maximumEntries & fetchInterval in config.js aren't working, default values in calendar.js override them
10 Posts 2 Posters 1.5k Views 2 Watching
  • Z Offline
    ZiggidyZ
    Good day to everyone! I am a VERY new user to Magic Mirror. I tried getting it working on a Raspberry Pi Zero W a few months ago to no avail and gave up. I recently got a number of Raspberry Pi Zero 2 W units, and just got Magic Mirror working this week for the first time ever.
    While messing about with the calendar, I stumbled upon an issue, I don’t know if it is specific to Magic Mirror in general, or with my specific hardware & software version.
    What I found is that SOME of the variables in the config.js file have NO effect, instead using the default values configured in the calendar.js file. I found that I am NOT able to configure SOME of the variables under the module section, most specifically maximumEntries & fetchInterval. The ONLY thing I have adjusted in the config.js file is duplicating the calendar module, and adjusting the max entries and fetch int to see if I could find out why default was overriding what is configured.
    Other things in the config do work like position and header, though they aren’t defined in the calendar.js file. The url is, but that I CAN change without issue. For grins I commented out the fetchInterval from the calendar.js, and the fetch runs continuously to the point that the calendar instances disappear. If only the maxEntries is commented out, the config.js entries STILL have zero impact.
    I am hoping this is something I am just overlooking that is a DUH kind of thing as a new user.
    Hardware:
    Hardware        : BCM2835
    Revision        : 902120
    Serial          : 000000005664a900
    Model           : Raspberry Pi Zero 2 W Rev 1.0
    Software:
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    Config.js
                            header: "US Holidays",
                            maximumEntries: "2",
                            fetchInterval: 604800000,
                                                    symbol: "calendar-check",
                                                    url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                            header: "TEST",
                            maximumEntries:5,
                            fetchInterval: 1000,
    Default configs from calendar.js
    	// Define module defaults
    	defaults: {
    		maximumEntries: 10, // Total Maximum Entries
    		fetchInterval: 60 * 60 * 1000, // Update every hour
    Console output after MM is started MANUALLY:
    [20.12.2023 00:30.41.830] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics - Interval: 3600000
    [20.12.2023 00:30.44.465] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics - Interval: 3600000
    S 1 Reply Last reply Dec 20, 2023, 1:13 PM Reply Quote 0
    • S Away
      sdetweil @ZiggidyZ
      @ZiggidyZ no. fetchInterval is also allowed per calendar
      above calendars[], it is for all calendars
      inside A calendar entry it is for that one calendar retrieval only.
      this allows the holiday schedule to be long and others to be shorter
      Z 1 Reply Last reply Dec 20, 2023, 8:29 PM Reply Quote 1
      • S Away
        sdetweil @ZiggidyZ
        @ZiggidyZ all the configuration options of a module goes inside the config:{…} section. these are instructions to the module
        fetchInterval
        maximunEntries
        the definition of the module and it’s position go outside it’s config section, these are instruction to MagicMirror
        it’s name
        position
        header
        • Z Offline
          ZiggidyZ
          Thank you for confirming that for me. That was an oversight on my part in my very late hours working on it this morning. I apologize for the boneheaded lack of observation. I read the documents, but was basing my findings on where I originally found the fetchInterval in the sample config. I moved it outside the config, didn’t think about moving it inside config but outside calendar.
          That all said, there IS AN ISSUE with a file on the github. The file config.js.sample has the fetchInterval in the wrong location. In it’s present location, the sample config hits the Holiday calendar once an hour rather than once a week.
          Here is a direct copy and paste from gitHub file:
          To fix the issue, LINE - 58 - fetchInterval: 7 * 24 * 60 * 60 * 1000, should be relocated to LINE 56
          calendars: [ should be moved down to LINE 57
          S 1 Reply Last reply Dec 20, 2023, 6:19 PM Reply Quote 0
          • S Away
            sdetweil @ZiggidyZ
            • Z Offline
              ZiggidyZ @sdetweil
              @sdetweil Thank you again for the information, but with that being the case, for me it is NOT working inside the calendar entry. I spun up a new Magic Mirror on identical hardware and software this morning, with the ONLY change to MM being the copy the config.js.sample to config.js, then running, and it was defaulting to 3.6 million ms which is 1 hour, rather than the 604.8 million ms which is 168 hours or 1 week.
              Here is essentially what I did:
              Raspbian - Raspberry PI OS Legacy 32 bit - configured with ONLY new username and Wifi credentials
              Enable VNC
              sudo apt update
              sudo apt upgrade
              sudo apt install -y ca-certificates curl gnupg git
              sudo mkdir -p /etc/apt/keyrings
              curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
              NODE_MAJOR=20
              echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_$NODE_MAJOR.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
              sudo apt update
              sudo apt install nodejs -y
              git clone https://github.com/MichMich/MagicMirror
              cd MagicMirror/
              npm run install-mm
              sudo npm install -g npm@10.2.5
              cp config/config.js.sample config/config.js
              sudo dphys-swapfile swapoff
              sudo nano /etc/dphys-swapfile
              CONF_SWAPSIZE=1024
              sudo dphys-swapfile setup
              sudo dphys-swapfile swapon
              npm run start
              Here is the full output of my test, key is the line just a few from the end:
              Again, this is running without modifying ANY of the files, it is just as it cloned it from Git. Is this a quirk on my hardware, or is the fetchInterval not currently working under the calendar.
              xxxxxxxx@raspberrypi:~ $ ls -l
              total 36
              drwxr-xr-x 2 xxxxxxxx xxxxxxxx 4096 Dec  4 20:48 Bookshelf
              drwxr-xr-x 2 xxxxxxxx xxxxxxxx 4096 Dec  4 21:08 Desktop
              drwxr-xr-x 2 xxxxxxxx xxxxxxxx 4096 Dec  4 21:08 Documents
              drwxr-xr-x 2 xxxxxxxx xxxxxxxx 4096 Dec  4 21:08 Downloads
              drwxr-xr-x 2 xxxxxxxx xxxxxxxx 4096 Dec  4 21:08 Music
              drwxr-xr-x 2 xxxxxxxx xxxxxxxx 4096 Dec  4 21:08 Pictures
              drwxr-xr-x 2 xxxxxxxx xxxxxxxx 4096 Dec  4 21:08 Public
              drwxr-xr-x 2 xxxxxxxx xxxxxxxx 4096 Dec  4 21:08 Templates
              drwxr-xr-x 2 xxxxxxxx xxxxxxxx 4096 Dec  4 21:08 Videos
              xxxxxxxx@raspberrypi:~ $ sudo apt update
              Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
              Reading package lists... Done
              Building dependency tree... Done
              6 packages can be upgraded. Run 'apt list --upgradable' to see them.
              xxxxxxxx@raspberrypi:~ $ sudo apt upgrade
              Calculating upgrade... Done
              The following package was automatically installed and is no longer required:
                libfuse2
              Use 'sudo apt autoremove' to remove it.
              The following packages will be upgraded:
                chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra xserver-common xserver-xorg-core xwayland
              6 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              Need to get 126 MB of archives.
              After this operation, 1,224 kB of additional disk space will be used.
              Do you want to continue? [Y/n] y
              Get:1 http://archive.raspberrypi.org/debian bullseye/main armhf chromium-browser-l10n all 120.0.6099.102-rpt1 [6,436 kB]
              Get:2 http://archive.raspberrypi.org/debian bullseye/main armhf chromium-browser armhf 120.0.6099.102-rpt1 [110 MB]
              Get:3 http://archive.raspberrypi.org/debian bullseye/main armhf chromium-codecs-ffmpeg-extra armhf 120.0.6099.102-rpt1 [1,024 kB]
              Get:4 http://archive.raspberrypi.org/debian bullseye/main armhf xserver-common all 2:1.20.11-1+rpt3+deb11u10 [2,285 kB]
              Get:5 http://archive.raspberrypi.org/debian bullseye/main armhf xserver-xorg-core armhf 2:1.20.11-1+rpt3+deb11u10 [3,352 kB]
              Get:6 http://archive.raspberrypi.org/debian bullseye/main armhf xwayland armhf 2:1.20.11-1+rpt3+deb11u10 [2,970 kB]
              Fetched 126 MB in 42s (3,035 kB/s)
              Reading changelogs... Done
              (Reading database ... 106663 files and directories currently installed.)
              Preparing to unpack .../0-chromium-browser-l10n_120.0.6099.102-rpt1_all.deb ...
              Unpacking chromium-browser-l10n (120.0.6099.102-rpt1) over (119.0.6045.171-rpt1) ...
              Preparing to unpack .../1-chromium-browser_120.0.6099.102-rpt1_armhf.deb ...
              Unpacking chromium-browser (120.0.6099.102-rpt1) over (119.0.6045.171-rpt1) ...
              Preparing to unpack .../2-chromium-codecs-ffmpeg-extra_120.0.6099.102-rpt1_armhf.deb ...
              Unpacking chromium-codecs-ffmpeg-extra (120.0.6099.102-rpt1) over (119.0.6045.171-rpt1) ...
              Preparing to unpack .../3-xserver-common_2%3a1.20.11-1+rpt3+deb11u10_all.deb ...
              Unpacking xserver-common (2:1.20.11-1+rpt3+deb11u10) over (2:1.20.11-1+rpt3+deb11u8) ...
              Preparing to unpack .../4-xserver-xorg-core_2%3a1.20.11-1+rpt3+deb11u10_armhf.deb ...
              Unpacking xserver-xorg-core (2:1.20.11-1+rpt3+deb11u10) over (2:1.20.11-1+rpt3+deb11u8) ...
              Preparing to unpack .../5-xwayland_2%3a1.20.11-1+rpt3+deb11u10_armhf.deb ...
              Unpacking xwayland (2:1.20.11-1+rpt3+deb11u10) over (2:1.20.11-1+rpt3+deb11u8) ...
              Setting up chromium-codecs-ffmpeg-extra (120.0.6099.102-rpt1) ...
              Setting up chromium-browser (120.0.6099.102-rpt1) ...
              Setting up chromium-browser-l10n (120.0.6099.102-rpt1) ...
              Setting up xserver-common (2:1.20.11-1+rpt3+deb11u10) ...
              Setting up xwayland (2:1.20.11-1+rpt3+deb11u10) ...
              Setting up xserver-xorg-core (2:1.20.11-1+rpt3+deb11u10) ...
              Processing triggers for mailcap (3.69) ...
              Processing triggers for desktop-file-utils (0.26-1) ...
              Processing triggers for hicolor-icon-theme (0.17-2) ...
              Processing triggers for gnome-menus (3.36.0-1) ...
              Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...
              Processing triggers for man-db (2.9.4-2) ...
              xxxxxxxx@raspberrypi:~ $ sudo apt-get install -y ca-certificates curl gnupg git
              ca-certificates is already the newest version (20210119).
              curl is already the newest version (7.74.0-1.3+deb11u10).
              git is already the newest version (1:2.30.2-1+deb11u2).
              gnupg is already the newest version (2.2.27-2+deb11u2).
                libfuse2
              xxxxxxxx@raspberrypi:~ $ sudo mkdir -p /etc/apt/keyrings
              xxxxxxxx@raspberrypi:~ $ curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
              xxxxxxxx@raspberrypi:~ $ NODE_MAJOR=20
              xxxxxxxx@raspberrypi:~ $ echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_$NODE_MAJOR.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
              deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
              Get:1 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
              Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
              Get:4 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [4,508 B]
              Fetched 16.6 kB in 2s (9,336 B/s)
              All packages are up to date.
              xxxxxxxx@raspberrypi:~ $ sudo apt install nodejs -y
                libfuse2
              The following NEW packages will be installed:
                nodejs
              0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
              Need to get 28.1 MB of archives.
              After this operation, 185 MB of additional disk space will be used.
              Get:1 https://deb.nodesource.com/node_20.x nodistro/main armhf nodejs armhf 20.10.0-1nodesource1 [28.1 MB]
              Fetched 28.1 MB in 7s (4,298 kB/s)
              Selecting previously unselected package nodejs.
              Preparing to unpack .../nodejs_20.10.0-1nodesource1_armhf.deb ...
              Unpacking nodejs (20.10.0-1nodesource1) ...
              Setting up nodejs (20.10.0-1nodesource1) ...
              total 36
              xxxxxxxx@raspberrypi:~ $ git clone https://github.com/MichMich/MagicMirror
              Cloning into 'MagicMirror'...
              remote: Enumerating objects: 25974, done.
              remote: Counting objects: 100% (332/332), done.
              remote: Compressing objects: 100% (184/184), done.
              remote: Total 25974 (delta 162), reused 276 (delta 128), pack-reused 25642
              Receiving objects: 100% (25974/25974), 21.84 MiB | 3.61 MiB/s, done.
              Resolving deltas: 100% (16046/16046), done.
              xxxxxxxx@raspberrypi:~ $ cd MagicMirror/
              xxxxxxxx@raspberrypi:~/MagicMirror $
              xxxxxxxx@raspberrypi:~/MagicMirror $ npm run install-mm
              > magicmirror@2.25.0 install-mm
              > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
              npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
              > magicmirror@2.25.0 postinstall
              > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
              > magicmirror@2.25.0 install-vendor
              > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
              added 10 packages in 58s
              > magicmirror@2.25.0 install-fonts
              > echo "Installing fonts ...
              > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
              added 2 packages in 5s
              > magicmirror@2.25.0 prepare
              > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
              no husky installed.
              added 334 packages in 6m
              npm notice
              npm notice New patch version of npm available! 10.2.3 -> 10.2.5
              npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.2.5
              npm notice Run npm install -g npm@10.2.5 to update!
              npm notice
              xxxxxxxx@raspberrypi:~/MagicMirror $ sudo npm install -g npm@10.2.5
              removed 11 packages, and changed 44 packages in 20s
              28 packages are looking for funding
                run `npm fund` for details
              xxxxxxxx@raspberrypi:~/MagicMirror $ cp config/config.js.sample config/config.js
              xxxxxxxx@raspberrypi:~/MagicMirror $ sudo dphys-swapfile swapoff
              xxxxxxxx@raspberrypi:~/MagicMirror $ sudo nano /etc/dphys-swapfile
              xxxxxxxx@raspberrypi:~/MagicMirror $ sudo dphys-swapfile setup
              want /var/swap=1024MByte, checking existing: deleting wrong size file (104857600), generating swapfile ... of 1024MBytes
              xxxxxxxx@raspberrypi:~/MagicMirror $ sudo dphys-swapfile swapon
              xxxxxxxx@raspberrypi:~/MagicMirror $ npm run start
              > magicmirror@2.25.0 start
              [20.12.2023 10:38.28.775] [LOG]   Starting MagicMirror: v2.25.0
              [20.12.2023 10:38.28.794] [LOG]   Loading config ...
              [20.12.2023 10:38.28.803] [DEBUG] config template file not exists, no envsubst
              [20.12.2023 10:38.28.826] [LOG]   Loading module helpers ...
              [20.12.2023 10:38.28.832] [LOG]   No helper found for module: alert.
              [20.12.2023 10:38.28.914] [LOG]   Initializing new module helper ...
              [20.12.2023 10:38.28.916] [LOG]   Module helper loaded: updatenotification
              [20.12.2023 10:38.28.924] [LOG]   No helper found for module: clock.
              [20.12.2023 10:38.29.661] [LOG]   Initializing new module helper ...
              [20.12.2023 10:38.29.664] [LOG]   Module helper loaded: calendar
              [20.12.2023 10:38.29.669] [LOG]   No helper found for module: compliments.
              [20.12.2023 10:38.29.673] [LOG]   No helper found for module: weather.
              [20.12.2023 10:38.30.106] [LOG]   Initializing new module helper ...
              [20.12.2023 10:38.30.107] [LOG]   Module helper loaded: newsfeed
              [20.12.2023 10:38.30.108] [LOG]   All module helpers loaded.
              [20.12.2023 10:38.30.132] [LOG]   Starting server on port 8080 ...
              [20.12.2023 10:38.33.155] [LOG]   Server started ...
              [20.12.2023 10:38.33.158] [LOG]   Connecting socket for: updatenotification
              [20.12.2023 10:38.33.160] [LOG]   Starting module helper: updatenotification
              [20.12.2023 10:38.33.162] [LOG]   Connecting socket for: calendar
              [20.12.2023 10:38.33.163] [LOG]   Starting node helper for: calendar
              [20.12.2023 10:38.33.164] [LOG]   Connecting socket for: newsfeed
              [20.12.2023 10:38.33.166] [LOG]   Starting node helper for: newsfeed
              [20.12.2023 10:38.33.167] [LOG]   Sockets connected & modules started ...
              [20.12.2023 10:38.33.488] [LOG]   Launching application.
              [2832:1220/103835.520076:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
              MESA-LOADER: failed to retrieve device information
              ../../buildtools/third_party/libc++/trunk/include/vector:1473: assertion __n < size() failed: vector[] index out of bounds[2832:1220/103909.594196:ERROR:gpu_process_host.cc(957)] GPU process exited unexpectedly: exit_code=6
              [2901:1220/103920.340951:ERROR:shared_image_manager.cc(217)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
              [2901:1220/103921.092737:ERROR:shared_image_manager.cc(217)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
              [2901:1220/103921.108810:ERROR:shared_image_manager.cc(217)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
              [2901:1220/103921.123298:ERROR:shared_image_manager.cc(217)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
              [2901:1220/103921.139159:ERROR:shared_image_manager.cc(217)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
              [2901:1220/103921.155662:ERROR:shared_image_manager.cc(217)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
              [2901:1220/103921.171791:ERROR:shared_image_manager.cc(217)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
              [2901:1220/103921.186838:ERROR:shared_image_manager.cc(217)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
              [2901:1220/103921.202814:ERROR:shared_image_manager.cc(217)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
              [2901:1220/103921.218720:ERROR:shared_image_manager.cc(217)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
              [2901:1220/103921.234435:ERROR:shared_image_manager.cc(217)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
              [2901:1220/103921.248651:ERROR:shared_image_manager.cc(217)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
              [2901:1220/103921.277456:ERROR:shared_image_manager.cc(217)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
              [2901:1220/103921.288642:ERROR:shared_image_manager.cc(217)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
              ../../buildtools/third_party/libc++/trunk/include/vector:1473: assertion __n < size() failed: vector[] index out of bounds[2832:1220/103926.104153:ERROR:gpu_process_host.cc(957)] GPU process exited unexpectedly: exit_code=6
              [2876:1220/103933.639804:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
              ../../buildtools/third_party/libc++/trunk/include/vector:1473: assertion __n < size() failed: vector[] index out of bounds[2832:1220/103942.045012:ERROR:gpu_process_host.cc(957)] GPU process exited unexpectedly: exit_code=6
              [20.12.2023 10:40.52.148] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics - Interval: 3600000
              [20.12.2023 10:40.55.368] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
              [20.12.2023 10:40.55.898] [INFO]  Checking git for module: MagicMirror
              [20.12.2023 10:41.13.460] [INFO]  Calendar-Fetcher: Broadcasting 13 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
              [20.12.2023 10:41.18.983] [INFO]  Newsfeed-Fetcher: Broadcasting 25 items.
              ^C^C^C^C/home/xxxxxxxx/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
              xxxxxxxx@raspberrypi:~/MagicMirror $ ^C
              Also, for clarity in case I am not communicating it correctly:
              DOES NOT work:
              DOES work:
              S 1 Reply Last reply Dec 20, 2023, 9:27 PM Reply Quote 0
              • S Away
                sdetweil @ZiggidyZ
                @ZiggidyZ well, the code says
                but it’s never set!
                Z 1 Reply Last reply Dec 20, 2023, 11:51 PM Reply Quote 0
                • Z Offline
                  ZiggidyZ @sdetweil
                  I am not 100% positive what that snippet of code means, but after an hour of googling, it sets fetchInterval to whatever is set in the config OR (if that is empty) use the default value in this file.
                  Anyhow, my issue has been solved, I do thank you for your assistance, I really appreciate it!
                  If there is anything you need me to provide regarding the issue I am seeing with the out of the box behavior with the fetchInterval I am more than happy to provide it, just let me know what you need and I will provide it if I can.
                  S 1 Reply Last reply Dec 20, 2023, 11:58 PM Reply Quote 0
                  • S Away
                    sdetweil @ZiggidyZ
                    @ZiggidyZ yes need to get an issue opened
                    Z 1 Reply Last reply Dec 21, 2023, 7:17 AM Reply Quote 0
                    • Z Offline
                      ZiggidyZ @sdetweil
                      Thank you!
                      I took the leap and opened Issue #3297 on GitHub. I hope I did it correctly, I just signed up for GitHub to create the issue, so I am not familiar with how it all works.
                      S 1 Reply Last reply Dec 21, 2023, 1:06 PM Reply Quote 1
                      • S Away
                        sdetweil @ZiggidyZ
                        @ZiggidyZ I saw, thank you!!
