    Help with date format MMM-CalendarExt3
    18 Posts 2 Posters 5.9k Views 2 Watching
    • 1 Offline
      1a2a3a @1a2a3a
      scratch that. managed to get cx3 and agenda to display correctly.
      im now left with the overall date and the calendar module that doesnt sems to work…
      i circled them in red both on the right. the red circle is abit light on the black background
      • 1 Offline
        1a2a3a @MMRIZE
        @MMRIZE ok almost there. overall date has been changed as well.
        all thats is left is the holiday on the right…
          MMRIZE @1a2a3a
          @1a2a3a
          dateFormat : "Do MMM", for the default calendar config, maybe. I hope so…
          1 1 Reply Last reply Reply Quote 0
          • 1 Offline
            1a2a3a @MMRIZE
            @MMRIZE it doesnt work. i have tried timeFormat to absolute as well.
            tried inputting locale to default calendar module as well.
            all doesnt work.
            btw the default calendar module is part of your cx3. in your cx3 it requires the configuration of default cal module.
            for the cx3agenda, i have hidden the default cal module.
              MMRIZE @1a2a3a
              @1a2a3a
              The default calendar is not part of mine. My module just use it’s broadcasted event list. So mines are dependent to that module, but its working is not my responsibility.
              To hide some module, set CSS as display:none for that module, or just remove position from config.
              • 1 Offline
                1a2a3a
                Anybody has an idea how to change the default cal?
                  MMRIZE @1a2a3a
                  @1a2a3a
                  /* default calendar config */
                  		timeFormat: "absolute",
                  		dateFormat: "Do. MMM, HH:mm",
                  		fulldayEventDateFormat: "Do. MMM",
                  		urgency: 0,
                  		getRelative: 0,
                  1 2 Replies Last reply Reply Quote 0
                  • 1 Offline
                    1a2a3a @MMRIZE
                    @MMRIZE hmm still not happening.
                    		broadcastPastEvents: true,
                    		header: "Singapore Holiday",
                    		maximumEntries: 10,
                    				url: "https://www.officeholidays.com/ics/singapore",
                      MMRIZE @1a2a3a
                      @1a2a3a Have no idea. Maybe another reason.
                      I recommend re-setup from the default config file cleanly. Change one by one.
                      • 1 Offline
                        1a2a3a @MMRIZE
                        @MMRIZE for your this particular calendar on the top left. are you able to show holiday and exclude all other calendar without affecting your cx3?
                        so for example in your calendar module you define holiday ics, soccer ics, and personal ics.
                        in cx3, to show all 3 ics.
                        but for that particular top left module, is it possible to just show holiday ics?
                        the only way for this to work is that i define 2 default calendar module in my config.
                        the 1st default cal - soccer ics and personal ics. hide this module and cx3 and cx3agenda will pull soccer ics and personal ics into them.
                        the 2nd default cal - holiday ics. do not hide and make it appear. this 2nd default cal module will show just holidays. cx3 and cx3 agenda will then show all 3 ics.
                          MMRIZE @1a2a3a
                          Remove position: "...", from the config of the target module to hide. It will not be rendered. In your case, maybe the 1st default calendar.
                          • 1 Offline
                            1a2a3a @MMRIZE
                            @MMRIZE so the thing here is that, with the 2 default calendar module, when 1 if turned off from viewing (hiding) i can set it to show different ics, but the date format change doesnt work.
                            if i ‘delete’ 1 of the default cal entirely and just keep 1 default calendar and showcase it, the date format change suggested by you works. but in this instance, that visible calendar is only able to show all the ics and not just the specific ones that i want.
                              MMRIZE @1a2a3a
                              @1a2a3a I think you’d better repost this as another new topic. (“Setting 2 default calendar modules; but weird represent”)
                              We are out of the original topic; ppl who don’t have an interest in CX3 will not see this thread.
                              • 1 1a2a3a referenced this topic on
