    Calendar not updating
    95 Posts 4 Posters 94.4k Views 6 Watching
      matt216
      I might have a go at spinning up another calendar server and see if the issue still exists there. This calendar is a newly self-hosted one so it could be an issue there (although the magicmirror is the only device having trouble with it).
      Thanks for the help still.
      Matt
        sdetweil @matt216
        @matt216 also try
        npm install electron@28.1.1
        supposedly it has the fix for ipv6 vs 4
        M 1 Reply Last reply
          matt216 @sdetweil
          @sdetweil Thanks. Done. No change :(
          Have you heard of others with this problem? No one else on this thread. I really appreciate your efforts, but don’t worry too much if it’s just me. Part of the fun with self-hosting calendars etc :)
            sdetweil @matt216
            @matt216 I have not had others with no updates, but others w missing events
            • N
              nechry
              I also had the problem with a Google calendar and an iCloud. for me the update to electronic@28.1.1 was the solution, now everything works as with the previous version of MM
                sdetweil @nechry
                @nechry thanks for the feedback
                  mspk
                  @sdetweil said in Calendar not updating:
                  Hi, I’m pretty new here, so sorry if I mess something up. I think I have the same problem. Installed MM yesterday (so pretty vanilla setup), the only module I added is the MMM-CalendarExt3.
                  I configured everything as it should be (I hope at least), but for some reason, my calendars are not beeing updated and one is not beeing show at all… I don’t know what to do anymore, maybe you guys have an idea.
                  Here is my error: ```
                  0|MagicMirror | [09.01.2024 12:28.43.248] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/[MyCalendarNameHere]/basic.ics
                  TypeError: fetch failed
                  0|MagicMirror | at Object.fetch (node:internal/deps/undici/undici:11576:11) {
                  0|MagicMirror | cause: Error: write EPIPE
                  0|MagicMirror | at WriteWrap.onWriteComplete [as oncomplete] (node:internal/stream_base_commons:94:16)
                  0|MagicMirror | at handleWriteReq (node:internal/stream_base_commons:58:21)
                  0|MagicMirror | at writeGeneric (node:internal/stream_base_commons:149:15)
                  0|MagicMirror | at TLSSocket._writeGeneric (node:net:931:11)
                  0|MagicMirror | at TLSSocket._write (node:net:943:8)
                  0|MagicMirror | at writeOrBuffer (node:internal/streams/writable:392:12)
                  0|MagicMirror | at _write (node:internal/streams/writable:333:10)
                  0|MagicMirror | at TLSSocket.write (node:internal/streams/writable:337:10)
                  0|MagicMirror | at write (node:internal/deps/undici/undici:10124:18)
                  0|MagicMirror | at _resume (node:internal/deps/undici/undici:10037:33)
                  0|MagicMirror | at resume (node:internal/deps/undici/undici:9938:7)
                  0|MagicMirror | at [dispatch] (node:internal/deps/undici/undici:9286:11)
                  0|MagicMirror | at Client.Intercept (node:internal/deps/undici/undici:9017:20)
                  0|MagicMirror | at Client.dispatch (node:internal/deps/undici/undici:7772:44)
                  0|MagicMirror | at [dispatch] (node:internal/deps/undici/undici:7991:32)
                  0|MagicMirror | at Pool.dispatch (node:internal/deps/undici/undici:7772:44) {
                  0|MagicMirror | errno: -32,
                  0|MagicMirror | code: ‘EPIPE’,
                  0|MagicMirror | syscall: ‘write’
                  0|MagicMirror | }
                  0|MagicMirror | }
                  Thanks!
                    sdetweil @mspk
                    @mspk I think you have the wrong calendar url , you need the ical format url, not the embed url
                    mine is like
                    https://calendar.google.com/calendar/ical/sdetweil%40gmail.com/private-fhkjsadfhsdflk'sdfk/basic.ics
                    M M 2 Replies Last reply
                      mspk @sdetweil
                      mine is like
                      You mean the public one? Because for some reason, 3 of the 5 calendars work just fine with the private ICal Format address.
                        matt216 @sdetweil
                        @sdetweil I think you are potentially right. For baikal I have followed such advice as here: https://forum.magicmirror.builders/topic/434/caldav/4?_=1704811423495 where it was advised just adding ?export to the end of the cal URL to generate the ics file, but it is not an actual ics link.
                        I shall work along those lines…
                          sdetweil @matt216
                          @matt216 i test others problems by building an ics FILE and using the url
                          http://localhost:mirror_port/modules/default/calendar/????.ics
                          so it doesn’t have to be ON a ‘server’… just has to be an ICS format file.
                          linking to google, the url returns that data when the calendar does a get request
                          same as for the local file. BUT we depend on the data changing…
                          the cal module does not know that ‘this’ fetch was or was not different than the last fetch.
                          we don’t keep a diff… we just get the current data and present it.
                          if it didn’t change then nothing changes
                            matt216 @sdetweil
                            @sdetweil Trying this.
                            Steps:
                            1. add new test event scheduled tomorrow
                            2. verify event on another device, proving calendar server sync
                            3. curl .ics file from server, find test event
                            4. set calendar module as described in your post above
                            Result:
                            calendar loads successfully, but still does not show new event.
                            Event as shown in ics file:
                            BEGIN:VEVENT
                            CREATED:20240109T161646Z
                            DTEND;TZID=Europe/London:20240110T170000
                            DTSTAMP:20240109T161647Z
                            DTSTART;TZID=Europe/London:20240110T160000
                            LAST-MODIFIED:20240109T161646Z
                            SEQUENCE:0
                            SUMMARY:test54321
                            TRANSP:OPAQUE
                            UID:156ED8F1-9BDA-43D2-BE7C-DDEFE18E95EF
                            URL;VALUE=URI:
                            X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
                            X-APPLE-CREATOR-TEAM-IDENTITY:0000000000
                            END:VEVENT
                            I think MagicMirror does not like the baikal server - no events created since I migrated from iCloud to self-hosted baikal are showing. Can you see anything unusual in the ics event above @sdetweil ?
                            M S 2 Replies Last reply
                              matt216 @matt216
                              @sdetweil so I’ve just spun up a radicale calendar server and added a few test events, then some more - works perfectly!
                              Looks like a problem with baikal integration
                                sdetweil @matt216
                                @matt216 no. i created an ics and ran mm against it
                                [09.01.2024 10:42.53.207] [LOG]   Create new calendarfetcher for url: http://localhost:8090/modules/default/calendar/testbalkan.ics - Interval: 604800000
                                [09.01.2024 10:42.53.336] [DEBUG] parsed data={"156ED8F1-9BDA-43D2-BE7C-DDEFE18E95EF":{"type":"VEVENT","params":[],"created":"2024-01-09T16:16:46.000Z","end":"2024-01-10T17:00:00.000Z","dtstamp":"2024-01-09T16:16:47.000Z","start":"2024-01-10T16:00:00.000Z","datetype":"date-time","lastmodified":"2024-01-09T16:16:46.000Z","sequence":"0","summary":"test54321","transparency":"OPAQUE","uid":"156ED8F1-9BDA-43D2-BE7C-DDEFE18E95EF","url":{"params":{"VALUE":"URI"},"val":""},"APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000"},"vcalendar":{"type":"VCALENDAR"}}
                                [09.01.2024 10:42.53.337] [DEBUG] There are 2 calendar entries.
                                [09.01.2024 10:42.53.338] [DEBUG] Processing entry...
                                [09.01.2024 10:42.53.339] [DEBUG] Event:
                                [09.01.2024 10:42.53.339] [DEBUG] start: Wed Jan 10 2024 10:00:00 GMT-0600 (Central Standard Time)
                                [09.01.2024 10:42.53.339] [DEBUG] end:: Wed Jan 10 2024 11:00:00 GMT-0600 (Central Standard Time)
                                [09.01.2024 10:42.53.339] [DEBUG] duration: 3600000
                                [09.01.2024 10:42.53.340] [DEBUG] title: test54321
                                [09.01.2024 10:42.53.340] [DEBUG] full day event =false
                                [09.01.2024 10:42.53.340] [DEBUG] initial tz=Europe/London
                                [09.01.2024 10:42.53.340] [DEBUG] corrected tz=Europe/London
                                [09.01.2024 10:42.53.341] [DEBUG] start date/time=Wed Jan 10 2024 10:00:00 GMT-0600 (Central Standard Time)
                                [09.01.2024 10:42.53.341] [DEBUG] start offset=0
                                [09.01.2024 10:42.53.341] [DEBUG] start date/time w tz =Wed Jan 10 2024 10:00:00 GMT-0600 (Central Standard Time)
                                [09.01.2024 10:42.53.342] [DEBUG] event date=Wed Jan 10 2024 10:00:00 GMT-0600 (Central Standard Time)
                                [09.01.2024 10:42.53.342] [DEBUG] event offset=0 hour=16 event date=Wed Jan 10 2024 10:00:00 GMT-0600 (Central Standard Time)
                                [09.01.2024 10:42.53.342] [DEBUG] adjustHours=0
                                [09.01.2024 10:42.53.342] [DEBUG] saving event: test54321
                                [09.01.2024 10:42.53.342] [DEBUG] Processing entry...
                                [09.01.2024 10:42.53.342] [INFO]  Calendar-Fetcher: Broadcasting 1 events from http://localhost:8090/modules/default/calendar/testbalkan.ics.
                                  @matt216 can u send me the curl ics from the baikal server where the events don’t show??
                                  (if you are willing)
                                  rename to .txt
                                    matt216 @sdetweil
                                    @sdetweil this is from the curl’d ics file, showing one of the events that will not display on the mirror display:
                                    BEGIN:VEVENT
                                    SEQUENCE:0
                                    SUMMARY:test54321
                                    TRANSP:OPAQUE
                                    URL;VALUE=URI:
                                    END:VEVENT
                                    I’d be happy to send over the contents of the ics file before events start, if that would be helpful? Far too much personal family info to send the whole thing, Im afraid (again, no offence intended)!
                                      sdetweil @matt216
                                      @matt216 I used that event in an ICS and it displays just fine.
                                      so I think this is not the events but some communications problem.
                                      the fact that you have it working with another local hosting server tells me it’s something other than the data
                                        matt216
                                        Initial testing with the apache version of the baikal container looks promising (I’m currently having problems with the nginx version). Will continue testing along these lines…
                                          matt216 @matt216
                                          OK interesting. I created a brand new calendar server. Empty. Added one event to it and configured the mirror calendar module to use this server. It shows the one single event ok. I added a second new event to the calendar and this also shows on the mirror. Seems to work as expected - new events are showing!
                                          Then I import my whole famlly calendar and run the same test. I now have 5 family events showing on the calendar. But if I add a new event that should show within my 5 events, it does not show. :(
                                          Debug logs >somefile.txt show the mirror is picking up the new event from the ics file, it’s just not showing on the display.
                                            matt216
                                            @sdetweil I wonder if I could run a nightly cron job to purge the calendar module or something similar…? Not sure how the calendar fetcher works.
                                            It still feels like the calendar will load an ics link ok the first time, but is not displaying events created since that first load.
                                            Nightly purge and re-connect would be acceptable, I think. Any advice there?
                                            • 3 / 5
