    Magic Mirror doesn't work after a boot
    27 Posts 2 Posters 8.9k Views 2 Watching
      sdetweil @eightbit
      @eightbit I just forgot, did you remove the autostart setup u added in the services?
      • E Offline
        eightbit @eightbit
        /home/secretsanta/.pm2/logs/MagicMirror-error.log last 15 lines:
        /home/secretsanta/.pm2/logs/MagicMirror-out.log last 15 lines:
        0|MagicMir | [14.12.2023 07:44.23.049] [LOG] No helper found for module: alert.
        0|MagicMir | [14.12.2023 07:44.23.234] [LOG] Initializing new module helper ...
        0|MagicMir | [14.12.2023 07:44.23.248] [LOG] Module helper loaded: updatenotification
        0|MagicMir | [14.12.2023 07:44.46.958] [LOG] Initializing new module helper ...
        0|MagicMir | [14.12.2023 07:44.46.963] [LOG] Module helper loaded: MMM-GooglePhotos
        0|MagicMir | [14.12.2023 07:44.46.988] [LOG] All module helpers loaded.
        0|MagicMir | [14.12.2023 07:44.47.103] [LOG] Starting server on port 8080 ...
        0|MagicMir | [14.12.2023 07:44.47.496] [LOG] Server started ...
        0|MagicMir | [14.12.2023 07:44.47.499] [LOG] Connecting socket for: updatenotification
        0|MagicMir | [14.12.2023 07:44.47.503] [LOG] Starting module helper: updatenotification
        0|MagicMir | [14.12.2023 07:44.47.525] [LOG] Connecting socket for: MMM-GooglePhotos
        0|MagicMir | [14.12.2023 07:44.47.527] [LOG] Sockets connected & modules started ...
        0|MagicMir | [14.12.2023 07:44.47.529] [LOG]
        0|MagicMir | Ready to go! Please point your browser to: http://localhost:8080
        0|MagicMir | Starting chromium browser now, have patience, it takes a minute
        • E Offline
          eightbit @sdetweil
          @sdetweil Yea I cleared out the systemd services I tried to enabled. They are disabled and stopped. I also tried an rc.local startup file to run the .sh file which never worked. I know that’s depreciated but desperate times and desperate measures lol.
            sdetweil @eightbit
            @eightbit what device is this… you are using my install script which launches
            run-start.sh
            this is reserved for armv6 devices…
            can u check the autostart
            did you do this??? (answer should be no)
            https://docs.magicmirror.builders/configuration/autostart.html#using-systemd-systemctl
              sdetweil @eightbit
              @eightbit also do a
              free -m
              see how big the swap space is and total memory
              • E Offline
                eightbit @sdetweil
                @sdetweil Raspberry Pi 3 Model B Rev 1.2
                I did try to use systemd but it did not work so I disabled and deleted all the systemd attempts.
                • E Offline
                  eightbit @sdetweil
                  secretsanta@raspberrypi:~ $ free -m
                                 total        used        free      shared  buff/cache   available
                  Mem:             921         265          94           6         561         594
                  Swap:           1861           1        1860
                    sdetweil @eightbit
                    @eightbit can u show me the “start”: from package.json
                    E 1 Reply Last reply Reply Quote 1
                    • E Offline
                      eightbit @sdetweil
                         "start":"./run-start.sh $1",
                                     "server": "node ./serveronly",
                                     "install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
                                     "install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
                                     "install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                                     "install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                                     "postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installation finished successfully! \n\"",
                                     "test": "NODE_ENV=test jest -i --forceExit",
                                     "test:coverage": "NODE_ENV=test jest --coverage -i --verbose false --forceExit",
                                     "test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
                                     "test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
                                     "test:unit": "NODE_ENV=test jest --selectProjects unit",
                                     "test:prettier": "prettier . --check",
                                     "test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --confi>
                                     "test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
                                     "test:calendar": "node ./modules/default/calendar/debug.js",
                                     "config:check": "node js/check_config.js",
                                     "lint:prettier": "prettier . --write",
                                     "lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --confi>
                                     "lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
                                     "lint:staged": "lint-staged",
                                     "prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed."
                        sdetweil @eightbit
                        @eightbit
                        delete one of them and replace the other with
                        also do uname -a
                        E 2 Replies Last reply Reply Quote 1
                        • E Offline
                          eightbit @sdetweil
                          @sdetweil said in Magic Mirror doesn't work after a boot:
                          “start”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js”,
                                  "name": "magicmirror",
                                  "version": "2.25.0",
                                  "description": "The open source modular smart mirror platform.",
                                  "main": "js/electron.js",
                                  "scripts": {
                                  "repository": {
                                          "type": "git",
                                          "url": "git+https://github.com/MichMich/MagicMirror.git"
                          • E Offline
                            eightbit @sdetweil
                            Linux raspberrypi 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                              sdetweil @eightbit
                              @eightbit you didn’t need to delete all the rest of the scripts
                                sdetweil @eightbit
                                @eightbit ok, armv7 and memory >512… hm
                                can u send me the ~/install.log
                                I want to see why it picked the run-statrt approach…
                                same userid at gmail
                                  sdetweil @eightbit
                                  @eightbit thanks for the log… says electron did not install. hmm…
                                  thus trying to use chromium…
                                  does it start now ? pm2 or npm start?
                                  • E Offline
                                    eightbit @sdetweil
                                    @sdetweil ```
                                    secretsanta@raspberrypi:~/MagicMirror $ npm start
                                    magicmirror@2.25.0 start
                                    sh: 1: ./node_modules/.bin/electron: not found
                                      sdetweil @eightbit
                                      @eightbit ok…
                                      npm install electron@26.2.4
                                      and try again, manually w
                                      npm start
                                        sdetweil @eightbit
                                        @eightbit i couldn’t approve the message, system though it was spam
                                        those are noise we can’t hide…
                                        try npm start again
                                        • E Offline
                                          eightbit @sdetweil
                                          @sdetweil that started up very quickly. Let me clean out my pm2 and re-run the autostart you suggested at the beginning.
                                          • E Offline
                                            eightbit
                                            DUDE YOU ARE THE ABSOLUTE BOSS!
                                            You may have even saved Christmas for my secret santa recipient. Thank you so much for helping me slog through this last piece of the puzzle. So it was a missing electron install after all? (And probably all my fuzzing around with the start up solutions)
