    Magic Mirror doesn't work after a boot
    27 Posts 2 Posters 9.4k Views 2 Watching
      sdetweil @eightbit
      @eightbit what device is this… you are using my install script which launches
      run-start.sh
      this is reserved for armv6 devices…
      can u check the autostart
      did you do this??? (answer should be no)
      https://docs.magicmirror.builders/configuration/autostart.html#using-systemd-systemctl
        sdetweil @eightbit
        @eightbit also do a
        free -m
        see how big the swap space is and total memory
        • E Offline
          eightbit @sdetweil
          @sdetweil Raspberry Pi 3 Model B Rev 1.2
          I did try to use systemd but it did not work so I disabled and deleted all the systemd attempts.
          • E Offline
            eightbit @sdetweil
            secretsanta@raspberrypi:~ $ free -m
                           total        used        free      shared  buff/cache   available
            Mem:             921         265          94           6         561         594
            Swap:           1861           1        1860
              sdetweil @eightbit
              @eightbit can u show me the “start”: from package.json
              E 1 Reply Last reply Reply Quote 1
              • E Offline
                eightbit @sdetweil
                   "start":"./run-start.sh $1",
                               "server": "node ./serveronly",
                               "install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
                               "install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
                               "install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                               "install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                               "postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installation finished successfully! \n\"",
                               "test": "NODE_ENV=test jest -i --forceExit",
                               "test:coverage": "NODE_ENV=test jest --coverage -i --verbose false --forceExit",
                               "test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
                               "test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
                               "test:unit": "NODE_ENV=test jest --selectProjects unit",
                               "test:prettier": "prettier . --check",
                               "test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --confi>
                               "test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
                               "test:calendar": "node ./modules/default/calendar/debug.js",
                               "config:check": "node js/check_config.js",
                               "lint:prettier": "prettier . --write",
                               "lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --confi>
                               "lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
                               "lint:staged": "lint-staged",
                               "prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed."
                  sdetweil @eightbit
                  @eightbit
                  delete one of them and replace the other with
                  also do uname -a
                  E 2 Replies Last reply Reply Quote 1
                  • E Offline
                    eightbit @sdetweil
                    @sdetweil said in Magic Mirror doesn't work after a boot:
                    “start”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js”,
                            "name": "magicmirror",
                            "version": "2.25.0",
                            "description": "The open source modular smart mirror platform.",
                            "main": "js/electron.js",
                            "scripts": {
                            "repository": {
                                    "type": "git",
                                    "url": "git+https://github.com/MichMich/MagicMirror.git"
                    • E Offline
                      eightbit @sdetweil
                      Linux raspberrypi 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                        sdetweil @eightbit
                        @eightbit you didn’t need to delete all the rest of the scripts
                          sdetweil @eightbit
                          @eightbit ok, armv7 and memory >512… hm
                          can u send me the ~/install.log
                          I want to see why it picked the run-statrt approach…
                          same userid at gmail
                            sdetweil @eightbit
                            @eightbit thanks for the log… says electron did not install. hmm…
                            thus trying to use chromium…
                            does it start now ? pm2 or npm start?
                            • E Offline
                              eightbit @sdetweil
                              @sdetweil ```
                              secretsanta@raspberrypi:~/MagicMirror $ npm start
                              magicmirror@2.25.0 start
                              sh: 1: ./node_modules/.bin/electron: not found
                                sdetweil @eightbit
                                @eightbit ok…
                                npm install electron@26.2.4
                                and try again, manually w
                                npm start
                                  sdetweil @eightbit
                                  @eightbit i couldn’t approve the message, system though it was spam
                                  those are noise we can’t hide…
                                  try npm start again
                                  • E Offline
                                    eightbit @sdetweil
                                    @sdetweil that started up very quickly. Let me clean out my pm2 and re-run the autostart you suggested at the beginning.
                                    • E Offline
                                      eightbit
                                      DUDE YOU ARE THE ABSOLUTE BOSS!
                                      You may have even saved Christmas for my secret santa recipient. Thank you so much for helping me slog through this last piece of the puzzle. So it was a missing electron install after all? (And probably all my fuzzing around with the start up solutions)
                                        sdetweil @eightbit
                                        @eightbit yes… why it didn’t install, I have no clue…
                                        but it also showed the chromium problem which I hadn’t seen before…
                                        to restore the original package.json (with the correct start line) do
                                        git checkout package.json
                                        glad we could fix it !
