    Magic Mirror doesn't work after a boot
    27 Posts 2 Posters 9.7k Views 2 Watching
    • E Offline
      eightbit @sdetweil
      @sdetweil Shoot. No luck! When I ran your script it loaded up and started perfectly and after the reboot it is hung on a white screen. In the logs it looks like it’s really trying to do something with the chromium browser but it just hangs and hangs. When it works on a pm2 start mm.sh (or using fixuppm2.sh) the log looks the same but then there are a couple lines after “starting chromium browser now”. I’ll post the log in another post.
      S E 2 Replies Last reply Reply Quote 0
        sdetweil @eightbit
        @eightbit I just forgot, did you remove the autostart setup u added in the services?
        • E Offline
          eightbit @eightbit
          /home/secretsanta/.pm2/logs/MagicMirror-error.log last 15 lines:
          /home/secretsanta/.pm2/logs/MagicMirror-out.log last 15 lines:
          0|MagicMir | [14.12.2023 07:44.23.049] [LOG] No helper found for module: alert.
          0|MagicMir | [14.12.2023 07:44.23.234] [LOG] Initializing new module helper ...
          0|MagicMir | [14.12.2023 07:44.23.248] [LOG] Module helper loaded: updatenotification
          0|MagicMir | [14.12.2023 07:44.46.958] [LOG] Initializing new module helper ...
          0|MagicMir | [14.12.2023 07:44.46.963] [LOG] Module helper loaded: MMM-GooglePhotos
          0|MagicMir | [14.12.2023 07:44.46.988] [LOG] All module helpers loaded.
          0|MagicMir | [14.12.2023 07:44.47.103] [LOG] Starting server on port 8080 ...
          0|MagicMir | [14.12.2023 07:44.47.496] [LOG] Server started ...
          0|MagicMir | [14.12.2023 07:44.47.499] [LOG] Connecting socket for: updatenotification
          0|MagicMir | [14.12.2023 07:44.47.503] [LOG] Starting module helper: updatenotification
          0|MagicMir | [14.12.2023 07:44.47.525] [LOG] Connecting socket for: MMM-GooglePhotos
          0|MagicMir | [14.12.2023 07:44.47.527] [LOG] Sockets connected & modules started ...
          0|MagicMir | [14.12.2023 07:44.47.529] [LOG]
          0|MagicMir | Ready to go! Please point your browser to: http://localhost:8080
          0|MagicMir | Starting chromium browser now, have patience, it takes a minute
          • E Offline
            eightbit @sdetweil
            @sdetweil Yea I cleared out the systemd services I tried to enabled. They are disabled and stopped. I also tried an rc.local startup file to run the .sh file which never worked. I know that’s depreciated but desperate times and desperate measures lol.
              sdetweil @eightbit
              @eightbit what device is this… you are using my install script which launches
              run-start.sh
              this is reserved for armv6 devices…
              can u check the autostart
              did you do this??? (answer should be no)
              https://docs.magicmirror.builders/configuration/autostart.html#using-systemd-systemctl
                sdetweil @eightbit
                @eightbit also do a
                free -m
                see how big the swap space is and total memory
                • E Offline
                  eightbit @sdetweil
                  @sdetweil Raspberry Pi 3 Model B Rev 1.2
                  I did try to use systemd but it did not work so I disabled and deleted all the systemd attempts.
                  • E Offline
                    eightbit @sdetweil
                    secretsanta@raspberrypi:~ $ free -m
                                   total        used        free      shared  buff/cache   available
                    Mem:             921         265          94           6         561         594
                    Swap:           1861           1        1860
                      sdetweil @eightbit
                      @eightbit can u show me the “start”: from package.json
                      E 1 Reply Last reply Reply Quote 1
                      • E Offline
                        eightbit @sdetweil
                           "start":"./run-start.sh $1",
                                       "server": "node ./serveronly",
                                       "install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
                                       "install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
                                       "install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                                       "install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                                       "postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installation finished successfully! \n\"",
                                       "test": "NODE_ENV=test jest -i --forceExit",
                                       "test:coverage": "NODE_ENV=test jest --coverage -i --verbose false --forceExit",
                                       "test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
                                       "test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
                                       "test:unit": "NODE_ENV=test jest --selectProjects unit",
                                       "test:prettier": "prettier . --check",
                                       "test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --confi>
                                       "test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
                                       "test:calendar": "node ./modules/default/calendar/debug.js",
                                       "config:check": "node js/check_config.js",
                                       "lint:prettier": "prettier . --write",
                                       "lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --confi>
                                       "lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
                                       "lint:staged": "lint-staged",
                                       "prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed."
                          sdetweil @eightbit
                          @eightbit
                          delete one of them and replace the other with
                          also do uname -a
                          E 2 Replies Last reply Reply Quote 1
                          • E Offline
                            eightbit @sdetweil
                            @sdetweil said in Magic Mirror doesn't work after a boot:
                            “start”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js”,
                                    "name": "magicmirror",
                                    "version": "2.25.0",
                                    "description": "The open source modular smart mirror platform.",
                                    "main": "js/electron.js",
                                    "scripts": {
                                    "repository": {
                                            "type": "git",
                                            "url": "git+https://github.com/MichMich/MagicMirror.git"
                            • E Offline
                              eightbit @sdetweil
                              Linux raspberrypi 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                                sdetweil @eightbit
                                @eightbit you didn’t need to delete all the rest of the scripts
                                  sdetweil @eightbit
                                  @eightbit ok, armv7 and memory >512… hm
                                  can u send me the ~/install.log
                                  I want to see why it picked the run-statrt approach…
                                  same userid at gmail
                                    sdetweil @eightbit
                                    @eightbit thanks for the log… says electron did not install. hmm…
                                    thus trying to use chromium…
                                    does it start now ? pm2 or npm start?
                                    • E Offline
                                      eightbit @sdetweil
                                      @sdetweil ```
                                      secretsanta@raspberrypi:~/MagicMirror $ npm start
                                      magicmirror@2.25.0 start
                                      sh: 1: ./node_modules/.bin/electron: not found
                                        sdetweil @eightbit
                                        @eightbit ok…
                                        npm install electron@26.2.4
                                        and try again, manually w
                                        npm start
                                          sdetweil @eightbit
                                          @eightbit i couldn’t approve the message, system though it was spam
                                          those are noise we can’t hide…
                                          try npm start again
                                          • E Offline
                                            eightbit @sdetweil
                                            @sdetweil that started up very quickly. Let me clean out my pm2 and re-run the autostart you suggested at the beginning.
