    Mmm calendar ext3
    11 Posts 3 Posters 6.1k Views 3 Watching
      sdetweil @Michelle.H2020
      @Michelle-H2020 said in Mmm calendar ext3:
      module: “calendar”,
      header: “D and M floors”,
      position: “middle”,
      in the default calendar
      the calendars:[ ] // is a list
      each entry in the list is a url block
           url:
           color:
           name:
           symbol:
      if TWO of the same entry is made ( like url, and url), the second overlays the first…
      ext3 NEVER uses url…
        MMRIZE @Michelle.H2020
        @Michelle-H2020
        What is your screen resolution? It seems not FHD.
          @Michelle-H2020
          I think you probably edited custom.css,
          Without any modification/overriding of custom.css, This module should look like these;
          • 1080x1920 vertical screen
          • 600x800 vertical screen
            Michelle.H2020 @MMRIZE
            @MMRIZE
            Great I will mess around with that when I get home later also how did you change your calendar event to showing just todays events ? Mine show all the way until January trying to resolve that.
            Also I have just been adjusting the config.is file I have no idea about the css stuff yet . Is that where you go to change font and styles ?
              Michelle.H2020 @sdetweil
              I was wondering why it wasn’t showing both my calendars thanks ! I will mess with that when I get home
                Michelle.H2020
                So I think I’m ok with the bottom calendar I just can’t figure out how to make the list to display for a month instead of all the way into January
                https://share.icloud.com/photos/078is2God3mgkrI_9spjrgJ5g
