    Stuck at my Mirror currently....
    9 Posts 2 Posters 1.4k Views 2 Watching
      MMRIZE @1a2a3a
      @1a2a3a
      For 2. “useMarquee:false”. It is too heavy to your device.
      1 1 Reply Last reply Reply Quote 0
      • 1 Offline
        1a2a3a @MMRIZE
        @MMRIZE sorry I’m not very good at this… could you provide more context on where and how should I do this and why?
          MMRIZE @1a2a3a
          @1a2a3a
          Rpi3 is almost 8years ago introduced. It may have not enough power to handle modern tech like 4k video or heavy animation.
          I added new feature to the module recently, because I don’t use RPI any more for MM, but still many ppl are using RPI legacy/low-profile models.
          Anyway to turn off the marquee effects, add “useMarquee:false,” in the config of CX3 module in your config.js
          https://github.com/MMRIZE/MMM-CalendarExt3#config-details
          I will change it’s default value to “false” later at next update. I have done now.
          • 1 Offline
            1a2a3a @MMRIZE
            @MMRIZE thanks for the explanation. I will give this a shot. But does this mean if the text is too long it won’t move anymore? I kinda like the animation tho. Is this then a hardware limitation and I need to get something better?
            • 1 Offline
              1a2a3a
              will a pi4 or pi5 fix the slowness issue?
                MMRIZE @1a2a3a
                @1a2a3a
                Right. MM itself is runnable on any device but more powered devices are usually more expensive or bigger than RPI.
                • 1 Offline
                  1a2a3a @MMRIZE
                  @MMRIZE if I change to rpi 4 or 5 will that helps?
                  I put in the calendar and google photo (yes managed to resolve installation issue) and it’s laggy like mad.
                  By any chance you have solution for point 1)?
                    MMRIZE @1a2a3a
                    @1a2a3a
                    I have no device to test at this moment. So I cannot confirm you.
                    And I have no idea about MMM-ModuleScheduler.
