    where is that "{DEGREE}" coming from?
    11 Posts 2 Posters 4.0k Views 2 Watching
    • L
      lkthomas
      module: “currentweather” is very strange on a fresh deployment,
      (Sorry for the color distortion, it’s normal as I took the screenshot from VNC which reduced the picture quality)
      Question: how could I get rid of that “{DEGREE}” string?
        sdetweil @lkthomas
        @lkthomas from the MagicMirror/translations/??.json file
        	"FEELS": "Feels like {DEGREE}",
        L 1 Reply Last reply
        • L
          lkthomas @sdetweil
          @sdetweil Thanks but is this a glitch or I miss some config?
            sdetweil @lkthomas
            @lkthomas some languages don’t have a feels like
            what lanuage is your system set to ?
            • L
              lkthomas @sdetweil
              @sdetweil should be English, how could I check?
                sdetweil @lkthomas
                @lkthomas edit the config.js
                language:
                • L
                  lkthomas @sdetweil
                  @sdetweil language: “en”
                    sdetweil @lkthomas
                    @lkthomas just fyi… all users with reputation below 2 have all their posts reviewed before posting on the forum… this stops all the spam, and advertising…
                    so, have patience/// I review every post
                    which provider are you using?
                    from the doc
                    • L
                      lkthomas @sdetweil
                      ( I masked my location)
                      That’s my config, I copy from my old config which uses “currentweather”, and if I use “weather”, the bottom left widget will keep “Loading” and nothing appears.
                        sdetweil @lkthomas
                        @lkthomas only thin you should need is the provider, the apikey and some location info.
                        from the sample
                        put in your apikey
                        its should give u current weather from NY
                        it uses openweather by default…
                                module: "weather",
                                disabled: true,
                                  locationID: "5128581",
                                  apiKey: "YOUR_OPENWEATHER_API_KEY",
                                  windUnits: "mph",
                                  useBeaufort: true,
                                  degreeLabel: "false",
                                  useKmh: false
                                order: "*",
                                label: "instance 1",
                                index: 1
                        • L
                          lkthomas @sdetweil
                          @sdetweil I will have a look when I have time, for now, I just removed {DEGREE} string from en.json and called it a day, thanks.
