    where is that "{DEGREE}" coming from?
    11 Posts 2 Posters 3.2k Views 2 Watching
      sdetweil @lkthomas
      @lkthomas some languages don’t have a feels like
      what lanuage is your system set to ?
      • L Offline
        lkthomas @sdetweil
        @sdetweil should be English, how could I check?
          sdetweil @lkthomas
          @lkthomas edit the config.js
          language:
          • L Offline
            lkthomas @sdetweil
            @sdetweil language: “en”
              sdetweil @lkthomas
              @lkthomas just fyi… all users with reputation below 2 have all their posts reviewed before posting on the forum… this stops all the spam, and advertising…
              so, have patience/// I review every post
              which provider are you using?
              from the doc
              • L Offline
                lkthomas @sdetweil
                ( I masked my location)
                That’s my config, I copy from my old config which uses “currentweather”, and if I use “weather”, the bottom left widget will keep “Loading” and nothing appears.
                  sdetweil @lkthomas
                  @lkthomas only thin you should need is the provider, the apikey and some location info.
                  from the sample
                  put in your apikey
                  its should give u current weather from NY
                  it uses openweather by default…
                          module: "weather",
                          disabled: true,
                            locationID: "5128581",
                            apiKey: "YOUR_OPENWEATHER_API_KEY",
                            windUnits: "mph",
                            useBeaufort: true,
                            degreeLabel: "false",
                            useKmh: false
                          order: "*",
                          label: "instance 1",
                          index: 1
                  • L Offline
                    lkthomas @sdetweil
                    @sdetweil I will have a look when I have time, for now, I just removed {DEGREE} string from en.json and called it a day, thanks.
