    [module.show] Not animated instantly shown
    10 Posts 4 Posters 6.0k Views 4 Watching
    • tosti007T Offline
      tosti007 Module Developer @strawberry 3.141
      @strawberry-3.141 Checked it, what happened was that this transition style was added as expected. However what I did notice was that the container within a region also changed it’s display value. When hiding it was set to display: none; after the animation. When showing a module it was set to display: block; and right when that happens the module is visible without animation (eventhough the module’s container did change transition value)
      If there is anything don't hesitate to contact me!
      ProfileSwitcher, TouchNotifications
      • tosti007T Offline
        Note: I tested it with electron and firefox
        • T Offline
          TheBogueRat
          I’ve been fighting with this as well. @tosti007 I noticed the same thing in the inspector. Still looking for a solution but digging into the guts of this thing is time consuming… I appreciate the test results, that saved me some time chasing ghosts.
          // Show the desire modules
          var showModules = MM.getModules().withClass(page);
          for (i = 0; i < showModules.length; i += 1) {
              showModules[i].show(this.config.fadeTime);
          If I figure it out I’ll post an update. I just wanted to let someone know that I’m experiencing the same issue.
          tosti007T 1 Reply Last reply Reply Quote 0
          • tosti007T Offline
            tosti007 Module Developer @TheBogueRat
            @TheBogueRat yea indeed it takes quite a while, let me know if you find anything! I hope you do
            • T Offline
              TheBogueRat
              I’ve found that if I have multiple iFrames in one position, i.e. ‘top_left’ and fade one out completely then start the fade in on the next one, I get the fade in/out to work properly which is my desired outcome.
              If I have single iFrames in the left and center and try to fade one out and the other in, it always pops in. That needs to be fixed but I couldn’t identify a cause.
              • CatoC Offline
                Cato Module Developer
                I noticed that animations works if you have at least one other visible module inside the region.
                I think the problem is in the function updateWrapperState (main.js) that will change the region wrapper’s style to “none” if no module inside the same region has a style.position of “fixed”.
                I’ve just added a PR that hopefully fixes this issue: https://github.com/MichMich/MagicMirror/pull/744
                • CatoC Offline
                  Just want to notify you that this issue has been solved in the latest commit in the develop-branch.
                  1 Reply Last reply Reply Quote 4
