    MM doesnt work after update to version 2.26
    30 Posts 2 Posters 12.6k Views 2 Watching
      davismorehead
      pi@raspberrypi:~ $ node -v
      v19.3.0
      pi@raspberrypi:~ $ npm -v
      9.2.0
      pi@raspberrypi:~ $ lsb_release -a
      No LSB modules are available.
      Distributor ID: Raspbian
      Description: Raspbian GNU/Linux 10 (buster)
      Release: 10
      Codename: buster
      pi@raspberrypi:~ $ uname -a
      Linux raspberrypi 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
      pi@raspberrypi:~ $
      I updated manually. Later I tried to run your script but I am running remotely so can’t do your script. would need to hook up keyboard to pi.
      am using pm2. Saw a different post where you did the npm start, so did that already. Same error
        sdetweil @davismorehead
        @davismorehead I need the actual messages from npm start.
        if you can ssh or VNC or RDP into your machine you can run my scripts, it’s a cut and paste of the comnands
          davismorehead
          pi@raspberrypi:~ $ pm2 stop all
          [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
          [PM2] mm ✓
          │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
          │ 0 │ mm │ fork │ 95 │ stopped │ 0% │ 0b │
          pi@raspberrypi:~ $ cd ~/MagicMirror/
          magicmirror@2.26.0 start
          /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGILL
          Also can you point me to instructions to run your script.
            davismorehead
            here is the command i found for your script
            pi@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
            $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
            $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
            $$$$$$ $$ | _
            $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
            $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
            $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
            _
            | _
            | _
            | _
            $$ |_| _
            |_| _|_|_| __| _
            / _| _______|
            _
            ____/
            install log being saved to /home/pi/install.log
            cat: /etc/systemd/system/default.target: No such file or directory
            system running in command line mode, need graphical desktop, see raspi-config
              @davismorehead see
              did you run npm install, or npm run install-mm
                davismorehead
                i did
                git pull && npm run install-mm
                Some of my replies take a long time to be approved. Is there a secret to get them approved faster.
                  @davismorehead if you have already installed, then you don’t run install again…
                  so, are you running headless? (no screen?)
                  so you would not do npm start, you would do npm run server
                    @davismorehead said in MM doesnt work after update to version 2.26:
                    I review every post for every user with reputation below 2.
                    this keeps out all the spam…
                    i DO do other things…
                      davismorehead
                      sorry, didn’t know how it worked. Didn’t realize you did it.
                        davismorehead
                        not running headless. Just don’t have a keyboard attached to pi. so SSH intomachine.
                          @davismorehead I use ssh exclusively, so that’s not it. and you are running in graphical mode, w the desktop…right?
                          I’ve had that check in there for 3 years now… and I just checked on all my pi systems. it never fails to find the file…
                            davismorehead
                            i checked i don’t have that file. looking on internet it says During the booting up of the system, systemd activates default. target , which is generally a symbolic link in the /etc/systemd/system/ directory to either graphical. target or multi-user. target . It is equivalent to the default runlevel, which the system administrator used to set in the /etc/inittab file.
                            I don’t have graphical.target or multi-user.target but I have graphical.target.wants
                              @davismorehead weird
                                davismorehead
                                so should i try and get your script to work or do something else to fix this
                                  @davismorehead you could try upgrade, with force instead of apply.
                                    davismorehead
                                    how do I do that?
                                    also if I run the command
                                    pi@raspberrypi:~ $ systemctl get-default
                                    graphical.target
                                    I get graphical even though I don’t have the file
                                      davismorehead
                                      I did
                                      npm update.
                                      i did pm2 start mm
                                      and it works. Thank you very much
                                        @davismorehead what npm update?
                                          davismorehead
                                          I will look at your script later.
                                          So in the future I should run npm update not npm install?
                                            davismorehead
                                            cd MagicMirror/
                                            pi@raspberrypi:~/MagicMirror $ npm update
                                            added 495 packages, and changed 6 packages in 3m
                                            195 packages are looking for funding
                                            run npm fund for details
                                            That worked
