    MM doesnt work after update to version 2.26
    30 Posts 2 Posters 12.6k Views 2 Watching
      davismorehead
      i did
      git pull && npm run install-mm
      Some of my replies take a long time to be approved. Is there a secret to get them approved faster.
        sdetweil @davismorehead
        @davismorehead if you have already installed, then you don’t run install again…
        so, are you running headless? (no screen?)
        so you would not do npm start, you would do npm run server
          @davismorehead said in MM doesnt work after update to version 2.26:
          I review every post for every user with reputation below 2.
          this keeps out all the spam…
          i DO do other things…
            davismorehead
            sorry, didn’t know how it worked. Didn’t realize you did it.
              davismorehead
              not running headless. Just don’t have a keyboard attached to pi. so SSH intomachine.
                @davismorehead I use ssh exclusively, so that’s not it. and you are running in graphical mode, w the desktop…right?
                I’ve had that check in there for 3 years now… and I just checked on all my pi systems. it never fails to find the file…
                  davismorehead
                  i checked i don’t have that file. looking on internet it says During the booting up of the system, systemd activates default. target , which is generally a symbolic link in the /etc/systemd/system/ directory to either graphical. target or multi-user. target . It is equivalent to the default runlevel, which the system administrator used to set in the /etc/inittab file.
                  I don’t have graphical.target or multi-user.target but I have graphical.target.wants
                    @davismorehead weird
                      davismorehead
                      so should i try and get your script to work or do something else to fix this
                        @davismorehead you could try upgrade, with force instead of apply.
                          davismorehead
                          how do I do that?
                          also if I run the command
                          pi@raspberrypi:~ $ systemctl get-default
                          graphical.target
                          I get graphical even though I don’t have the file
                            davismorehead
                            I did
                            npm update.
                            i did pm2 start mm
                            and it works. Thank you very much
                              @davismorehead what npm update?
                                davismorehead
                                I will look at your script later.
                                So in the future I should run npm update not npm install?
                                  davismorehead
                                  cd MagicMirror/
                                  pi@raspberrypi:~/MagicMirror $ npm update
                                  added 495 packages, and changed 6 packages in 3m
                                  195 packages are looking for funding
                                  run npm fund for details
                                  That worked
                                    @davismorehead i don’t understand
                                    when we release a new version, we have dependency changes additions, removals
                                    so to handle all that you do
                                    npm run install-mm
                                    install-mm is a script tag in the package.json
                                    it just turns off as much of the noise as we can…
                                    my script does the same thing…
                                    I don’t know what npm update does. we don’t use it
                                      davismorehead @sdetweil
                                      @sdetweil said in MM doesnt work after update to version 2.26:
                                      so based on this post i Tried npm update. Not sure what you meant me to do. So sounds like we solved it but don’t know why.
                                          @davismorehead what I meant was to use my upgrade script
                                          its a two step process…
                                          test
                                          do
                                          on the ‘do’
                                          its the same command as test, but with the parm ‘apply’ on the end
                                          I check if you have already upgraded, and won’t let you do it again, accidentally
                                          SO, as you HAVE already downloaded the new code, I would just end
                                          but if you change apply to force
                                          then upgrade will happen again …
                                          my objective is to NOT screw up your wonderful mirror system .
                                            davismorehead
                                            oh. I have to figure that out since I cannot get it to run because of the default.target file not existing on my pi.
                                            Again thanks for your help.
