    Calendar not updating
    95 Posts 4 Posters 90.1k Views 6 Watching
      matt216 @matt216
      OK interesting. I created a brand new calendar server. Empty. Added one event to it and configured the mirror calendar module to use this server. It shows the one single event ok. I added a second new event to the calendar and this also shows on the mirror. Seems to work as expected - new events are showing!
      Then I import my whole famlly calendar and run the same test. I now have 5 family events showing on the calendar. But if I add a new event that should show within my 5 events, it does not show. :(
      Debug logs >somefile.txt show the mirror is picking up the new event from the ics file, it’s just not showing on the display.
        matt216
        @sdetweil I wonder if I could run a nightly cron job to purge the calendar module or something similar…? Not sure how the calendar fetcher works.
        It still feels like the calendar will load an ics link ok the first time, but is not displaying events created since that first load.
        Nightly purge and re-connect would be acceptable, I think. Any advice there?
          sdetweil @matt216
          @matt216 there is no way to programmatically trigger a calendar refresh. you have to restart mm
          but you could do this w pm2
          pm2 restart MagicMirror
          (or it’s number)
          in the current state does the broadcasting message indicate a change in number of events?
            matt216 @sdetweil
            @sdetweil yes, the broadcasting event number increases by 1 when I add my new event, but the event does not show on the display.
              sdetweil @matt216
              @matt216 can u show me the cal config again… as far as I can tell, the ONLY reason its not displayed is that the count (maximumEntries) clips off the total number of events
              actually there are more conditions… in calendar.js
              but they are all configurable
              			for (const e in calendar) {
              				const event = JSON.parse(JSON.stringify(calendar[e])); // clone object
              				if (this.config.hidePrivate && event.class === "PRIVATE") {
              					// do not add the current event, skip it
              					continue;
              				if (limitNumberOfEntries) { (//called with true)
              					if (event.endDate < maxPastDaysCompare) {
              						continue;
              					if (this.config.hideOngoing && event.startDate < now) {
              						continue;
              					if (this.config.hideDuplicates && this.listContainsEvent(events, event)) {
              						continue;
              					if (--remainingEntries < 0) {
              						break;
              and after filtering them out , apply the number of days limit and max entries limit
              		// Limit the number of days displayed
              		// If limitDays is set > 0, limit display to that number of days
              		if (this.config.limitDays > 0) {
              			let newEvents = [];
              			let lastDate = today.clone().subtract(1, "days").format("YYYYMMDD");
              			let days = 0;
              			for (const ev of events) {
              				let eventDate = moment(ev.startDate, "x").format("YYYYMMDD");
              				// if date of event is later than lastdate
              				// check if we already are showing max unique days
              				if (eventDate > lastDate) {
              					// if the only entry in the first day is a full day event that day is not counted as unique
              					if (!this.config.limitDaysNeverSkip && newEvents.length === 1 && days === 1 && newEvents[0].fullDayEvent) {
              						days--;
              					days++;
              					if (days > this.config.limitDays) {
              						continue;
              					} else {
              						lastDate = eventDate;
              				newEvents.push(ev);
              			events = newEvents;
              		return events.slice(0, this.config.maximumEntries);
                matt216 @sdetweil
                			header: "--- Calendar testing ---",
                				fetchInterval: 120000,
                				timeFormat: 'absolute',
                				maximumEntries: 5,
                				broadcastPastEvents: false,
                						url: 'https://my.cal.url/dav.php/calendars/family/default?export',
                						auth: 	{
                							user: 'family',
                							pass: 'pass',
                							method: 'basic'
                With the maximumEntries I currently have events showing several days in the future. When I am adding events to test this, I add the event to start just a few hours in the future so that it should show within the 5 events.
                  sdetweil @matt216
                  @matt216 lets make that maximumEvents: 20
                  for this test
                    matt216 @sdetweil
                    @sdetweil Updated to 20. This now shows calendar entries all the way to early May but the test event that starts at 20:00 this evening does not show. There are actually lots of events over the next few days that are not showing.
                      sdetweil @matt216
                      @matt216 ok, lets add some debugging , then we can see what is received in the UI module and what is processed for display (after filtering)
                      ~/MagicMirror/modules/default/calendar/calendar.js
                      about line 219
                      		const events = this.createEventList(true);
                      		Log.log("events to process="+JSON.stringify(events))  // add this line
                      		const wrapper = document.createElement("table");
                      and around line 582
                      		for (const calendarUrl in this.calendarData) {
                      			const calendar = this.calendarData[calendarUrl];
                      			Log.log("before filter events="+JSON.stringify(calendar))  // add this line
                      			let remainingEntries = this.maximumEntriesForUrl(calendarUrl);
                      then in the browser developers window (ctrl-shift-i to open) select the console tab,
                      add cal to the filter field
                      you will see these two blocks
                      before filter events=[{"title":"Henry swim at Y","startDate":"1705156800000","endDate":"1705159200000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at Y","startDate":"1705761600000","endDate":"1705764000000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at Y","startDate":"1706366400000","endDate":"1706368800000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at Y","startDate":"1706971200000","endDate":"1706973600000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false},{"title":"Henry swim at
                      and then
                      events to process=[{"title":"Henry swim at Y","startDate":"1705156800000","endDate":"1705159200000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false,"url":"http://localhost:8090/modules/default/calendar/JUSTONE.ICS","today":false,"dayBeforeYesterday":false,"yesterday":false,"tomorrow":true,"dayAfterTomorrow":false},{"title":"Henry swim at Y","startDate":"1705761600000","endDate":"1705764000000","fullDayEvent":false,"recurringEvent":true,"class":"","firstYear":2024,"location":false,"geo":false,"description":false,"url":"http://localhost:8090/modules/default/calendar/JUSTONE.IC
                        @matt216 the before filter is what was sent from the parser
                        the events to process is what will be shown, limited to maximumEntries in length
                          matt216 @sdetweil
                          @sdetweil Thanks Sam. Will have a go and report back.
                            sdetweil @matt216
                            @matt216 you can also use this web site
                            https://codebeautify.org/jsonvalidator?/jsonvalidate
                            to paste in the data (from [ to ]) and then push the format button (in pink) to make it more readable, ctrl-f will allow you to search for the entry you are looking for
                              matt216 @sdetweil
                              @sdetweil good tip, thanks.
                              Little update - I put maximumEntries back to 5 and all my events showed up! But then I added another event, pm2 restart and they disappeared again :weary_face:
                              We’re getting closer! I think you’re on to something with the maximumEntries effect. And also handling between back and front end.
                              I’ll have a go with editing calendar.js this weekend and report back.
                                matt216 @sdetweil
                                @sdetweil Hi Sam.
                                The before filter section is not showing the events that are missing. So not sent from the parser…?
                                The events to process section reflects what is seen in the before filter section.
                                Over the weekend the calendar looked good, but come Monday morning lots of events are missing. The mirror is currently showing events 10 days in the future even though there are plenty of events before then.
                                I have had a play with module config maximumEntries and limitDays to see if anything improves, but with no luck.
                                Thanks again,
                                Matt
                                  sdetweil @matt216
                                  @matt216 ok, go back to the prior parser
                                  npm install node-ical@0.16.1
                                  restart MM
                                    matt216 @sdetweil
                                    @sdetweil said in Calendar not updating:
                                    node-ical@0.16.1
                                    Done. Different events shown on the mirror - events over the next few days rather than 10 days away! - but still events not displaying.
                                    Browser dev tools indicate they’re sitll not getting parsed.
                                    Server pm2 logs do show the events are being picked up from the calendar server e.g.
                                    0|MagicMirror  | {"type":"VEVENT","params":[],"created":"2024-01-16T10:33:48.000Z","end":"2024-01-19T15:00:00.000Z","dtstamp":"2024-01-16T10:33:49.000Z","start":"2024-01-19T14:00:00.000Z","datetype":"date-time","lastmodified":"2024-01-16T10:33:48.000Z","sequence":"0","summary":"Alex bike","transparency":"OPAQUE","uid":"66D38BB9-70EA-486B-A297-58C2E0F3642C","url":{"params":{"VALUE":"URI"},"val":""},"APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000"}
                                    is not showing on the display and is not showing in browser devtools.
                                      sdetweil @matt216
                                      @matt216 can u show the rest of the debug on that event?
                                        matt216 @sdetweil
                                        @sdetweil Hi Sam.
                                        For a test I created an event in my calendar called test111 and verified server sync across several devices. This event starts in a few hours time so should be at the top of the events displayed on the mirror. I then stopped and started pm2.
                                        Here are the magicmirror debug logs for the event:
                                        [19.01.2024 08:41.23.286] [DEBUG] Event:
                                        {"type":"VEVENT","params":[],"created":"2024-01-19T08:39:52.000Z","lastmodified":"2024-01-19T08:40:05.000Z","dtstamp":"2024-01-19T08:40:05.000Z","uid":"7383cead-3ce7-4a50-80d0-cf214e98caac","summary":"test111","start":"2024-01-19T11:00:00.000Z","datetype":"date-time","end":"2024-01-19T12:00:00.000Z","transparency":"OPAQUE"}
                                        [19.01.2024 08:41.23.287] [DEBUG] start: Fri Jan 19 2024 11:00:00 GMT+0000 (Greenwich Mean Time)
                                        [19.01.2024 08:41.23.287] [DEBUG] end:: Fri Jan 19 2024 12:00:00 GMT+0000 (Greenwich Mean Time)
                                        [19.01.2024 08:41.23.287] [DEBUG] duration: 3600000
                                        [19.01.2024 08:41.23.287] [DEBUG] title: test111
                                        [19.01.2024 08:41.23.288] [DEBUG] initial tz=Europe/London
                                        [19.01.2024 08:41.23.288] [DEBUG] corrected tz=Europe/London
                                        [19.01.2024 08:41.23.288] [DEBUG] start date/time=Fri Jan 19 2024 11:00:00 GMT+0000 (Greenwich Mean Time)
                                        [19.01.2024 08:41.23.288] [DEBUG] start offset=0
                                        [19.01.2024 08:41.23.289] [DEBUG] start date/time w tz =Fri Jan 19 2024 11:00:00 GMT+0000 (Greenwich Mean Time)
                                        [19.01.2024 08:41.23.289] [DEBUG] event date=Fri Jan 19 2024 11:00:00 GMT+0000 (Greenwich Mean Time)
                                        [19.01.2024 08:41.23.289] [DEBUG] event offset=0 hour=11 event date=Fri Jan 19 2024 11:00:00 GMT+0000 (Greenwich Mean Time)
                                        [19.01.2024 08:41.23.289] [DEBUG] adjustHours=0
                                        [19.01.2024 08:41.23.290] [DEBUG] Processing entry...
                                        [19.01.2024 08:41.23.297] [INFO]  Calendar-Fetcher: Broadcasting 621 events from https://my.cal.url
                                        But in dev tools the event does not appear in the before filter events or events to process console sections which, i think, would indicate it’s not being parsed through to the UI…?
                                        For comparison, if it helps, an event that is being parsed through looks like this in the logs (with a couple of bits redacted for privacy):
                                        [19.01.2024 08:41.45.109] [DEBUG] Event:
                                        {"type":"VEVENT","params":[],"created":"2024-01-05T14:17:41.000Z","end":"2024-01-20T21:00:00.000Z","dtstamp":"2024-01-16T18:42:50.000Z","start":"2024-01-20T17:00:00.000Z","datetype":"date-time","lastmodified":"2024-01-16T18:42:49.000Z","location":"redacted","sequence":"2","summary":"Jarv birthday beers","transparency":"OPAQUE","uid":"7DF90CA7-D3BA-4519-96F7-944D027F79DE","url":{"params":{"VALUE":"URI"},"val":""},"APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000","APPLE-STRUCTURED-LOCATION":{"params":{"VALUE":"URI","X-ADDRESS":"redacted","X-APPLE-MAPKIT-HANDLE":"redacted","X-APPLE-RADIUS":141.1751152233582,"X-APPLE-REFERENCEFRAME":1,"X-TITLE":"redacted"},"val":"geo:redacted"}}
                                        [19.01.2024 08:41.45.109] [DEBUG] start: Sat Jan 20 2024 17:00:00 GMT+0000 (Greenwich Mean Time)
                                        [19.01.2024 08:41.45.110] [DEBUG] end:: Sat Jan 20 2024 21:00:00 GMT+0000 (Greenwich Mean Time)
                                        [19.01.2024 08:41.45.110] [DEBUG] duration: 14400000
                                        [19.01.2024 08:41.45.110] [DEBUG] title: Jarv birthday beers
                                        [19.01.2024 08:41.45.110] [DEBUG] initial tz=Europe/London
                                        [19.01.2024 08:41.45.110] [DEBUG] corrected tz=Europe/London
                                        [19.01.2024 08:41.45.111] [DEBUG] start date/time=Sat Jan 20 2024 17:00:00 GMT+0000 (Greenwich Mean Time)
                                        [19.01.2024 08:41.45.111] [DEBUG] start offset=0
                                        [19.01.2024 08:41.45.111] [DEBUG] start date/time w tz =Sat Jan 20 2024 17:00:00 GMT+0000 (Greenwich Mean Time)
                                        [19.01.2024 08:41.45.112] [DEBUG] event date=Sat Jan 20 2024 17:00:00 GMT+0000 (Greenwich Mean Time)
                                        [19.01.2024 08:41.45.112] [DEBUG] event offset=0 hour=17 event date=Sat Jan 20 2024 17:00:00 GMT+0000 (Greenwich Mean Time)
                                        [19.01.2024 08:41.45.112] [DEBUG] adjustHours=0
                                        [19.01.2024 08:41.45.113] [DEBUG] Processing entry...
                                        Thanks again.
                                          sdetweil @matt216
                                          @matt216 interesting
                                          time to fall back to the prior parser
                                            matt216 @sdetweil
                                            pi@magicmirror:~/MagicMirror $ npm install node-ical@0.16.1
                                            up to date in 11s
                                            196 packages are looking for funding
                                              run `npm fund` for details
                                            Done. Same result - event which should display is seen in the pm2 logs, but not in the UI events.
                                            • 4 / 5
