    Magic Mirror doesn't work after a boot
    27 Posts 2 Posters 8.1k Views 2 Watching
      sdetweil @eightbit
      @eightbit its only called ‘fix’ cause during my install script you can add pm2 support, or not… so its a separate script if u change your mind later
      • E Offline
        eightbit @sdetweil
        @sdetweil Shoot. No luck! When I ran your script it loaded up and started perfectly and after the reboot it is hung on a white screen. In the logs it looks like it’s really trying to do something with the chromium browser but it just hangs and hangs. When it works on a pm2 start mm.sh (or using fixuppm2.sh) the log looks the same but then there are a couple lines after “starting chromium browser now”. I’ll post the log in another post.
        S E 2 Replies Last reply Reply Quote 0
          sdetweil @eightbit
          @eightbit I just forgot, did you remove the autostart setup u added in the services?
          • E Offline
            eightbit @eightbit
            /home/secretsanta/.pm2/logs/MagicMirror-error.log last 15 lines:
            /home/secretsanta/.pm2/logs/MagicMirror-out.log last 15 lines:
            0|MagicMir | [14.12.2023 07:44.23.049] [LOG] No helper found for module: alert.
            0|MagicMir | [14.12.2023 07:44.23.234] [LOG] Initializing new module helper ...
            0|MagicMir | [14.12.2023 07:44.23.248] [LOG] Module helper loaded: updatenotification
            0|MagicMir | [14.12.2023 07:44.46.958] [LOG] Initializing new module helper ...
            0|MagicMir | [14.12.2023 07:44.46.963] [LOG] Module helper loaded: MMM-GooglePhotos
            0|MagicMir | [14.12.2023 07:44.46.988] [LOG] All module helpers loaded.
            0|MagicMir | [14.12.2023 07:44.47.103] [LOG] Starting server on port 8080 ...
            0|MagicMir | [14.12.2023 07:44.47.496] [LOG] Server started ...
            0|MagicMir | [14.12.2023 07:44.47.499] [LOG] Connecting socket for: updatenotification
            0|MagicMir | [14.12.2023 07:44.47.503] [LOG] Starting module helper: updatenotification
            0|MagicMir | [14.12.2023 07:44.47.525] [LOG] Connecting socket for: MMM-GooglePhotos
            0|MagicMir | [14.12.2023 07:44.47.527] [LOG] Sockets connected & modules started ...
            0|MagicMir | [14.12.2023 07:44.47.529] [LOG]
            0|MagicMir | Ready to go! Please point your browser to: http://localhost:8080
            0|MagicMir | Starting chromium browser now, have patience, it takes a minute
            • E Offline
              eightbit @sdetweil
              @sdetweil Yea I cleared out the systemd services I tried to enabled. They are disabled and stopped. I also tried an rc.local startup file to run the .sh file which never worked. I know that’s depreciated but desperate times and desperate measures lol.
                sdetweil @eightbit
                @eightbit what device is this… you are using my install script which launches
                run-start.sh
                this is reserved for armv6 devices…
                can u check the autostart
                did you do this??? (answer should be no)
                https://docs.magicmirror.builders/configuration/autostart.html#using-systemd-systemctl
                  sdetweil @eightbit
                  @eightbit also do a
                  free -m
                  see how big the swap space is and total memory
                  • E Offline
                    eightbit @sdetweil
                    @sdetweil Raspberry Pi 3 Model B Rev 1.2
                    I did try to use systemd but it did not work so I disabled and deleted all the systemd attempts.
                    • E Offline
                      eightbit @sdetweil
                      secretsanta@raspberrypi:~ $ free -m
                                     total        used        free      shared  buff/cache   available
                      Mem:             921         265          94           6         561         594
                      Swap:           1861           1        1860
                        sdetweil @eightbit
                        @eightbit can u show me the “start”: from package.json
                        E 1 Reply Last reply Reply Quote 1
