    Calendar not updating
    95 Posts 4 Posters 91.1k Views 6 Watching
      matt216
      @sdetweil I wonder if I could run a nightly cron job to purge the calendar module or something similar…? Not sure how the calendar fetcher works.
      It still feels like the calendar will load an ics link ok the first time, but is not displaying events created since that first load.
      Nightly purge and re-connect would be acceptable, I think. Any advice there?
        sdetweil @matt216
        @matt216 there is no way to programmatically trigger a calendar refresh. you have to restart mm
        but you could do this w pm2
        pm2 restart MagicMirror
        (or it’s number)
        in the current state does the broadcasting message indicate a change in number of events?
          matt216 @sdetweil
          @sdetweil yes, the broadcasting event number increases by 1 when I add my new event, but the event does not show on the display.
            sdetweil @matt216
            @matt216 can u show me the cal config again… as far as I can tell, the ONLY reason its not displayed is that the count (maximumEntries) clips off the total number of events
            actually there are more conditions… in calendar.js
            but they are all configurable
            			for (const e in calendar) {
            				const event = JSON.parse(JSON.stringify(calendar[e])); // clone object
            				if (this.config.hidePrivate && event.class === "PRIVATE") {
            					// do not add the current event, skip it
            					continue;
            				if (limitNumberOfEntries) { (//called with true)
            					if (event.endDate < maxPastDaysCompare) {
            						continue;
            					if (this.config.hideOngoing && event.startDate < now) {
            						continue;
            					if (this.config.hideDuplicates && this.listContainsEvent(events, event)) {
            						continue;
            					if (--remainingEntries < 0) {
            						break;
            and after filtering them out , apply the number of days limit and max entries limit
            		// Limit the number of days displayed
            		// If limitDays is set > 0, limit display to that number of days
            		if (this.config.limitDays > 0) {
            			let newEvents = [];
            			let lastDate = today.clone().subtract(1, "days").format("YYYYMMDD");
            			let days = 0;
            			for (const ev of events) {
            				let eventDate = moment(ev.startDate, "x").format("YYYYMMDD");
            				// if date of event is later than lastdate
            				// check if we already are showing max unique days
            				if (eventDate > lastDate) {
            					// if the only entry in the first day is a full day event that day is not counted as unique
            					if (!this.config.limitDaysNeverSkip && newEvents.length === 1 && days === 1 && newEvents[0].fullDayEvent) {
            						days--;
            					days++;
            					if (days > this.config.limitDays) {
            						continue;
            					} else {
            						lastDate = eventDate;
            				newEvents.push(ev);
            			events = newEvents;
            		return events.slice(0, this.config.maximumEntries);
              matt216 @sdetweil
              			header: "--- Calendar testing ---",
              				fetchInterval: 120000,
              				timeFormat: 'absolute',
              				maximumEntries: 5,
              				broadcastPastEvents: false,
              						url: 'https://my.cal.url/dav.php/calendars/family/default?export',
              						auth: 	{
              							user: 'family',
              							pass: 'pass',
              							method: 'basic'
              With the maximumEntries I currently have events showing several days in the future. When I am adding events to test this, I add the event to start just a few hours in the future so that it should show within the 5 events.
                sdetweil @matt216
                @matt216 lets make that maximumEvents: 20
                for this test
                  matt216 @sdetweil
                  @sdetweil Updated to 20. This now shows calendar entries all the way to early May but the test event that starts at 20:00 this evening does not show. There are actually lots of events over the next few days that are not showing.
                    sdetweil @matt216
                    @matt216 ok, lets add some debugging , then we can see what is received in the UI module and what is processed for display (after filtering)
                    ~/MagicMirror/modules/default/calendar/calendar.js
                    about line 219
                    		const events = this.createEventList(true);
                    		Log.log("events to process="+JSON.stringify(events))  // add this line
                    		const wrapper = document.createElement("table");
                    and around line 582
                    		for (const calendarUrl in this.calendarData) {
                    			const calendar = this.calendarData[calendarUrl];
                    			Log.log("before filter events="+JSON.stringify(calendar))  // add this line
                    			let remainingEntries = this.maximumEntriesForUrl(calendarUrl);
                    then in the browser developers window (ctrl-shift-i to open) select the console tab,
                    add cal to the filter field
                    you will see these two blocks
                    before filter events=[{"title":"Henry swim at Y","startDate":"1705156800000","endDate":"1705159200000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at Y","startDate":"1705761600000","endDate":"1705764000000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at Y","startDate":"1706366400000","endDate":"1706368800000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at Y","startDate":"1706971200000","endDate":"1706973600000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at
                    and then
                    events to process=[{"title":"Henry swim at Y","startDate":"1705156800000","endDate":"1705159200000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false,"url":"http://localhost:8090/modules/default/calendar/JUSTONE.ICS","today":false,"dayBeforeYesterday":false,"yesterday":false,"tomorrow":true,"dayAfterTomorrow":false},{"title":"Henry swim at Y","startDate":"1705761600000","endDate":"1705764000000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false,"url":"http://localhost:8090/modules/default/calendar/JUSTONE.IC
                      @matt216 the before filter is what was sent from the parser
                      the events to process is what will be shown, limited to maximumEntries in length
                        matt216 @sdetweil
                        @sdetweil Thanks Sam. Will have a go and report back.
                          sdetweil @matt216
                          @matt216 you can also use this web site
                          https://codebeautify.org/jsonvalidator?/jsonvalidate
                          to paste in the data (from [ to ]) and then push the format button (in pink) to make it more readable, ctrl-f will allow you to search for the entry you are looking for
                            matt216 @sdetweil
                            @sdetweil good tip, thanks.
                            Little update - I put maximumEntries back to 5 and all my events showed up! But then I added another event, pm2 restart and they disappeared again :weary_face:
                            We’re getting closer! I think you’re on to something with the maximumEntries effect. And also handling between back and front end.
                            I’ll have a go with editing calendar.js this weekend and report back.
                              matt216 @sdetweil
                              @sdetweil Hi Sam.
                              The before filter section is not showing the events that are missing. So not sent from the parser…?
                              The events to process section reflects what is seen in the before filter section.
                              Over the weekend the calendar looked good, but come Monday morning lots of events are missing. The mirror is currently showing events 10 days in the future even though there are plenty of events before then.
                              I have had a play with module config maximumEntries and limitDays to see if anything improves, but with no luck.
                              Thanks again,
                              Matt
                                sdetweil @matt216
                                @matt216 ok, go back to the prior parser
                                npm install node-ical@0.16.1
                                restart MM
                                  matt216 @sdetweil
                                  @sdetweil said in Calendar not updating:
                                  node-ical@0.16.1
                                  Done. Different events shown on the mirror - events over the next few days rather than 10 days away! - but still events not displaying.
                                  Browser dev tools indicate they’re sitll not getting parsed.
                                  Server pm2 logs do show the events are being picked up from the calendar server e.g.
                                  0|MagicMirror  | {"type":"VEVENT","params":[],"created":"2024-01-16T10:33:48.000Z","end":"2024-01-19T15:00:00.000Z","dtstamp":"2024-01-16T10:33:49.000Z","start":"2024-01-19T14:00:00.000Z","datetype":"date-time","lastmodified":"2024-01-16T10:33:48.000Z","sequence":"0","summary":"Alex bike","transparency":"OPAQUE","uid":"66D38BB9-70EA-486B-A297-58C2E0F3642C","url":{"params":{"VALUE":"URI"},"val":""},"APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000"}
                                  is not showing on the display and is not showing in browser devtools.
                                    sdetweil @matt216
                                    @matt216 can u show the rest of the debug on that event?
                                      matt216 @sdetweil
                                      @sdetweil Hi Sam.
                                      For a test I created an event in my calendar called test111 and verified server sync across several devices. This event starts in a few hours time so should be at the top of the events displayed on the mirror. I then stopped and started pm2.
                                      Here are the magicmirror debug logs for the event:
                                      [19.01.2024 08:41.23.286] [DEBUG] Event:
                                      {"type":"VEVENT","params":[],"created":"2024-01-19T08:39:52.000Z","lastmodified":"2024-01-19T08:40:05.000Z","dtstamp":"2024-01-19T08:40:05.000Z","uid":"7383cead-3ce7-4a50-80d0-cf214e98caac","summary":"test111","start":"2024-01-19T11:00:00.000Z","datetype":"date-time","end":"2024-01-19T12:00:00.000Z","transparency":"OPAQUE"}
                                      [19.01.2024 08:41.23.287] [DEBUG] start: Fri Jan 19 2024 11:00:00 GMT+0000 (Greenwich Mean Time)
                                      [19.01.2024 08:41.23.287] [DEBUG] end:: Fri Jan 19 2024 12:00:00 GMT+0000 (Greenwich Mean Time)
                                      [19.01.2024 08:41.23.287] [DEBUG] duration: 3600000
                                      [19.01.2024 08:41.23.287] [DEBUG] title: test111
                                      [19.01.2024 08:41.23.288] [DEBUG] initial tz=Europe/London
                                      [19.01.2024 08:41.23.288] [DEBUG] corrected tz=Europe/London
                                      [19.01.2024 08:41.23.288] [DEBUG] start date/time=Fri Jan 19 2024 11:00:00 GMT+0000 (Greenwich Mean Time)
                                      [19.01.2024 08:41.23.288] [DEBUG] start offset=0
                                      [19.01.2024 08:41.23.289] [DEBUG] start date/time w tz =Fri Jan 19 2024 11:00:00 GMT+0000 (Greenwich Mean Time)
                                      [19.01.2024 08:41.23.289] [DEBUG] event date=Fri Jan 19 2024 11:00:00 GMT+0000 (Greenwich Mean Time)
                                      [19.01.2024 08:41.23.289] [DEBUG] event offset=0 hour=11 event date=Fri Jan 19 2024 11:00:00 GMT+0000 (Greenwich Mean Time)
                                      [19.01.2024 08:41.23.289] [DEBUG] adjustHours=0
                                      [19.01.2024 08:41.23.290] [DEBUG] Processing entry...
                                      [19.01.2024 08:41.23.297] [INFO]  Calendar-Fetcher: Broadcasting 621 events from https://my.cal.url
                                      But in dev tools the event does not appear in the before filter events or events to process console sections which, i think, would indicate it’s not being parsed through to the UI…?
                                      For comparison, if it helps, an event that is being parsed through looks like this in the logs (with a couple of bits redacted for privacy):
                                      [19.01.2024 08:41.45.109] [DEBUG] Event:
                                      {"type":"VEVENT","params":[],"created":"2024-01-05T14:17:41.000Z","end":"2024-01-20T21:00:00.000Z","dtstamp":"2024-01-16T18:42:50.000Z","start":"2024-01-20T17:00:00.000Z","datetype":"date-time","lastmodified":"2024-01-16T18:42:49.000Z","location":"redacted","sequence":"2","summary":"Jarv birthday beers","transparency":"OPAQUE","uid":"7DF90CA7-D3BA-4519-96F7-944D027F79DE","url":{"params":{"VALUE":"URI"},"val":""},"APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000","APPLE-STRUCTURED-LOCATION":{"params":{"VALUE":"URI","X-ADDRESS":"redacted","X-APPLE-MAPKIT-HANDLE":"redacted","X-APPLE-RADIUS":141.1751152233582,"X-APPLE-REFERENCEFRAME":1,"X-TITLE":"redacted"},"val":"geo:redacted"}}
                                      [19.01.2024 08:41.45.109] [DEBUG] start: Sat Jan 20 2024 17:00:00 GMT+0000 (Greenwich Mean Time)
                                      [19.01.2024 08:41.45.110] [DEBUG] end:: Sat Jan 20 2024 21:00:00 GMT+0000 (Greenwich Mean Time)
                                      [19.01.2024 08:41.45.110] [DEBUG] duration: 14400000
                                      [19.01.2024 08:41.45.110] [DEBUG] title: Jarv birthday beers
                                      [19.01.2024 08:41.45.110] [DEBUG] initial tz=Europe/London
                                      [19.01.2024 08:41.45.110] [DEBUG] corrected tz=Europe/London
                                      [19.01.2024 08:41.45.111] [DEBUG] start date/time=Sat Jan 20 2024 17:00:00 GMT+0000 (Greenwich Mean Time)
                                      [19.01.2024 08:41.45.111] [DEBUG] start offset=0
                                      [19.01.2024 08:41.45.111] [DEBUG] start date/time w tz =Sat Jan 20 2024 17:00:00 GMT+0000 (Greenwich Mean Time)
                                      [19.01.2024 08:41.45.112] [DEBUG] event date=Sat Jan 20 2024 17:00:00 GMT+0000 (Greenwich Mean Time)
                                      [19.01.2024 08:41.45.112] [DEBUG] event offset=0 hour=17 event date=Sat Jan 20 2024 17:00:00 GMT+0000 (Greenwich Mean Time)
                                      [19.01.2024 08:41.45.112] [DEBUG] adjustHours=0
                                      [19.01.2024 08:41.45.113] [DEBUG] Processing entry...
                                      Thanks again.
                                        sdetweil @matt216
                                        @matt216 interesting
                                        time to fall back to the prior parser
                                          matt216 @sdetweil
                                          pi@magicmirror:~/MagicMirror $ npm install node-ical@0.16.1
                                          up to date in 11s
                                          196 packages are looking for funding
                                            run `npm fund` for details
                                          Done. Same result - event which should display is seen in the pm2 logs, but not in the UI events.
                                            sdetweil @matt216
                                            @matt216 I sent you a message here in chat with a link to another test version of the calendar parser file…
                                            • 4 / 5
