[module.show] Not animated instantly shown
When calling the show function from a module it doesn’t use it’s animation, no matter the animation time. I am using windows and just did a clean pull to make sure it wasn’t the fault of a module I was making.
To test this I made a very simple module, code:Module.register("TestHideShow", { notificationReceived: function (notification, payload, sender) { if (notification === "TEST_HIDE") { MM.getModules().enumerate(function (module) { module.hide(10000); }); } if (notification === "TEST_SHOW") { MM.getModules().enumerate(function (module) { module.show(10000); }); } } });All it does is hide all modules when a notification is recieved.
Then I copied the sample config, removed both weather modules and added:{ module: "MMM-ModuleScheduler", config: { notification_schedule: [ {notification: "TEST_HIDE", schedule: "3 * * * *", payload: "a"}, {notification: "TEST_SHOW", schedule: "4 * * * *", payload: "b"} ] } }, { module: "TestHideShow" },I used the ModuleScheduler to send 2 notifications, with one minute in between.
For the hide animation everything works as expected, a very slow fade out (10sec). Then after one minute you would expect a very slow fade in (also 10sec), but it just pops onto the screen as if the duration was0. I also checked the log and it didn’t do anything unusual.Is anyone able to recreate this/does anyone encountered the same issue?
Note: I came across this while making a different module, so it’s not because of this testing module only.
I tested this with the remote controll module aswell and experienced the same result.
@tosti007 the core adds this style property to the wrapper
moduleWrapper.style.transition = "opacity " + speed / 1000 + "s";when the hide function is called, inspect the elements in your browser and see if this shows your 10 seconds -
@strawberry-3.141 Checked it, what happened was that this transition style was added as expected. However what I did notice was that the container within a region also changed it’s display value. When hiding it was set to
display: none;after the animation. When showing a module it was set todisplay: block;and right when that happens the module is visible without animation (eventhough the module’s container did changetransitionvalue) -
Note: I tested it with electron and firefox
I’ve been fighting with this as well. @tosti007 I noticed the same thing in the inspector. Still looking for a solution but digging into the guts of this thing is time consuming… I appreciate the test results, that saved me some time chasing ghosts.
// Show the desire modules var showModules = MM.getModules().withClass(page); for (i = 0; i < showModules.length; i += 1) { showModules[i].show(this.config.fadeTime); }If I figure it out I’ll post an update. I just wanted to let someone know that I’m experiencing the same issue.
@TheBogueRat yea indeed it takes quite a while, let me know if you find anything! I hope you do
I’ve found that if I have multiple iFrames in one position, i.e. ‘top_left’ and fade one out completely then start the fade in on the next one, I get the fade in/out to work properly which is my desired outcome.
If I have single iFrames in the left and center and try to fade one out and the other in, it always pops in. That needs to be fixed but I couldn’t identify a cause.
I noticed that animations works if you have at least one other visible module inside the region.
I think the problem is in the function updateWrapperState (main.js) that will change the region wrapper’s style to “none” if no module inside the same region has a style.position of “fixed”.
I’ve just added a PR that hopefully fixes this issue: https://github.com/MichMich/MagicMirror/pull/744
Just want to notify you that this issue has been solved in the latest commit in the develop-branch.
