    No display of the MM via "mstsc"
    4 Posts 2 Posters 832 Views 2 Watching
      MyMirror
      Raspberry Pi 3b with Bullseye
      Before Christmas, I decided to completely rebuild my MagicMirror.
      The mirror works fine so far, but now I have the problem that I can no longer start and see the MM as another instance on my PC - it worked before on my old mirror.
      Here is the output when I try to start the MM with “npm start”:
      chef@pi5:~/MagicMirror $ lsb_release -d
      Description:	Raspbian GNU/Linux 11 (bullseye)
      chef@pi5:~/MagicMirror $ npm start
      > magicmirror@2.26.0 start
      [07.01.2024 13:15.03.113] [LOG]   Starting MagicMirror: v2.26.0
      [07.01.2024 13:15.03.126] [LOG]   Loading config ...
      [07.01.2024 13:15.03.138] [DEBUG] config template file not exists, no envsubst
      [07.01.2024 13:15.03.151] [LOG]   Loading module helpers ...
      [07.01.2024 13:15.03.155] [LOG]   No helper found for module: alert.
      [07.01.2024 13:15.03.293] [LOG]   Initializing new module helper ...
      [07.01.2024 13:15.03.305] [LOG]   Module helper loaded: updatenotification
      [07.01.2024 13:15.03.307] [LOG]   No helper found for module: clock.
      [07.01.2024 13:15.03.309] [LOG]   No helper found for module: MMM-CountUP.
      [07.01.2024 13:15.03.344] [LOG]   Initializing new module helper ...
      [07.01.2024 13:15.03.345] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.26.0
      [07.01.2024 13:15.03.347] [LOG]   Version is ok!
      [07.01.2024 13:15.03.349] [LOG]   Module helper loaded: MMM-Fuel
      [07.01.2024 13:15.03.359] [LOG]   No helper found for module: MMM-OpenWeather24Hours.
      [07.01.2024 13:15.03.360] [WARN]  No /home/chef/MagicMirror/js/../modules/weatherforecast/weatherforecast.js found for module: weatherforecast.
      [07.01.2024 13:15.03.362] [LOG]   No helper found for module: weatherforecast.
      [07.01.2024 13:15.03.419] [LOG]   Initializing new module helper ...
      [07.01.2024 13:15.03.419] [LOG]   Module helper loaded: MMM-MyWastePickup
      [07.01.2024 13:15.04.595] [LOG]   Initializing new module helper ...
      [07.01.2024 13:15.04.596] [LOG]   Module helper loaded: MMM-Tado
      [07.01.2024 13:15.05.329] [LOG]   Initializing new module helper ...
      [07.01.2024 13:15.05.330] [LOG]   Module helper loaded: MMM-Todoist
      [07.01.2024 13:15.05.723] [LOG]   init module helper birthdaylist
      [07.01.2024 13:15.05.724] [LOG]   Module helper loaded: birthdaylist
      [07.01.2024 13:15.05.726] [LOG]   No helper found for module: MMM-EyeCandy.
      [07.01.2024 13:15.05.970] [LOG]   Initializing new module helper ...
      [07.01.2024 13:15.05.972] [LOG]   Module helper loaded: newsfeed
      [07.01.2024 13:15.05.973] [LOG]   All module helpers loaded.
      [07.01.2024 13:15.05.994] [LOG]   Starting server on port 8080 ...
      [07.01.2024 13:15.06.584] [ERROR] Whoops! There was an uncaught exception...
      [07.01.2024 13:15.06.589] [ERROR] Error: listen EADDRINUSE: address already in use ::1:8080
          at Server.setupListenHandle [as _listen2] (node:net:1751:16)
          at listenInCluster (node:net:1799:12)
          at GetAddrInfoReqWrap.doListen [as callback] (node:net:1948:7)
          at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:110:8) {
        code: 'EADDRINUSE',
        errno: -98,
        syscall: 'listen',
        address: '::1',
        port: 8080
      [07.01.2024 13:15.06.591] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [07.01.2024 13:15.06.592] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      ^C/home/chef/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      Any ideas?
        sdetweil @MyMirror
        @MyMirror that error
        says that another copy of mm is running already
        if you did pm2 start and it’s stuck
        pm2 status
        then
        pm2 stop all
        then npm start
          MyMirror @sdetweil
          Ok, that works.
          With my “old” mirror this also worked when the right mirror was working, but this workaround is sufficient for me.
          Thank you
            sdetweil @MyMirror
            @MyMirror you could also do
            pm2 restart xxx
            where xxx is the name or the number on the row of the thing
