    Magic Mirror doesn't work after a boot
    27 Posts 2 Posters 8.9k Views 2 Watching
    • E Offline
      eightbit @sdetweil
      @sdetweil said in Magic Mirror doesn't work after a boot:
      “start”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js”,
              "name": "magicmirror",
              "version": "2.25.0",
              "description": "The open source modular smart mirror platform.",
              "main": "js/electron.js",
              "scripts": {
              "repository": {
                      "type": "git",
                      "url": "git+https://github.com/MichMich/MagicMirror.git"
      • E Offline
        eightbit @sdetweil
        Linux raspberrypi 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
          sdetweil @eightbit
          @eightbit you didn’t need to delete all the rest of the scripts
            sdetweil @eightbit
            @eightbit ok, armv7 and memory >512… hm
            can u send me the ~/install.log
            I want to see why it picked the run-statrt approach…
            same userid at gmail
              sdetweil @eightbit
              @eightbit thanks for the log… says electron did not install. hmm…
              thus trying to use chromium…
              does it start now ? pm2 or npm start?
              • E Offline
                eightbit @sdetweil
                @sdetweil ```
                secretsanta@raspberrypi:~/MagicMirror $ npm start
                magicmirror@2.25.0 start
                sh: 1: ./node_modules/.bin/electron: not found
                  sdetweil @eightbit
                  @eightbit ok…
                  npm install electron@26.2.4
                  and try again, manually w
                  npm start
                    sdetweil @eightbit
                    @eightbit i couldn’t approve the message, system though it was spam
                    those are noise we can’t hide…
                    try npm start again
                    E 1 Reply Last reply Reply Quote 1
                    • E Offline
                      eightbit @sdetweil
                      @sdetweil that started up very quickly. Let me clean out my pm2 and re-run the autostart you suggested at the beginning.
                      • E Offline
                        eightbit
                        DUDE YOU ARE THE ABSOLUTE BOSS!
                        You may have even saved Christmas for my secret santa recipient. Thank you so much for helping me slog through this last piece of the puzzle. So it was a missing electron install after all? (And probably all my fuzzing around with the start up solutions)
                          sdetweil @eightbit
                          @eightbit yes… why it didn’t install, I have no clue…
                          but it also showed the chromium problem which I hadn’t seen before…
                          to restore the original package.json (with the correct start line) do
                          git checkout package.json
                          glad we could fix it !
