    Calendar not updating
    95 Posts 4 Posters 84.6k Views 6 Watching
      mspk @sdetweil
      @sdetweil said in Calendar not updating:
      I think you have the wrong calendar url , you need the ical format url, not the embed url
      mine is like
      You mean the public one? Because for some reason, 3 of the 5 calendars work just fine with the private ICal Format address.
        matt216 @sdetweil
        @sdetweil I think you are potentially right. For baikal I have followed such advice as here: https://forum.magicmirror.builders/topic/434/caldav/4?_=1704811423495 where it was advised just adding ?export to the end of the cal URL to generate the ics file, but it is not an actual ics link.
        I shall work along those lines…
          sdetweil @matt216
          @matt216 i test others problems by building an ics FILE and using the url
          http://localhost:mirror_port/modules/default/calendar/????.ics
          so it doesn’t have to be ON a ‘server’… just has to be an ICS format file.
          linking to google, the url returns that data when the calendar does a get request
          same as for the local file. BUT we depend on the data changing…
          the cal module does not know that ‘this’ fetch was or was not different than the last fetch.
          we don’t keep a diff… we just get the current data and present it.
          if it didn’t change then nothing changes
            matt216 @sdetweil
            @sdetweil Trying this.
            Steps:
            1. add new test event scheduled tomorrow
            2. verify event on another device, proving calendar server sync
            3. curl .ics file from server, find test event
            4. set calendar module as described in your post above
            Result:
            calendar loads successfully, but still does not show new event.
            Event as shown in ics file:
            BEGIN:VEVENT
            CREATED:20240109T161646Z
            DTEND;TZID=Europe/London:20240110T170000
            DTSTAMP:20240109T161647Z
            DTSTART;TZID=Europe/London:20240110T160000
            LAST-MODIFIED:20240109T161646Z
            SEQUENCE:0
            SUMMARY:test54321
            TRANSP:OPAQUE
            UID:156ED8F1-9BDA-43D2-BE7C-DDEFE18E95EF
            URL;VALUE=URI:
            X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
            X-APPLE-CREATOR-TEAM-IDENTITY:0000000000
            END:VEVENT
            I think MagicMirror does not like the baikal server - no events created since I migrated from iCloud to self-hosted baikal are showing. Can you see anything unusual in the ics event above @sdetweil ?
            M S 2 Replies Last reply Reply Quote 0
              matt216 @matt216
              @sdetweil so I’ve just spun up a radicale calendar server and added a few test events, then some more - works perfectly!
              Looks like a problem with baikal integration
                sdetweil @matt216
                @matt216 no. i created an ics and ran mm against it
                [09.01.2024 10:42.53.207] [LOG]   Create new calendarfetcher for url: http://localhost:8090/modules/default/calendar/testbalkan.ics - Interval: 604800000
                [09.01.2024 10:42.53.336] [DEBUG] parsed data={"156ED8F1-9BDA-43D2-BE7C-DDEFE18E95EF":{"type":"VEVENT","params":[],"created":"2024-01-09T16:16:46.000Z","end":"2024-01-10T17:00:00.000Z","dtstamp":"2024-01-09T16:16:47.000Z","start":"2024-01-10T16:00:00.000Z","datetype":"date-time","lastmodified":"2024-01-09T16:16:46.000Z","sequence":"0","summary":"test54321","transparency":"OPAQUE","uid":"156ED8F1-9BDA-43D2-BE7C-DDEFE18E95EF","url":{"params":{"VALUE":"URI"},"val":""},"APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000"},"vcalendar":{"type":"VCALENDAR"}}
                [09.01.2024 10:42.53.337] [DEBUG] There are 2 calendar entries.
                [09.01.2024 10:42.53.338] [DEBUG] Processing entry...
                [09.01.2024 10:42.53.339] [DEBUG] Event:
                [09.01.2024 10:42.53.339] [DEBUG] start: Wed Jan 10 2024 10:00:00 GMT-0600 (Central Standard Time)
                [09.01.2024 10:42.53.339] [DEBUG] end:: Wed Jan 10 2024 11:00:00 GMT-0600 (Central Standard Time)
                [09.01.2024 10:42.53.339] [DEBUG] duration: 3600000
                [09.01.2024 10:42.53.340] [DEBUG] title: test54321
                [09.01.2024 10:42.53.340] [DEBUG] full day event =false
                [09.01.2024 10:42.53.340] [DEBUG] initial tz=Europe/London
                [09.01.2024 10:42.53.340] [DEBUG] corrected tz=Europe/London
                [09.01.2024 10:42.53.341] [DEBUG] start date/time=Wed Jan 10 2024 10:00:00 GMT-0600 (Central Standard Time)
                [09.01.2024 10:42.53.341] [DEBUG] start offset=0
                [09.01.2024 10:42.53.341] [DEBUG] start date/time w tz =Wed Jan 10 2024 10:00:00 GMT-0600 (Central Standard Time)
                [09.01.2024 10:42.53.342] [DEBUG] event date=Wed Jan 10 2024 10:00:00 GMT-0600 (Central Standard Time)
                [09.01.2024 10:42.53.342] [DEBUG] event offset=0 hour=16 event date=Wed Jan 10 2024 10:00:00 GMT-0600 (Central Standard Time)
                [09.01.2024 10:42.53.342] [DEBUG] adjustHours=0
                [09.01.2024 10:42.53.342] [DEBUG] saving event: test54321
                [09.01.2024 10:42.53.342] [DEBUG] Processing entry...
                [09.01.2024 10:42.53.342] [INFO]  Calendar-Fetcher: Broadcasting 1 events from http://localhost:8090/modules/default/calendar/testbalkan.ics.
                  @matt216 can u send me the curl ics from the baikal server where the events don’t show??
                  (if you are willing)
                  rename to .txt
                    matt216 @sdetweil
                    @sdetweil this is from the curl’d ics file, showing one of the events that will not display on the mirror display:
                    BEGIN:VEVENT
                    SEQUENCE:0
                    SUMMARY:test54321
                    TRANSP:OPAQUE
                    URL;VALUE=URI:
                    END:VEVENT
                    I’d be happy to send over the contents of the ics file before events start, if that would be helpful? Far too much personal family info to send the whole thing, Im afraid (again, no offence intended)!
                      sdetweil @matt216
                      @matt216 I used that event in an ICS and it displays just fine.
                      so I think this is not the events but some communications problem.
                      the fact that you have it working with another local hosting server tells me it’s something other than the data
                        matt216
                        Initial testing with the apache version of the baikal container looks promising (I’m currently having problems with the nginx version). Will continue testing along these lines…
                          matt216 @matt216
                          OK interesting. I created a brand new calendar server. Empty. Added one event to it and configured the mirror calendar module to use this server. It shows the one single event ok. I added a second new event to the calendar and this also shows on the mirror. Seems to work as expected - new events are showing!
                          Then I import my whole famlly calendar and run the same test. I now have 5 family events showing on the calendar. But if I add a new event that should show within my 5 events, it does not show. :(
                          Debug logs >somefile.txt show the mirror is picking up the new event from the ics file, it’s just not showing on the display.
                            matt216
                            @sdetweil I wonder if I could run a nightly cron job to purge the calendar module or something similar…? Not sure how the calendar fetcher works.
                            It still feels like the calendar will load an ics link ok the first time, but is not displaying events created since that first load.
                            Nightly purge and re-connect would be acceptable, I think. Any advice there?
                              sdetweil @matt216
                              @matt216 there is no way to programmatically trigger a calendar refresh. you have to restart mm
                              but you could do this w pm2
                              pm2 restart MagicMirror
                              (or it’s number)
                              in the current state does the broadcasting message indicate a change in number of events?
                                matt216 @sdetweil
                                @sdetweil yes, the broadcasting event number increases by 1 when I add my new event, but the event does not show on the display.
                                  sdetweil @matt216
                                  @matt216 can u show me the cal config again… as far as I can tell, the ONLY reason its not displayed is that the count (maximumEntries) clips off the total number of events
                                  actually there are more conditions… in calendar.js
                                  but they are all configurable
                                  			for (const e in calendar) {
                                  				const event = JSON.parse(JSON.stringify(calendar[e])); // clone object
                                  				if (this.config.hidePrivate && event.class === "PRIVATE") {
                                  					// do not add the current event, skip it
                                  					continue;
                                  				if (limitNumberOfEntries) { (//called with true)
                                  					if (event.endDate < maxPastDaysCompare) {
                                  						continue;
                                  					if (this.config.hideOngoing && event.startDate < now) {
                                  						continue;
                                  					if (this.config.hideDuplicates && this.listContainsEvent(events, event)) {
                                  						continue;
                                  					if (--remainingEntries < 0) {
                                  						break;
                                  and after filtering them out , apply the number of days limit and max entries limit
                                  		// Limit the number of days displayed
                                  		// If limitDays is set > 0, limit display to that number of days
                                  		if (this.config.limitDays > 0) {
                                  			let newEvents = [];
                                  			let lastDate = today.clone().subtract(1, "days").format("YYYYMMDD");
                                  			let days = 0;
                                  			for (const ev of events) {
                                  				let eventDate = moment(ev.startDate, "x").format("YYYYMMDD");
                                  				// if date of event is later than lastdate
                                  				// check if we already are showing max unique days
                                  				if (eventDate > lastDate) {
                                  					// if the only entry in the first day is a full day event that day is not counted as unique
                                  					if (!this.config.limitDaysNeverSkip && newEvents.length === 1 && days === 1 && newEvents[0].fullDayEvent) {
                                  						days--;
                                  					days++;
                                  					if (days > this.config.limitDays) {
                                  						continue;
                                  					} else {
                                  						lastDate = eventDate;
                                  				newEvents.push(ev);
                                  			events = newEvents;
                                  		return events.slice(0, this.config.maximumEntries);
                                    matt216 @sdetweil
                                    			header: "--- Calendar testing ---",
                                    				fetchInterval: 120000,
                                    				timeFormat: 'absolute',
                                    				maximumEntries: 5,
                                    				broadcastPastEvents: false,
                                    						url: 'https://my.cal.url/dav.php/calendars/family/default?export',
                                    						auth: 	{
                                    							user: 'family',
                                    							pass: 'pass',
                                    							method: 'basic'
                                    With the maximumEntries I currently have events showing several days in the future. When I am adding events to test this, I add the event to start just a few hours in the future so that it should show within the 5 events.
                                      sdetweil @matt216
                                      @matt216 lets make that maximumEvents: 20
                                      for this test
                                        matt216 @sdetweil
                                        @sdetweil Updated to 20. This now shows calendar entries all the way to early May but the test event that starts at 20:00 this evening does not show. There are actually lots of events over the next few days that are not showing.
                                          sdetweil @matt216
                                          @matt216 ok, lets add some debugging , then we can see what is received in the UI module and what is processed for display (after filtering)
                                          ~/MagicMirror/modules/default/calendar/calendar.js
                                          about line 219
                                          		const events = this.createEventList(true);
                                          		Log.log("events to process="+JSON.stringify(events))  // add this line
                                          		const wrapper = document.createElement("table");
                                          and around line 582
                                          		for (const calendarUrl in this.calendarData) {
                                          			const calendar = this.calendarData[calendarUrl];
                                          			Log.log("before filter events="+JSON.stringify(calendar))  // add this line
                                          			let remainingEntries = this.maximumEntriesForUrl(calendarUrl);
                                          then in the browser developers window (ctrl-shift-i to open) select the console tab,
                                          add cal to the filter field
                                          you will see these two blocks
                                          before filter events=[{"title":"Henry swim at Y","startDate":"1705156800000","endDate":"1705159200000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at Y","startDate":"1705761600000","endDate":"1705764000000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at Y","startDate":"1706366400000","endDate":"1706368800000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at Y","startDate":"1706971200000","endDate":"1706973600000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at
                                          and then
                                          events to process=[{"title":"Henry swim at Y","startDate":"1705156800000","endDate":"1705159200000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false,"url":"http://localhost:8090/modules/default/calendar/JUSTONE.ICS","today":false,"dayBeforeYesterday":false,"yesterday":false,"tomorrow":true,"dayAfterTomorrow":false},{"title":"Henry swim at Y","startDate":"1705761600000","endDate":"1705764000000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false,"url":"http://localhost:8090/modules/default/calendar/JUSTONE.IC
                                            @matt216 the before filter is what was sent from the parser
                                            the events to process is what will be shown, limited to maximumEntries in length
                                            • 4 / 5
