    Magic Mirror doesn't work after a boot
    27 Posts 2 Posters 8.2k Views 2 Watching
    • E Offline
      eightbit @sdetweil
      @sdetweil Should I delete the mm.sh in my home dir before i run your pm2 fix?
        sdetweil @eightbit
        @eightbit no… if it all works then later yes
          sdetweil @eightbit
          @eightbit its only called ‘fix’ cause during my install script you can add pm2 support, or not… so its a separate script if u change your mind later
          • E Offline
            eightbit @sdetweil
            @sdetweil Shoot. No luck! When I ran your script it loaded up and started perfectly and after the reboot it is hung on a white screen. In the logs it looks like it’s really trying to do something with the chromium browser but it just hangs and hangs. When it works on a pm2 start mm.sh (or using fixuppm2.sh) the log looks the same but then there are a couple lines after “starting chromium browser now”. I’ll post the log in another post.
            S E 2 Replies Last reply Reply Quote 0
              sdetweil @eightbit
              @eightbit I just forgot, did you remove the autostart setup u added in the services?
              • E Offline
                eightbit @eightbit
                /home/secretsanta/.pm2/logs/MagicMirror-error.log last 15 lines:
                /home/secretsanta/.pm2/logs/MagicMirror-out.log last 15 lines:
                0|MagicMir | [14.12.2023 07:44.23.049] [LOG] No helper found for module: alert.
                0|MagicMir | [14.12.2023 07:44.23.234] [LOG] Initializing new module helper ...
                0|MagicMir | [14.12.2023 07:44.23.248] [LOG] Module helper loaded: updatenotification
                0|MagicMir | [14.12.2023 07:44.46.958] [LOG] Initializing new module helper ...
                0|MagicMir | [14.12.2023 07:44.46.963] [LOG] Module helper loaded: MMM-GooglePhotos
                0|MagicMir | [14.12.2023 07:44.46.988] [LOG] All module helpers loaded.
                0|MagicMir | [14.12.2023 07:44.47.103] [LOG] Starting server on port 8080 ...
                0|MagicMir | [14.12.2023 07:44.47.496] [LOG] Server started ...
                0|MagicMir | [14.12.2023 07:44.47.499] [LOG] Connecting socket for: updatenotification
                0|MagicMir | [14.12.2023 07:44.47.503] [LOG] Starting module helper: updatenotification
                0|MagicMir | [14.12.2023 07:44.47.525] [LOG] Connecting socket for: MMM-GooglePhotos
                0|MagicMir | [14.12.2023 07:44.47.527] [LOG] Sockets connected & modules started ...
                0|MagicMir | [14.12.2023 07:44.47.529] [LOG]
                0|MagicMir | Ready to go! Please point your browser to: http://localhost:8080
                0|MagicMir | Starting chromium browser now, have patience, it takes a minute
                • E Offline
                  eightbit @sdetweil
                  @sdetweil Yea I cleared out the systemd services I tried to enabled. They are disabled and stopped. I also tried an rc.local startup file to run the .sh file which never worked. I know that’s depreciated but desperate times and desperate measures lol.
                    sdetweil @eightbit
                    @eightbit what device is this… you are using my install script which launches
                    run-start.sh
                    this is reserved for armv6 devices…
                    can u check the autostart
                    did you do this??? (answer should be no)
                    https://docs.magicmirror.builders/configuration/autostart.html#using-systemd-systemctl
                      sdetweil @eightbit
                      @eightbit also do a
                      free -m
                      see how big the swap space is and total memory
                      • E Offline
                        eightbit @sdetweil
                        @sdetweil Raspberry Pi 3 Model B Rev 1.2
                        I did try to use systemd but it did not work so I disabled and deleted all the systemd attempts.
