    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 432.9k Views 65 Watching
      anhanyoung91 @Saabman
      @Saabman thank you so much for the reply. I’ll trace my steps and give it a shot!
        @Saabman I’ve literally re-done the steps over and over and I keep getting the permissions error. Have any other ideas what might be causing this or how to fix it? Thanks in advance
          sdetweil @anhanyoung91
          @anhanyoung91 did u do the tutorial
          https://vdirsyncer.pimutils.org/en/stable/tutorial.html
            Alfnie
            I run into a problem with vdirsyncer (discover) which is raised some times before in this thread, but I can’t find the solution. I have tried with other internet resources to solve my problem, but I ran out of options. Hopefully one of you can help me troubleshoot.
            1.) First, I successfully followed the steps of @Beh with additionally the clean, easy way from here:
            https://vdirsyncer.pimutils.org/en/stable/installation.html#the-clean-hard-way
            I got stuck at the part: Let vdirsyncer discover the collections and do the inital sync, with the command vdirsyncer discover. It returned:
            adm@raspberrypi:~ $ vdirsyncer discover
              File "/home/adm/.local/bin/vdirsyncer", line 5, in <module>
                from vdirsyncer.cli import main
            ModuleNotFoundError: No module named 'vdirsyncer'
            2.) Second, I followed the routine from @mr190e, on page 13 in this thread (link), after i used pipx uninstall vdirsyncer from The clean, easy way.
            Seems like I got to work again.
            First of all, I installed vdirsyncer via
            “sudo apt-get install vdirsyncer”,
            and not using pip.
            Now, vdirsyncer discover returns:
            critical: Error during reading config /home/adm/.config/vdirsyncer/config: [Errno 2] No such file or directory: '/home/adm/.config/vdirsyncer/config'
            Now I am out of tricks, I’m not sure how to troubleshoot this. What do I need to check, or to modify, to get it to work…
            Thanks advance for your help!
            • A Alfnie referenced this topic on
              sdetweil @Alfnie
              @Alfnie so create the folder .config/.vdirsyncer
              And add the config file there
                Alfnie @sdetweil
                Thanks for your reply, it sounds simple, however it seems complicated for me.
                I do as you say by taking these commands from the instruction (is this correct?)
                mkdir /home/adm/.config/vdirsyncer/
                touch /home/adm/.config/vdirsyncer/config
                nano /home/adm/.config/vdirsyncer/config
                It results in:
                admns@raspberrypi:~ $ mkdir /home/adm/.config/vdirsyncer/
                mkdir: cannot create directory ‘/home/adm/.config/vdirsyncer/’: No such file or directory
                admns@raspberrypi:~ $ touch /home/adm/.config/vdirsyncer/config
                touch: cannot touch '/home/adm/.config/vdirsyncer/config': No such file or directory
                How should I create the folder .config/.vdirsyncer as you pointed out?
                  sdetweil @Alfnie
                  @Alfnie you missed the . in front of vdirsyncer…
                  the dot on linux makes the folder ‘hidden’ from normal ls commands… as linux file system doesn’t have a hidden attribute
                    @Alfnie
                    who is adm? should be the current username (pi?)
                    always best to use the shortcut
                    ~/.config
                    ~ means the home folder of the current user , same as
                    /home/$USER
                    or /home/pi is pi is logged in
                      Alfnie @sdetweil
                      Thanks, it works now.
                      Also, I have learned about the dot (.) implying Hidden folders, thanks.
                      Tomorrow I’m gonna try to add multiple calendars.
                      • kaiK Offline
                        kai @Beh
                        Hi @Beh,
                        thank you very much for this detailed description. This was exactly what I was looking for for my MM, and with your step-by-step instructions it worked for me straight away.
                        Happy New Year and thank you very much again!!! :thumbs_up:
                        May the code be with you
                        -kai
                          JamesScreech
                          Thanks for the detailed description, I’ve done this and it works most of the time, however one of my calendars is not updating.
                          I know very little about Pi’s and am new to Linux it general, are there any suggestions on how to find issues?
                            JamesScreech @JamesScreech
                            The problem with not updating looks like it’s related to one of my calendars not having any entries in the requested timescale. If all calendars have entries then they sync however if one (in my case the last one) has no entries then there are no updates. Very strange.
                            • D dubbedMonster referenced this topic on
                              raisins @ggfuzzy
                              @Gailby said in Sync private iCloud calendar with MagicMirror:
                              @Gailby @ganther @Beh the ics files doesn’t seem to sync in Calendars… all files are empty. Have anyone resolved this?
                              @ganther said in Sync private iCloud calendar with MagicMirror:
                              Hi there,
                              i followed the instructions, my calendars are shown in discovery.
                              I copied the UUID and it starts syncing, but the saved files are 0kb.
                              I tried several calendars and checked the UUID’s but can’t find any mistake?
                              any ideas?
                              thanks!!
                              @maestro82
                              Did you check your calendar-url in conf/config.js?
                              My calendar is running now correctly. Don‘t know why but now my ics-file isn‘t empty anymore.
                              @ggfuzzy said in Sync private iCloud calendar with MagicMirror:
                              Went through all the steps in the tutorial (including the modification to set the .service file to point to where vdirsyncer really lives [Thanks @Beh !]). Everything works, except that my .ics files are empty (0 length). I saw a reference to this early in the forum comments, but the poster said they eventually started working with no reason for the change. Anyone have any ideas?
                              I’m getting this same thing. The .ics files are created, but they’re empty. Everything up to there is working. The iCloud credentials must be correct as it’s talking to me and I can see the names and uuids of the remote calendars when I use “vdirsync discover”. I just don’t get any events into the local files with “vdirsync sync”.
                              I’m aware this is more a vdirsync issue than MagicMirror, but did any of you folks having this problem ever figure it out?
                                aceahspades
                                Hello! I can get to the point where I update my collections, but when I run the discover feature again and enter y + enter I get this error message
                                error: Unknown error occurred: [Errno 13] Permission denied: ‘/home/pi’
                                error: Use -vdebug to see the full traceback.
                                Is there a fix for this?
                                  sdetweil @aceahspades
                                  @aceahspades is the userid you are logged on as
                                  pi??
                                  if not you should change that string the /user/xxxxx
                                  where xxxxx is your logged on username
                                    aceahspades @sdetweil
                                    @sdetweil Up and running, thank you so very much!
                                      bobbythemoh
                                      Hey - this script with vdirsyncer was working for years without any issues - recently i obersverd that my meetings are not shown any more - so i went to the console and entered “vdirsyncer discover” - and i am getting this error:
                                      warning: Failed to discover collections for iCloud, use -vdebug to see the full traceback.
                                      error: Unknown error occurred: 401, message=‘Unauthorized’, url=URL(‘https://caldav.icloud.com/.well-known/caldav’)
                                      I did check the iCloud API Keys - they are still there.
                                      Is anyone having the same issue? Does anyone know how to fix it?
                                      • N Offline
                                        nwonnink
                                        Hi All,
                                        I have set it up like above, my Icloud agenda is shown in the Magicmirror but it does not synchronize also not after the minutes set?
                                        Also after vdirsyncer sync command it doesnt update directly on the Magicmirror only when i stop and start the services again.
                                        Anybody knows what it could be?
                                        I only had a fault during setup the Symbolic Link. The error message was that the file already Exist.
                                        Thank you in advanced,
                                          sdetweil @nwonnink
                                          @nwonnink this topic is old, but seems pretty comprehensive
                                          you have to setup some mechanism to run the sync on a schedule
                                          https://forum.magicmirror.builders/topic/5327/sync-private-icloud-calendar-with-magicmirror
                                          • 8 / 9
