors2023%40gmail.com/public/basic.ics",
          maxTitleLength: 50,
              firstDayOfWeek: 1,
             weeksInView: 3,
          wrapEvents: true,
          timeFormat: "relative",
          		dateFormat: "MMM Do",
          		dateEndFormat: "LT",
          		fullDayEventDateFormat: "MMM Do",
          weekIndex:0,
          useWeather: true,
          weatherLocationName: "castle rock",
          displayWeatherTemp: true,
          			header: "D and M floors",
          			position: "middle",
          				broadcastPastEvents: true,
          maxTitleLength: 50,
          fade: false,
          						symbol: "heart",
          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
          						url: "https://calendar.google.com/calendar/ical/9953584ecf47252ac2c45157fea7937266a498edfa2520dbfaccd8778cec2833%40group.calendar.google.com/public/basic.ics",
            sdetweil @Michelle.H2020
            @Michelle-H2020 said in Mmm calendar ext3:
            module: “calendar”,
            header: “D and M floors”,
            position: “middle”,
            in the default calendar
            the calendars:[ ] // is a list
            each entry in the list is a url block
                 url:
                 color:
                 name:
                 symbol:
            if TWO of the same entry is made ( like url, and url), the second overlays the first…
            ext3 NEVER uses url…
              MMRIZE @Michelle.H2020
              @Michelle-H2020
              What is your screen resolution? It seems not FHD.
                @Michelle-H2020
                I think you probably edited custom.css,
                Without any modification/overriding of custom.css, This module should look like these;
                • 1080x1920 vertical screen
                • 600x800 vertical screen
                  @MMRIZE
                  Great I will mess around with that when I get home later also how did you change your calendar event to showing just todays events ? Mine show all the way until January trying to resolve that.
                  Also I have just been adjusting the config.is file I have no idea about the css stuff yet . Is that where you go to change font and styles ?
                    I was wondering why it wasn’t showing both my calendars thanks ! I will mess with that when I get home
                      Michelle.H2020
                      So I think I’m ok with the bottom calendar I just can’t figure out how to make the list to display for a month instead of all the way into January
                      https://share.icloud.com/photos/078is2God3mgkrI_9spjrgJ5g
