    Magic Mirror doesn't work after a boot
    27 Posts 2 Posters 9.7k Views 2 Watching
    • E Offline
      eightbit @sdetweil
      @sdetweil Yea I cleared out the systemd services I tried to enabled. They are disabled and stopped. I also tried an rc.local startup file to run the .sh file which never worked. I know that’s depreciated but desperate times and desperate measures lol.
        sdetweil @eightbit
        @eightbit what device is this… you are using my install script which launches
        run-start.sh
        this is reserved for armv6 devices…
        can u check the autostart
        did you do this??? (answer should be no)
        https://docs.magicmirror.builders/configuration/autostart.html#using-systemd-systemctl
          sdetweil @eightbit
          @eightbit also do a
          free -m
          see how big the swap space is and total memory
          • E Offline
            eightbit @sdetweil
            @sdetweil Raspberry Pi 3 Model B Rev 1.2
            I did try to use systemd but it did not work so I disabled and deleted all the systemd attempts.
            • E Offline
              eightbit @sdetweil
              secretsanta@raspberrypi:~ $ free -m
                             total        used        free      shared  buff/cache   available
              Mem:             921         265          94           6         561         594
              Swap:           1861           1        1860
                sdetweil @eightbit
                @eightbit can u show me the “start”: from package.json
                E 1 Reply Last reply Reply Quote 1
                • E Offline
                  eightbit @sdetweil
                     "start":"./run-start.sh $1",
                                 "server": "node ./serveronly",
                                 "install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
                                 "install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
                                 "install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                                 "install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                                 "postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installation finished successfully! \n\"",
                                 "test": "NODE_ENV=test jest -i --forceExit",
                                 "test:coverage": "NODE_ENV=test jest --coverage -i --verbose false --forceExit",
                                 "test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
                                 "test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
                                 "test:unit": "NODE_ENV=test jest --selectProjects unit",
                                 "test:prettier": "prettier . --check",
                                 "test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --confi>
                                 "test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
                                 "test:calendar": "node ./modules/default/calendar/debug.js",
                                 "config:check": "node js/check_config.js",
                                 "lint:prettier": "prettier . --write",
                                 "lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --confi>
                                 "lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
                                 "lint:staged": "lint-staged",
                                 "prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed."
                    sdetweil @eightbit
                    @eightbit
                    delete one of them and replace the other with
                    also do uname -a
                    E 2 Replies Last reply Reply Quote 1
                    • E Offline
                      eightbit @sdetweil
                      @sdetweil said in Magic Mirror doesn't work after a boot:
                      “start”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js”,
                              "name": "magicmirror",
                              "version": "2.25.0",
                              "description": "The open source modular smart mirror platform.",
                              "main": "js/electron.js",
                              "scripts": {
                              "repository": {
                                      "type": "git",
                                      "url": "git+https://github.com/MichMich/MagicMirror.git"
                      • E Offline
                        eightbit @sdetweil
                        Linux raspberrypi 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                          sdetweil @eightbit
                          @eightbit you didn’t need to delete all the rest of the scripts
                            sdetweil @eightbit
                            @eightbit ok, armv7 and memory >512… hm
                            can u send me the ~/install.log
                            I want to see why it picked the run-statrt approach…
                            same userid at gmail
                              sdetweil @eightbit
                              @eightbit thanks for the log… says electron did not install. hmm…
                              thus trying to use chromium…
                              does it start now ? pm2 or npm start?
                              • E Offline
                                eightbit @sdetweil
                                @sdetweil ```
                                secretsanta@raspberrypi:~/MagicMirror $ npm start
                                magicmirror@2.25.0 start
                                sh: 1: ./node_modules/.bin/electron: not found
                                  sdetweil @eightbit
                                  @eightbit ok…
                                  npm install electron@26.2.4
                                  and try again, manually w
                                  npm start
                                    sdetweil @eightbit
                                    @eightbit i couldn’t approve the message, system though it was spam
                                    those are noise we can’t hide…
                                    try npm start again
                                    • E Offline
                                      eightbit @sdetweil
                                      @sdetweil that started up very quickly. Let me clean out my pm2 and re-run the autostart you suggested at the beginning.
                                      • E Offline
                                        eightbit
                                        DUDE YOU ARE THE ABSOLUTE BOSS!
                                        You may have even saved Christmas for my secret santa recipient. Thank you so much for helping me slog through this last piece of the puzzle. So it was a missing electron install after all? (And probably all my fuzzing around with the start up solutions)
                                          sdetweil @eightbit
                                          @eightbit yes… why it didn’t install, I have no clue…
                                          but it also showed the chromium problem which I hadn’t seen before…
                                          to restore the original package.json (with the correct start line) do
                                          git checkout package.json
                                          glad we could fix it !
