    No news after update to 2.25
    14 Posts 2 Posters 5.5k Views 2 Watching
      MajorC Project Sponsor
      Hi I updated my MM to V2.25 with @sdetweil script.
      But now, the newsfeed widget only shows “no news at the moment”.
      My config is:
      			module: "newsfeed",
      			position: "bottom_bar",
      					feeds: [
      						title: "Spiegel",
      						url: "http://www.spiegel.de/schlagzeilen/tops/index.rss",
      						title: "Süddeutsche",
      						url: "http://rss.sueddeutsche.de/rss/Topthemen",
      						title: "Tagesschau",
      						url: "http://www.tagesschau.de/xml/rss2",
      						title: "EDDH",
      						url: "http://www.eddh.de/special/rss/feed.rss",
      						encoding: "ISO-8859-1",
      						title: "RP News",
      						url: "https://rp-online.de/feed.rss",
      						title: "RP Ratingen",
      						url: "https://rp-online.de/nrw/staedte/ratingen/feed.rss",
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: false,
      				broadcastNewsUpdates: false,
      				updateInterval: 30000,
      				ignoreOldItems: true,
      				ignoreOlderThan: 86400000 //86400000 = 1 Tag
      Any ideas?
        sdetweil @MajorC
        @MajorC can u show the messages where u start mm
        if pm2, then
        pm2 flush
        restart mm, pm2 restart all
        wait
        pm2 logs --lines=50
          sdetweil @MajorC
          @MajorC also I’m guessing the first 4 should be https. the Internet has gone to secure transport everywhere as the default.
          I can’t test right now
            MajorC Project Sponsor @sdetweil
            [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
            /home/pi/.pm2/pm2.log last 50 lines:
            PM2        | 2023-12-27T15:40:18: PM2 log: Stopping app:MagicMirror id:0
            PM2        | 2023-12-27T15:40:18: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
            PM2        | 2023-12-27T15:40:18: PM2 log: pid=1682 msg=process killed
            PM2        | 2023-12-27T15:40:18: PM2 log: App [MagicMirror:0] starting in -fork mode-
            PM2        | 2023-12-27T15:40:18: PM2 log: App [MagicMirror:0] online
            /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
            0|MagicMir |     at processTicksAndRejections (node:internal/process/task_queues:78:11)
            0|MagicMir |     at runNextTicks (node:internal/process/task_queues:65:3)
            0|MagicMir |     at process.processImmediate (node:internal/timers:437:9)
            0|MagicMir | [27.12.2023 15:40.26.365] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            0|MagicMir | [27.12.2023 15:40.26.365] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            0|MagicMir | [27.12.2023 15:40.26.371] [ERROR] Whoops! There was an uncaught exception...
            0|MagicMir | [27.12.2023 15:40.26.372] [ERROR] ReferenceError: fetch is not defined
            0|MagicMir |     at fetchNews (/home/pi/MagicMirror/modules/default/newsfeed/newsfeedfetcher.js:110:3)
            0|MagicMir |     at NewsfeedFetcher.startFetch (/home/pi/MagicMirror/modules/default/newsfeed/newsfeedfetcher.js:153:3)
            0|MagicMir |     at Class.createFetcher (/home/pi/MagicMirror/modules/default/newsfeed/node_helper.js:72:11)
            0|MagicMir |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/default/newsfeed/node_helper.js:22:9)
            0|MagicMir |     at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:104:11)
            0|MagicMir |     at Socket.emit (node:events:513:28)
            0|MagicMir |     at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
            0|MagicMir |     at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:704:39
            0|MagicMir | [27.12.2023 15:40.26.373] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            0|MagicMir | [27.12.2023 15:40.26.373] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            0|MagicMir | [27.12.2023 15:40.26.377] [ERROR] Whoops! There was an uncaught exception...
            0|MagicMir | [27.12.2023 15:40.26.378] [ERROR] ReferenceError: fetch is not defined
            0|MagicMir | [27.12.2023 15:40.26.380] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            0|MagicMir | [27.12.2023 15:40.26.381] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            0|MagicMir | [27.12.2023 15:40.26.391] [ERROR] Whoops! There was an uncaught exception...
            0|MagicMir | [27.12.2023 15:40.26.393] [ERROR] ReferenceError: fetch is not defined
            0|MagicMir | [27.12.2023 15:40.26.393] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            0|MagicMir | [27.12.2023 15:40.26.394] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
            0|MagicMir | [27.12.2023 15:40.22.640] [LOG]   Starting server on port 8080 ...
            0|MagicMir | [27.12.2023 15:40.22.659] [LOG]   Server started ...
            0|MagicMir | [27.12.2023 15:40.22.660] [LOG]   Connecting socket for: updatenotification
            0|MagicMir | [27.12.2023 15:40.22.661] [LOG]   Starting module helper: updatenotification
            0|MagicMir | [27.12.2023 15:40.22.662] [LOG]   Connecting socket for: MMM-BackgroundSlideshow
            0|MagicMir | [27.12.2023 15:40.22.663] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
            0|MagicMir | [27.12.2023 15:40.22.664] [LOG]   MMM-DWD-WarnWeather helper started...
            0|MagicMir | [27.12.2023 15:40.22.665] [LOG]   Connecting socket for: MMM-NINA
            0|MagicMir | [27.12.2023 15:40.22.665] [LOG]   MMM-NINA helper method started...
            0|MagicMir | [27.12.2023 15:40.22.666] [LOG]   Connecting socket for: MMM-TAF
            0|MagicMir | [27.12.2023 15:40.22.667] [LOG]   MMM-TAF helper started ...
            0|MagicMir | [27.12.2023 15:40.22.667] [LOG]   Connecting socket for: newsfeed
            0|MagicMir | [27.12.2023 15:40.22.668] [LOG]   Starting node helper for: newsfeed
            0|MagicMir | [27.12.2023 15:40.22.668] [LOG]   Sockets connected & modules started ...
            0|MagicMir | [27.12.2023 15:40.22.934] [LOG]   Launching application.
            0|MagicMir | [27.12.2023 15:40.26.288] [LOG]   Notification: GET_TAF
            0|MagicMir | [27.12.2023 15:40.26.292] [LOG]   --Aviation TAF: Fetching TAF Data--
            0|MagicMir | [27.12.2023 15:40.26.296] [LOG]   Checking URL: http://avwx.rest/api/metar/EDDL?options=summary,translate,info&format=json&onfail=cache
            0|MagicMir | [27.12.2023 15:40.26.306] [LOG]   Checking URL: http://avwx.rest/api/taf/EDDL?options=summary&format=json&onfail=cache
            0|MagicMir | [27.12.2023 15:40.26.309] [LOG]   Checking URL: http://avwx.rest/api/metar/EDLP?options=summary,translate,info&format=json&onfail=cache
            0|MagicMir | [27.12.2023 15:40.26.312] [LOG]   Checking URL: http://avwx.rest/api/taf/EDLP?options=summary&format=json&onfail=cache
            0|MagicMir | [27.12.2023 15:40.26.316] [LOG]   Checking URL: http://avwx.rest/api/metar/EDDB?options=summary,translate,info&format=json&onfail=cache
            0|MagicMir | [27.12.2023 15:40.26.318] [LOG]   Checking URL: http://avwx.rest/api/taf/EDDB?options=summary&format=json&onfail=cache
            0|MagicMir | [27.12.2023 15:40.26.321] [LOG]   Checking URL: http://avwx.rest/api/metar/EDDH?options=summary,translate,info&format=json&onfail=cache
            0|MagicMir | [27.12.2023 15:40.26.324] [LOG]   Checking URL: http://avwx.rest/api/taf/EDDH?options=summary&format=json&onfail=cache
            0|MagicMir | [27.12.2023 15:40.26.328] [LOG]   Create new newsfetcher for url: http://www.spiegel.de/schlagzeilen/tops/index.rss - Interval: 300000
            0|MagicMir | [27.12.2023 15:40.26.346] [LOG]   Create new newsfetcher for url: http://rss.sueddeutsche.de/rss/Topthemen - Interval: 300000
            0|MagicMir | [27.12.2023 15:40.26.360] [LOG]   Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
            0|MagicMir | [27.12.2023 15:40.26.370] [LOG]   Create new newsfetcher for url: http://www.eddh.de/special/rss/feed.rss - Interval: 300000
            0|MagicMir | [27.12.2023 15:40.26.376] [LOG]   Create new newsfetcher for url: https://rp-online.de/feed.rss - Interval: 300000
            0|MagicMir | [27.12.2023 15:40.26.388] [LOG]   Create new newsfetcher for url: https://rp-online.de/nrw/staedte/ratingen/feed.rss - Interval: 300000
            0|MagicMir | [27.12.2023 15:40.26.422] [INFO]  Checking git for module: MMM-BackgroundSlideshow
            0|MagicMir | [27.12.2023 15:40.26.485] [INFO]  Checking git for module: MMM-DWD-WarnWeather
            0|MagicMir | [27.12.2023 15:40.26.643] [INFO]  Checking git for module: MMM-NINA
            0|MagicMir | [27.12.2023 15:40.26.685] [INFO]  BACKGROUNDSLIDESHOW: Reading directory "modules/MMM-BackgroundSlideshow/BackgroundImages" for images.
            0|MagicMir | [27.12.2023 15:40.26.698] [INFO]  BACKGROUNDSLIDESHOW: 48 files found
            0|MagicMir | [27.12.2023 15:40.26.762] [INFO]  Checking git for module: MMM-TAF
            0|MagicMir | [27.12.2023 15:40.26.805] [INFO]  BACKGROUNDSLIDESHOW_NEXT_IMAGE
            0|MagicMir | [27.12.2023 15:40.26.808] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/BackgroundImages/IMG_9710.JPG"
            0|MagicMir | [27.12.2023 15:40.26.983] [LOG]   Airports remaining: 7
            0|MagicMir | [27.12.2023 15:40.26.991] [LOG]   Airports remaining: 6
            0|MagicMir | [27.12.2023 15:40.26.996] [LOG]   Airports remaining: 5
            0|MagicMir | [27.12.2023 15:40.27.000] [LOG]   Airports remaining: 4
            0|MagicMir | [27.12.2023 15:40.27.007] [LOG]   Airports remaining: 3
            0|MagicMir | [27.12.2023 15:40.27.014] [LOG]   Airports remaining: 2
            0|MagicMir | [27.12.2023 15:40.27.019] [LOG]   Airports remaining: 1
            0|MagicMir | [27.12.2023 15:40.27.024] [LOG]   Airports remaining: 0
            0|MagicMir | [27.12.2023 15:40.27.031] [LOG]   Socket notification sent.
            0|MagicMir | [27.12.2023 15:40.27.034] [INFO]  Checking git for module: MMM-OpenmapWeather
            0|MagicMir | [27.12.2023 15:40.27.103] [INFO]  Checking git for module: MagicMirror
              sdetweil @MajorC
              @MajorC hm… can you do node -v
              should be 18 or 20
              also send me the ~/MagicMirror/installers/upgrade.log
              same userid at gmail
                I changed it to https, but still no news. I will try your next suggestion.
                  MajorC Project Sponsor @MajorC
                  This is with https:
                  pi@ratingen:~ $ pm2 logs --lines=50
                  PM2        | 2023-12-27T15:43:49: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                  PM2        | 2023-12-27T15:43:49: PM2 log: Stopping app:MagicMirror id:0
                  PM2        | 2023-12-27T15:43:50: PM2 log: pid=2262 msg=failed to kill - retrying in 100ms
                  PM2        | 2023-12-27T15:43:50: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                  PM2        | 2023-12-27T15:43:50: PM2 log: pid=2262 msg=process killed
                  PM2        | 2023-12-27T15:43:50: PM2 log: App [MagicMirror:0] starting in -fork mode-
                  PM2        | 2023-12-27T15:43:50: PM2 log: App [MagicMirror:0] online
                  0|MagicMir |     at process.processTicksAndRejections (node:internal/process/task_queues:78:11)
                  0|MagicMir | [27.12.2023 15:43.57.779] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  0|MagicMir | [27.12.2023 15:43.57.780] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  0|MagicMir | [27.12.2023 15:43.57.783] [ERROR] Whoops! There was an uncaught exception...
                  0|MagicMir | [27.12.2023 15:43.57.785] [ERROR] ReferenceError: fetch is not defined
                  0|MagicMir | [27.12.2023 15:43.57.786] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  0|MagicMir | [27.12.2023 15:43.57.786] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  0|MagicMir | [27.12.2023 15:43.57.790] [ERROR] Whoops! There was an uncaught exception...
                  0|MagicMir | [27.12.2023 15:43.57.791] [ERROR] ReferenceError: fetch is not defined
                  0|MagicMir | [27.12.2023 15:43.57.792] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  0|MagicMir | [27.12.2023 15:43.57.792] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  0|MagicMir | [27.12.2023 15:43.57.796] [ERROR] Whoops! There was an uncaught exception...
                  0|MagicMir | [27.12.2023 15:43.57.798] [ERROR] ReferenceError: fetch is not defined
                  0|MagicMir | [27.12.2023 15:43.57.800] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  0|MagicMir | [27.12.2023 15:43.57.800] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  0|MagicMir | [27.12.2023 15:43.54.094] [LOG]   Starting server on port 8080 ...
                  0|MagicMir | [27.12.2023 15:43.54.113] [LOG]   Server started ...
                  0|MagicMir | [27.12.2023 15:43.54.114] [LOG]   Connecting socket for: updatenotification
                  0|MagicMir | [27.12.2023 15:43.54.115] [LOG]   Starting module helper: updatenotification
                  0|MagicMir | [27.12.2023 15:43.54.115] [LOG]   Connecting socket for: MMM-BackgroundSlideshow
                  0|MagicMir | [27.12.2023 15:43.54.117] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
                  0|MagicMir | [27.12.2023 15:43.54.118] [LOG]   MMM-DWD-WarnWeather helper started...
                  0|MagicMir | [27.12.2023 15:43.54.118] [LOG]   Connecting socket for: MMM-NINA
                  0|MagicMir | [27.12.2023 15:43.54.119] [LOG]   MMM-NINA helper method started...
                  0|MagicMir | [27.12.2023 15:43.54.119] [LOG]   Connecting socket for: MMM-TAF
                  0|MagicMir | [27.12.2023 15:43.54.121] [LOG]   MMM-TAF helper started ...
                  0|MagicMir | [27.12.2023 15:43.54.122] [LOG]   Connecting socket for: newsfeed
                  0|MagicMir | [27.12.2023 15:43.54.123] [LOG]   Starting node helper for: newsfeed
                  0|MagicMir | [27.12.2023 15:43.54.123] [LOG]   Sockets connected & modules started ...
                  0|MagicMir | [27.12.2023 15:43.54.373] [LOG]   Launching application.
                  0|MagicMir | [27.12.2023 15:43.57.679] [LOG]   Notification: GET_TAF
                  0|MagicMir | [27.12.2023 15:43.57.683] [LOG]   --Aviation TAF: Fetching TAF Data--
                  0|MagicMir | [27.12.2023 15:43.57.688] [LOG]   Checking URL: http://avwx.rest/api/metar/EDDL?options=summary,translate,info&format=json&onfail=cache
                  0|MagicMir | [27.12.2023 15:43.57.705] [LOG]   Checking URL: http://avwx.rest/api/taf/EDDL?options=summary&format=json&onfail=cache
                  0|MagicMir | [27.12.2023 15:43.57.709] [LOG]   Checking URL: http://avwx.rest/api/metar/EDLP?options=summary,translate,info&format=json&onfail=cache
                  0|MagicMir | [27.12.2023 15:43.57.714] [LOG]   Checking URL: http://avwx.rest/api/taf/EDLP?options=summary&format=json&onfail=cache
                  0|MagicMir | [27.12.2023 15:43.57.719] [LOG]   Checking URL: http://avwx.rest/api/metar/EDDB?options=summary,translate,info&format=json&onfail=cache
                  0|MagicMir | [27.12.2023 15:43.57.725] [LOG]   Checking URL: http://avwx.rest/api/taf/EDDB?options=summary&format=json&onfail=cache
                  0|MagicMir | [27.12.2023 15:43.57.729] [LOG]   Checking URL: http://avwx.rest/api/metar/EDDH?options=summary,translate,info&format=json&onfail=cache
                  0|MagicMir | [27.12.2023 15:43.57.733] [LOG]   Checking URL: http://avwx.rest/api/taf/EDDH?options=summary&format=json&onfail=cache
                  0|MagicMir | [27.12.2023 15:43.57.738] [LOG]   Create new newsfetcher for url: https://www.spiegel.de/schlagzeilen/tops/index.rss - Interval: 300000
                  0|MagicMir | [27.12.2023 15:43.57.768] [LOG]   Create new newsfetcher for url: https://rss.sueddeutsche.de/rss/Topthemen - Interval: 300000
                  0|MagicMir | [27.12.2023 15:43.57.775] [LOG]   Create new newsfetcher for url: https://www.tagesschau.de/infoservices/alle-meldungen-100~rss2.xml - Interval: 300000
                  0|MagicMir | [27.12.2023 15:43.57.781] [LOG]   Create new newsfetcher for url: https://www.eddh.de/special/rss/feed.rss - Interval: 300000
                  0|MagicMir | [27.12.2023 15:43.57.789] [LOG]   Create new newsfetcher for url: https://rp-online.de/feed.rss - Interval: 300000
                  0|MagicMir | [27.12.2023 15:43.57.795] [LOG]   Create new newsfetcher for url: https://rp-online.de/nrw/staedte/ratingen/feed.rss - Interval: 300000
                  0|MagicMir | [27.12.2023 15:43.57.874] [INFO]  Checking git for module: MMM-BackgroundSlideshow
                  0|MagicMir | [27.12.2023 15:43.57.986] [INFO]  Checking git for module: MMM-DWD-WarnWeather
                  0|MagicMir | [27.12.2023 15:43.58.104] [INFO]  Checking git for module: MMM-NINA
                  0|MagicMir | [27.12.2023 15:43.58.141] [INFO]  BACKGROUNDSLIDESHOW: Reading directory "modules/MMM-BackgroundSlideshow/BackgroundImages" for images.
                  0|MagicMir | [27.12.2023 15:43.58.152] [INFO]  BACKGROUNDSLIDESHOW: 48 files found
                  0|MagicMir | [27.12.2023 15:43.58.185] [INFO]  Checking git for module: MMM-TAF
                  0|MagicMir | [27.12.2023 15:43.58.232] [INFO]  BACKGROUNDSLIDESHOW_NEXT_IMAGE
                  0|MagicMir | [27.12.2023 15:43.58.234] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/BackgroundImages/IMG_1402.JPG"
                  0|MagicMir | [27.12.2023 15:43.58.386] [LOG]   Airports remaining: 7
                  0|MagicMir | [27.12.2023 15:43.58.394] [INFO]  Checking git for module: MMM-OpenmapWeather
                  0|MagicMir | [27.12.2023 15:43.58.456] [LOG]   Airports remaining: 6
                  0|MagicMir | [27.12.2023 15:43.58.473] [LOG]   Airports remaining: 5
                  0|MagicMir | [27.12.2023 15:43.58.482] [INFO]  Checking git for module: MagicMirror
                  0|MagicMir | [27.12.2023 15:43.58.669] [LOG]   Airports remaining: 4
                  0|MagicMir | [27.12.2023 15:43.59.642] [LOG]   Airports remaining: 3
                  0|MagicMir | [27.12.2023 15:44.00.486] [LOG]   Airports remaining: 2
                  0|MagicMir | [27.12.2023 15:44.00.492] [LOG]   Airports remaining: 1
                  0|MagicMir | [27.12.2023 15:44.00.504] [LOG]   Airports remaining: 0
                  0|MagicMir | [27.12.2023 15:44.00.509] [LOG]   Socket notification sent.
                    sdetweil @MajorC
                    @MajorC yeh it’s not code problem
                    the version of node is down level, but I should have upgraded it
                    I need to see the upgrade.log to figure out why.
                    did u try to manual upgrade first?
                      @MajorC I’m going to be gone for a few hours helping my daughter.
                        @MajorC I am back. I need to see the upgrade.log
                          @sdetweil did you get my email with the log?
                            sdetweil @MajorC
                            @MajorC yes, got sent to spam
                              sdetweil @MajorC
                              @MajorC I tested with your feeds on 2.25, the installed version according to the log and files.
                              [28.12.2023 12:30.49.429] [INFO]  Newsfeed-Fetcher: Broadcasting 6 items.
                              [28.12.2023 12:30.49.474] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                              [28.12.2023 12:30.49.586] [INFO]  Newsfeed-Fetcher: Broadcasting 5 items.
                              [28.12.2023 12:30.49.813] [INFO]  Newsfeed-Fetcher: Broadcasting 15 items.
                              [28.12.2023 12:30.50.037] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                              [28.12.2023 12:30.50.542] [INFO]  Newsfeed-Fetcher: reloadInterval set to ttl=5400000 for url http://www.tagesschau.de/xml/rss2
                              [28.12.2023 12:30.50.603] [INFO]  Newsfeed-Fetcher: Broadcasting 40 items.
                              worked as expected…
                              the log says node 20.08 is installed as it should be.
                              this provides the fecth() function the error claims to miss
                              can you do
                              node -v
                              npm start
                              and see what happens?
                              I’m wondering if the pm2 saved data is reverting back to node 16, altho I’ve never seen that happen
                                @sdetweil Thank you for all the help.
                                The mirror is at my family’s house. So I have to find a way to VPN connect myself to that.
                                I will come back to you asap.
