    dist/electron: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directory
    23 Posts 2 Posters 12.6k Views 2 Watching
    • T Offline
      the_2winz
      new magicmirror2 install. finally got npm install-mm to run. when i ran npm start run, i get /MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directory
      • T Offline
        the_2winz @sdetweil
        @sdetweil i think i will just lean on the browser feature - npm run server seems to work. thanks for all your help!
          sdetweil @the_2winz
          @the_2winz what platform is this?
          Google search to find the system command to install that library
          • T Offline
            the_2winz @sdetweil
            @sdetweil Debian Bullseye with Raspberry Pi Desktop
              sdetweil @the_2winz
              @the_2winz weird. haven’t seen that error in a long time on that
              did you install MagicMirror w my script or manually?
              • T Offline
                the_2winz @sdetweil
                @sdetweil both actually. I ran npm run install-mm, then i ran your upgrade-script.sh got this Check current Node installation …
                Minimum Node version: v20.8.0
                Installed Node version: v20.8.0
                No Node.js upgrade necessary.
                Check current NPM installation …
                Minimum npm version: V10.1.0
                Installed npm version: V10.2.3
                No npm upgrade necessary.
                upgrading from version 2.25.0 to 2.25.0
                fetching latest revisions
                no modules found needing npm refresh
                  sdetweil @the_2winz
                  @the_2winz did u find the command to install libnss?
                  T 2 Replies Last reply Reply Quote 0
                  • T Offline
                    the_2winz @sdetweil
                    @sdetweil I found this Install libnss3 deb package: sudo apt-get install libnss3, but get this: /usr/lib/x86_64-linux-gnu $ sudo apt-get install libnss3
                    Reading package lists… Done
                    Building dependency tree… Done
                    Reading state information… Done
                    libnss3 is already the newest version (2:3.61-1+deb11u3).
                    0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
                      sdetweil @the_2winz
                      @the_2winz and now MM should start ok
                      you should not be running MM as root user…
                      • T Offline
                        the_2winz @sdetweil
                        @sdetweil still get this
                        rob@raspberry:~/MagicMirror $ npm run start
                        magicmirror@2.25.0 start
                        /home/rob/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directory
                          sdetweil @the_2winz
                          @the_2winz
                          sudo apt get install libnss
                          edit:
                          on my desktop I see
                          libnss3.so => /usr/lib/x86_64-linux-gnu/libnss3.so (0x00007f2630707000)
                          from
                          ldd ~/MagicMirror/node_modules/electron/dist/electron | grep libnss
